#include <commandsProc.hxx>
| CommandSetFuncNodeFunctionName (std::string node, std::string funcName) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _nodeName |
| std::string | _funcName |
| std::string | _oldName |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 640 of file commandsProc.hxx.
| CommandSetFuncNodeFunctionName::CommandSetFuncNodeFunctionName | ( | std::string | node, |
| std::string | funcName | ||
Definition at line 3584 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3591 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3597 of file commandsProc.cxx.
References _funcName, YACS::HMI::GuiContext::_lastErrorMessage, _nodeName, _oldName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), and setErrorMsg().
protectedvirtual |
Definition at line 3629 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, _nodeName, _oldName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), and setErrorMsg().
protected |
Definition at line 649 of file commandsProc.hxx.
protected |
Definition at line 648 of file commandsProc.hxx.
protected |
Definition at line 650 of file commandsProc.hxx.
Referenced by CommandSetFuncNodeFunctionName(), localExecute(), and localReverse().
