YACS::HMI::CommandAddNodeFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddNodeFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddNodeFromCatalog:
 CommandAddNodeFromCatalog (YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string position, std::string name, bool newCompoInst=true, int swCase=0)
YACS::ENGINE::Node * getNode ()
YACS::HMI::SubjectNode * getSubjectNode ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
TypeOfElem _typeNode
std::string _compoName
std::string _typeName
std::string _position
bool _newCompoInst
int _swCase
YACS::ENGINE::Node * _node
YACS::HMI::SubjectNode * _snode
bool _normalReverse
Definition at line 108 of file commandsProc.hxx.
◆ CommandAddNodeFromCatalog()
CommandAddNodeFromCatalog::CommandAddNodeFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  compo,
std::string  type,
std::string  name,
bool  newCompoInst = true,
int  swCase = 0
Definition at line 180 of file commandsProc.cxx.
187 : Command(), _catalog(catalog), _compoName(compo), _typeName(type),
188 _position(position), _name(name), _newCompoInst(newCompoInst), _swCase(swCase)
189{
190 DEBTRACE("CommandAddNodeFromCatalog " << compo << " " << type << " " << position << " " << name);
191 _node=0;
192 _snode=0;
193}
References _node, _snode, and DEBTRACE.
◆ dump()
std::string CommandAddNodeFromCatalog::dump ( )
Definition at line 195 of file commandsProc.cxx.
196{
197 string ret ="CommandAddNodeFromCatalog " + _compoName + " " + _typeName + " " + _position + " " + _name;
198 return ret;
199}
References _compoName, _name, _position, and _typeName.
◆ getNode()
YACS::ENGINE::Node * CommandAddNodeFromCatalog::getNode ( )
Definition at line 201 of file commandsProc.cxx.
202{
203 return _node;
204}
References _node.
Referenced by YACS::HMI::SubjectComposedNode::createNode().
◆ getSubjectNode()
YACS::HMI::SubjectNode * CommandAddNodeFromCatalog::getSubjectNode ( )
Definition at line 206 of file commandsProc.cxx.
207{
208 return _snode;
209}
References _snode.
◆ localExecute()
bool CommandAddNodeFromCatalog::localExecute ( )
Definition at line 211 of file commandsProc.cxx.
212{
213 DEBTRACE("CommandAddNodeFromCatalog::localExecute");
214
215 Node *son = 0;
216 Node *nodeToClone = 0;
217 try
218 {
219 if (_compoName.empty())
220 {
221 if (_catalog->_nodeMap.count(_typeName))
222 nodeToClone = _catalog->_nodeMap[_typeName];
223 else if (_catalog->_composednodeMap.count(_typeName))
224 nodeToClone = _catalog->_composednodeMap[_typeName];
225 }
226 else
228 {
230 if (compodef->_serviceMap.count(_typeName))
231 nodeToClone = compodef->_serviceMap[_typeName];
232 }
233 if (nodeToClone)
234 _typeNode = ProcInvoc::getTypeOfNode(nodeToClone);
235
238 Node* node = proc;
239 ServiceNode *service = 0;
240
241 if (!_position.empty()) node = proc->getChildByName(_position);
242 ComposedNode* father =dynamic_cast<ComposedNode*> (node);
243 if (father && nodeToClone)
244 {
245 son = nodeToClone->clone(0);
246 son->setName(_name);
247 service = dynamic_cast<ServiceNode*>(son);
248 }
249
250 // Node creation eventually reusing old component instance
251 ComponentInstance *compo = 0;
252 if (service)
253 compo = service->getComponent();
254
255 if(compo)
256 {
257 std::string compoName=compo->getCompoName();
258 DEBTRACE(compoName);
259 std::string compoInstName=compo->getInstanceName();
260 DEBTRACE(compoInstName);
261 if(!_newCompoInst)
262 {
264 DEBTRACE(lastcompo);
265 if(lastcompo)
266 {
267 DEBTRACE(lastcompo->getInstanceName());
268 service->setComponent(lastcompo); // use the last component instance of the same type and not a new instance
269 }
270 else
272 }
273 else
275 }
276
277 if (son)
278 {
279 TypeOfElem fatherType = ProcInvoc::getTypeOfNode(father);
280 switch (fatherType)
281 {
282 case BLOC:
283 (dynamic_cast<YACS::ENGINE::Bloc*>(father))->edAddChild(son);
284 break;
285 case FORLOOP:
286 (dynamic_cast<YACS::ENGINE::ForLoop*>(father))->edSetNode(son);
287 break;
288 case WHILELOOP:
289 (dynamic_cast<YACS::ENGINE::WhileLoop*>(father))->edSetNode(son);
290 break;
291 case SWITCH:
292 (dynamic_cast<YACS::ENGINE::Switch*>(father))->edSetNode(_swCase,son);
293 break;
294 case FOREACHLOOP:
295 (dynamic_cast<YACS::ENGINE::ForEachLoopGen*>(father))->edSetNode(son);
296 break;
297 case OPTIMIZERLOOP:
298 (dynamic_cast<YACS::ENGINE::OptimizerLoop*>(father))->edSetNode(son);
299 break;
300 default:
301 YASSERT(0);
302 }
303 }
304 _node = son;
305 if (!_node)
306 throw YACS::Exception("node from catalog is not correct: check if catalog is up to date!");
307
311 _snode->loadLinks();
312 }
313 catch (Exception& ex)
314 {
315 DEBTRACE("CommandAddNode::localExecute() : " << ex.what());
317 if (son) delete son;
318 _node = 0;
319 }
320 return (_node != 0);
321}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: Bloc.hxx:36
std::map< std::string, ComposedNode * > _composednodeMap
Definition: Catalog.hxx:52
std::map< std::string, ComponentDefinition * > _componentMap
Definition: Catalog.hxx:50
std::map< std::string, Node * > _nodeMap
Definition: Catalog.hxx:51
Base class for component definition.
std::map< std::string, ServiceNode * > _serviceMap
const std::string & getInstanceName() const
Class for for loop node.
