#include <commandsProc.hxx>
| CommandSetContainerProperties (std::string container, std::map< std::string, std::string > properties) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _container |
| std::map< std::string, std::string > | _properties |
| std::map< std::string, std::string > | _oldProp |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 563 of file commandsProc.hxx.
| CommandSetContainerProperties::CommandSetContainerProperties | ( | std::string | container, |
| std::map< std::string, std::string > | properties | ||
Definition at line 3369 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3377 of file commandsProc.cxx.
References _container.
protectedvirtual |
Definition at line 3383 of file commandsProc.cxx.
References _container, YACS::HMI::GuiContext::_lastErrorMessage, _oldProp, _properties, YACS::HMI::ASSOCIATE, YACS::HMI::CONTAINER, YACS::ENGINE::Proc::containerMap, DEBTRACE, testCppPluginInvokation::ex, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::SubjectContainerBase::notifyComponentsChange(), gui.CONNECTOR::ref(), setErrorMsg(), YACS::HMI::UPDATE, YACS::HMI::Subject::update(), and YASSERT.
protectedvirtual |
Definition at line 3411 of file commandsProc.cxx.
References _container, YACS::HMI::GuiContext::_lastErrorMessage, _oldProp, YACS::ENGINE::Proc::containerMap, DEBTRACE, testCppPluginInvokation::ex, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), gui.CONNECTOR::ref(), setErrorMsg(), and YASSERT.
protected |
Definition at line 572 of file commandsProc.hxx.
protected |
Definition at line 574 of file commandsProc.hxx.
Referenced by CommandSetContainerProperties(), localExecute(), and localReverse().
protected |
Definition at line 573 of file commandsProc.hxx.
Referenced by localExecute().
