YACS::HMI::CommandRenameNode Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandRenameNode:
Collaboration diagram for YACS::HMI::CommandRenameNode:
 CommandRenameNode (std::string position, std::string name)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _position
std::string _oldName
std::string _newpos
bool _normalReverse
Definition at line 189 of file commandsProc.hxx.
◆ CommandRenameNode()
CommandRenameNode::CommandRenameNode ( std::string  position,
std::string  name
Definition at line 807 of file commandsProc.cxx.
808 : Command(), _position(position), _name(name)
809{
810 DEBTRACE("CommandRenameNode::CommandRenameNode " << _position << " " << _name);
811 _oldName ="";
812 _newpos="";
813}
References _name, _newpos, _oldName, _position, and DEBTRACE.
◆ dump()
std::string CommandRenameNode::dump ( )
Definition at line 815 of file commandsProc.cxx.
816{
817 string ret ="CommandRenameNode " + _position + " " + _name;
818 return ret;
819}
References _name, and _position.
◆ localExecute()
bool CommandRenameNode::localExecute ( )
Definition at line 821 of file commandsProc.cxx.
822{
823 DEBTRACE("CommandRenameNode::localExecute");
825 Node* node = proc;
826 try
827 {
828 if (_position != proc->getName()) node = proc->getChildByName(_position);
829 _oldName = node->getName();
830 node->setName(_name);
831 if (node == proc)
832 _newpos = _name;
833 else
834 _newpos = proc->getChildName(node);
836 if (snode)
837 snode->recursiveUpdate(RENAME, 0, snode);
838 }
839 catch (Exception& ex)
840 {
841 DEBTRACE("CommandRenameNode::localExecute() : " << ex.what());
843 node = 0;
844 }
845 return (node != 0);
846}
std::string getName() const
Base class for all nodes.
Definition: Node.hxx:70
Definition: Node.hxx:125
Change the name of the node.
Definition: Node.cxx:162
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual void recursiveUpdate(GuiEvent event, int type, Subject *son)
References YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _newpos, _oldName, _position, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::HMI::GuiContext::getProc(), YACS::HMI::SubjectNode::recursiveUpdate(), YACS::HMI::RENAME, setErrorMsg(), and YACS::ENGINE::Node::setName().
◆ localReverse()
bool CommandRenameNode::localReverse ( )
Definition at line 848 of file commandsProc.cxx.
849{
850 DEBTRACE("CommandRenameNode::localReverse");
852 Node* node = proc;
853 try
854 {
855 if (_newpos != proc->getName()) node = proc->getChildByName(_newpos);
856 YASSERT(node->getName() == _name);
857 node->setName(_oldName);
859 if (snode)
860 snode->recursiveUpdate(RENAME, 0, snode);
861 }
862 catch (Exception& ex)
863 {
864 DEBTRACE("CommandRenameNode::localReverse() : " << ex.what());
866 node = 0;
867 }
868 return (node != 0);
869}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
References YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _newpos, _oldName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::HMI::GuiContext::getProc(), YACS::HMI::SubjectNode::recursiveUpdate(), YACS::HMI::RENAME, setErrorMsg(), YACS::ENGINE::Node::setName(), and YASSERT.
◆ _name
std::string YACS::HMI::CommandRenameNode::_name
Definition at line 198 of file commandsProc.hxx.
Referenced by CommandRenameNode(), dump(), localExecute(), and localReverse().
◆ _newpos
std::string YACS::HMI::CommandRenameNode::_newpos
Definition at line 200 of file commandsProc.hxx.
Referenced by CommandRenameNode(), localExecute(), and localReverse().
◆ _oldName
std::string YACS::HMI::CommandRenameNode::_oldName
Definition at line 199 of file commandsProc.hxx.
◆ _position
std::string YACS::HMI::CommandRenameNode::_position
Definition at line 197 of file commandsProc.hxx.
Referenced by CommandRenameNode(), dump(), and localExecute().
