#include <commandsProc.hxx>
| CommandSetForEachBranch (std::string forEach, std::string value) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _forEach |
| std::string | _value |
| int | _oldValue |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 470 of file commandsProc.hxx.
| CommandSetForEachBranch::CommandSetForEachBranch | ( | std::string | forEach, |
| std::string | value | ||
Definition at line 2712 of file commandsProc.cxx.
protectedvirtual |
Definition at line 2720 of file commandsProc.cxx.
protectedvirtual |
Definition at line 2726 of file commandsProc.cxx.
References _forEach, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _value, DEBTRACE, YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputPort(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::Subject::update(), YACS::HMI::SubjectNode::update(), and YASSERT.
protectedvirtual |
Definition at line 2753 of file commandsProc.cxx.
References _forEach, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, DEBTRACE, YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputPort(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::Subject::update(), YACS::HMI::SubjectNode::update(), and YASSERT.
protected |
Definition at line 479 of file commandsProc.hxx.
protected |
Definition at line 481 of file commandsProc.hxx.
Referenced by CommandSetForEachBranch(), localExecute(), and localReverse().
protected |
Definition at line 480 of file commandsProc.hxx.