Definition: ForLoop.hxx:33
Base class for all nodes.
Definition: Node.hxx:70
Change the name of the node.
Definition: Node.cxx:162
Node * clone(ComposedNode *father, bool editionOnly=true) const
This method MUST NEVER BE VIRTUAL
Definition: Node.cxx:131
Definition: Proc.hxx:44
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: Switch.hxx:85
Class for a while loop.
Definition: WhileLoop.hxx:39
void setCurrentCatalog(YACS::ENGINE::Catalog *cata)
Definition: guiContext.hxx:61
Definition: guiContext.hxx:67
std::map< std::string, YACS::ENGINE::ComponentInstance * > _mapOfLastComponentInstance
Definition: guiContext.hxx:78
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
static TypeOfElem getTypeOfNode(YACS::ENGINE::Node *node)
SubjectNode * addSubjectNode(YACS::ENGINE::Node *node, std::string name="", YACS::ENGINE::Catalog *catalog=0, std::string compo="", std::string type="")
virtual void loadLinks()
virtual void loadChildren()
References _catalog, _compoName, YACS::ENGINE::Catalog::_componentMap, YACS::ENGINE::Catalog::_composednodeMap, YACS::HMI::GuiContext::_mapOfLastComponentInstance, YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _newCompoInst, _node, YACS::ENGINE::Catalog::_nodeMap, _position, YACS::ENGINE::ComponentDefinition::_serviceMap, _snode, _swCase, _typeName, _typeNode, YACS::HMI::SubjectComposedNode::addSubjectNode(), YACS::HMI::BLOC, YACS::ENGINE::Node::clone(), DEBTRACE, testCppPluginInvokation::ex, YACS::HMI::FOREACHLOOP, YACS::HMI::FORLOOP, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::HMI::GuiContext::getProc(), YACS::HMI::ProcInvoc::getTypeOfNode(), YACS::HMI::Subject::loadChildren(), YACS::HMI::Subject::loadLinks(), YACS::HMI::OPTIMIZERLOOP, YACS::ENGINE::ServiceNode::setComponent(), YACS::HMI::GuiContext::setCurrentCatalog(), setErrorMsg(), YACS::ENGINE::Node::setName(), YACS::HMI::SWITCH, YACS::HMI::WHILELOOP, and YASSERT.
◆ localReverse()
bool CommandAddNodeFromCatalog::localReverse ( )
Definition at line 323 of file commandsProc.cxx.
324{
325 DEBTRACE("CommandAddNodeFromCatalog::localReverse");
326 try
327 {
329 string nodeName;
330 if (_position.empty())
331 nodeName= _name;
332 else
333 nodeName = _position + "." + _name;
334 DEBTRACE(nodeName);
335 _node = proc->getChildByName(nodeName);
336 YASSERT(_node);
337 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(_node));
339
340 Subject *father=_snode->getParent();
341 DEBTRACE(father);
342 DEBTRACE(father->getName());
344 _snode= 0;
345 _node = 0;
346 if (father)
347 {
348 DEBTRACE("REMOVE");
349 father->select(true);
350 father->update(REMOVE,0,0);
351 }
352 return true;
353 }
354 catch (Exception& ex)
355 {
356 DEBTRACE("CommandAddNodeFromCatalog::localReverse(): " << ex.what());
358 return false;
359 }
360}
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual std::string getName()
virtual void select(bool isSelected)
References YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _node, _position, _snode, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::Subject::getName(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddNodeFromCatalog::_catalog
Definition at line 124 of file commandsProc.hxx.
Referenced by localExecute().
◆ _compoName
std::string YACS::HMI::CommandAddNodeFromCatalog::_compoName
Definition at line 126 of file commandsProc.hxx.
◆ _name
std::string YACS::HMI::CommandAddNodeFromCatalog::_name
Definition at line 129 of file commandsProc.hxx.
◆ _newCompoInst
bool YACS::HMI::CommandAddNodeFromCatalog::_newCompoInst
Definition at line 130 of file commandsProc.hxx.
◆ _node
YACS::ENGINE::Node* YACS::HMI::CommandAddNodeFromCatalog::_node
Definition at line 132 of file commandsProc.hxx.
Referenced by CommandAddNodeFromCatalog(), getNode(), localExecute(), and localReverse().
◆ _position
std::string YACS::HMI::CommandAddNodeFromCatalog::_position
Definition at line 128 of file commandsProc.hxx.
◆ _snode
YACS::HMI::SubjectNode* YACS::HMI::CommandAddNodeFromCatalog::_snode
◆ _swCase
int YACS::HMI::CommandAddNodeFromCatalog::_swCase
Definition at line 131 of file commandsProc.hxx.
◆ _typeName
std::string YACS::HMI::CommandAddNodeFromCatalog::_typeName
Definition at line 127 of file commandsProc.hxx.
◆ _typeNode
TypeOfElem YACS::HMI::CommandAddNodeFromCatalog::_typeNode
Definition at line 125 of file commandsProc.hxx.
