ConnectionManager.cxx
1// Copyright (C) 2007-2026 CEA, EDF
20#include "ConnectionManager.hxx"
21#include <iostream>
24: _ids()
25, _current_id(0)
26, _mutex()
27{
28}
31{
32}
33
35ConnectionManager::connect(Engines::DSC_ptr uses_component,
36 const char* uses_port_name,
37 Engines::DSC_ptr provides_component,
38 const char* provides_port_name)
39{
40 // We use a mutex for multithreaded applications.
41 std::unique_lock<std::mutex> lock(_mutex);
42 Ports::Port_var p_port = provides_component->get_provides_port(provides_port_name, false);
43 uses_component->connect_uses_port(uses_port_name, p_port);
44 provides_component->connect_provides_port(provides_port_name);
45
46 // Creating a new structure containing connection's infos.
47 connection_infos * infos = new connection_infos();
48 infos->uses_component = Engines::DSC::_duplicate(uses_component);
49 infos->uses_port_name = uses_port_name;
50 infos->provides_component = Engines::DSC::_duplicate(provides_component);
51 infos->provides_port_name = provides_port_name;
52 infos->provides_port = Ports::Port::_duplicate(p_port);
53
54 // Creating a new connection id.
56 _current_id += 1;
57 // Adding the new connection into the map.
58 _ids[rtn_id] = infos;
59
60 return rtn_id;
61}
62
63void
65 Engines::DSC::Message message)
66{
67 std::unique_lock<std::mutex> lock(_mutex);
68 int err=0;
69 // Connection id exist ?
70 ids_it_type ids_it = _ids.find(id);
71 if (ids_it == _ids.end())
72 return;
73
74 // TODO
75 // We need to catch exceptions if one of these disconnect operation fails.
76 // connection_infos * infos = ids[id];
77 connection_infos * infos = ids_it->second;
78 try
79 {
80 infos->provides_component->disconnect_provides_port(infos->provides_port_name.c_str(), message);
81 }
82 catch(CORBA::SystemException& ex)
83 {
84 std::cerr << "Problem in disconnect(CORBA::SystemException) provides port: " << infos->provides_port_name.c_str() << std::endl;
85 err=1;
86 }
87 try
88 {
89 infos->uses_component->disconnect_uses_port(infos->uses_port_name.c_str(),
90 infos->provides_port, message);
91 }
92 catch(CORBA::SystemException& ex)
93 {
94 std::cerr << "Problem in disconnect(CORBA::SystemException) uses port: " << infos->uses_port_name.c_str() << std::endl;
95 err=1;
96 }
97 delete infos;
98 _ids.erase(id);
99
100 if(err)
101 throw Engines::DSC::BadPortReference();
102}
103
104void
106{
107 ids_it_type ids_it = _ids.begin();
108 while(ids_it != _ids.end())
109 {
110 disconnect(ids_it->first, Engines::DSC::RemovingConnection);
111 ids_it = _ids.begin();
112 }
113}
ConnectionManager::connectionId connect(Engines::DSC_ptr uses_component, const char *uses_port_name, Engines::DSC_ptr provides_component, const char *provides_port_name)
void disconnect(ConnectionManager::connectionId id, Engines::DSC::Message message)
std::map< Engines::ConnectionManager::connectionId, connection_infos * >::iterator ids_it_type
