#include <commandsProc.hxx>
| CommandSetInlineNodeScript (std::string node, std::string script) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _nodeName |
| std::string | _script |
| std::string | _oldScript |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 653 of file commandsProc.hxx.
| CommandSetInlineNodeScript::CommandSetInlineNodeScript | ( | std::string | node, |
| std::string | script | ||
Definition at line 3657 of file commandsProc.cxx.
References _oldScript, and DEBTRACE.
protectedvirtual |
Definition at line 3664 of file commandsProc.cxx.
References _nodeName.
protectedvirtual |
Definition at line 3670 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _nodeName, _oldScript, _script, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SYNCHRO, YACS::HMI::SubjectNode::update(), and YASSERT.
protectedvirtual |
Definition at line 3705 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _nodeName, _oldScript, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SYNCHRO, YACS::HMI::SubjectNode::update(), and YASSERT.
protected |
Definition at line 661 of file commandsProc.hxx.
protected |
Definition at line 663 of file commandsProc.hxx.
Referenced by CommandSetInlineNodeScript(), localExecute(), and localReverse().
protected |
Definition at line 662 of file commandsProc.hxx.
Referenced by localExecute().
