#include <commandsProc.hxx>
| CommandSetAlgo (std::string optimizer, std::string alglib, std::string symbol) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _optimizer |
| std::string | _alglib |
| std::string | _symbol |
| std::string | _oldAlglib |
| std::string | _oldSymbol |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 484 of file commandsProc.hxx.
| CommandSetAlgo::CommandSetAlgo | ( | std::string | optimizer, |
| std::string | alglib, | ||
| std::string | symbol | ||
Definition at line 2780 of file commandsProc.cxx.
References _alglib, _oldAlglib, _oldSymbol, _optimizer, _symbol, and DEBTRACE.
protectedvirtual |
Definition at line 2788 of file commandsProc.cxx.
References _alglib, _optimizer, and _symbol.
protectedvirtual |
Definition at line 2794 of file commandsProc.cxx.
References _alglib, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldAlglib, _oldSymbol, _optimizer, _symbol, DEBTRACE, YACS::ENGINE::OptimizerLoop::edGetPortForOutPool(), YACS::ENGINE::DynParaLoop::edGetSamplePort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::OptimizerLoop::setAlgorithm(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::UPDATE, YACS::HMI::Subject::update(), YACS::HMI::SubjectNode::update(), and YASSERT.
protectedvirtual |
Definition at line 2825 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldAlglib, _oldSymbol, _optimizer, DEBTRACE, YACS::ENGINE::OptimizerLoop::edGetPortForOutPool(), YACS::ENGINE::DynParaLoop::edGetSamplePort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::OptimizerLoop::setAlgorithm(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::UPDATE, YACS::HMI::Subject::update(), YACS::HMI::SubjectNode::update(), and YASSERT.
protected |
Definition at line 493 of file commandsProc.hxx.
Referenced by CommandSetAlgo(), dump(), and localExecute().
protected |
Definition at line 495 of file commandsProc.hxx.
Referenced by CommandSetAlgo(), localExecute(), and localReverse().
protected |
Definition at line 496 of file commandsProc.hxx.
protected |
Definition at line 492 of file commandsProc.hxx.
Referenced by CommandSetAlgo(), dump(), localExecute(), and localReverse().
protected |
Definition at line 494 of file commandsProc.hxx.
