YACS::ENGINE::CORBAComponent Class Reference
Class for CORBA component instance. More...
#include <CORBAComponent.hxx>
Inheritance diagram for YACS::ENGINE::CORBAComponent:
Collaboration diagram for YACS::ENGINE::CORBAComponent:
 CORBAComponent (const std::string &name)
 CORBAComponent constructor. More...
 CORBAComponent (const CORBAComponent &other)
 CORBAComponent copy constructor. More...
virtual ~CORBAComponent ()
virtual void load (Task *askingNode)
 Load the component. More...
virtual void unload (Task *askingNode)
 Unload the component. More...
virtual bool isLoaded (Task *askingNode) const
 Is the component instance already loaded ? More...
virtual ServiceNode * createNode (const std::string &name)
 Create a ServiceNode with this component instance and no input or output port. More...
virtual ComponentInstance * clone () const
 Clone the component instance. More...
virtual ComponentInstance * cloneAlways () const
virtual std::string getFileRepr () const
 For dump in file. More...
virtual CORBA::Object_ptr getCompoPtr ()
virtual std::string getKind () const
 Return the component kind. More...
virtual std::string getKindForNode () const
- Public Member Functions inherited from YACS::ENGINE::ComponentInstance
 ComponentInstance (const std::string &name)
 ComponentInstance (const ComponentInstance &other)
const std::string & getCompoName () const
const std::string & getInstanceName () const
virtual void setAnonymous (bool anon)
virtual bool isAnonymous ()
int getNumId () const
virtual bool setContainer (Container *cont)
Container * getContainer () const
virtual void load (Task *askingNode)=0
 Load the component instance. More...
virtual void unload (Task *askingNode)=0
 Unload the component instance. More...
virtual bool isLoaded (Task *askingNode) const =0
 Indicate if the component instance is loaded (true) or not. More...
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
bool isAttachedOnCloning () const
virtual ServiceNode * createNode (const std::string &name)=0
virtual ComponentInstance * clone () const =0
virtual ComponentInstance * cloneAlways () const =0
- Public Member Functions inherited from YACS::ENGINE::PropertyInterface
virtual ~PropertyInterface ()
 Get a property value given its name. More...
std::map< std::string, std::string > getProperties () const
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] ="CORBA"
- Static Public Attributes inherited from YACS::ENGINE::ComponentInstance
static const char KIND [] =""
CORBA::Object_var _objComponent
- Protected Attributes inherited from YACS::ENGINE::ComponentInstance
std::string _compoName
 WARNING : _compoName identify only the component type. More...
std::string _instanceName
 WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each other. More...
int _numId
Container * _container
bool _isAttachedOnCloning
bool _anonymous
- Protected Attributes inherited from YACS::ENGINE::PropertyInterface
unsigned int _cnt
- Protected Member Functions inherited from YACS::ENGINE::ComponentInstance
virtual ~ComponentInstance ()
 RefCounter ()
virtual ~RefCounter ()
- Static Protected Attributes inherited from YACS::ENGINE::ComponentInstance
static const char NULL_FILE_REPR [] ="No repr specified for ComponentInstance"
static int _total = 0
Definition at line 36 of file CORBAComponent.hxx.
◆ CORBAComponent() [1/2]
CORBAComponent::CORBAComponent ( const std::string &  name)
Definition at line 44 of file CORBAComponent.cxx.
44 : ComponentInstance(name)
45{
46 _objComponent=CORBA::Object::_nil();
47}
ComponentInstance(const std::string &name)
References _objComponent.
Referenced by cloneAlways().
◆ CORBAComponent() [2/2]
CORBAComponent::CORBAComponent ( const CORBAComponent &  other)
Definition at line 50 of file CORBAComponent.cxx.
50 :ComponentInstance(other)
51{
52 _objComponent=CORBA::Object::_nil();
53}
◆ ~CORBAComponent()
CORBAComponent::~CORBAComponent ( )
Definition at line 55 of file CORBAComponent.cxx.
56{
57#ifdef REFCNT
58 DEBTRACE( "+++++++++++++++++" << getName() << " +++++++++++++++++" );
59 if(_objComponent != CORBA::Object::_nil())
60 {
61 std::cerr << "CORBAComponent::destructor:refcount: " <<_objComponent->_PR_getobj()->pd_refCount << std::endl;
62 }
63#endif
64}
References _objComponent, and DEBTRACE.
◆ clone()
ComponentInstance * CORBAComponent::clone ( ) const
Implements YACS::ENGINE::ComponentInstance.
Definition at line 180 of file CORBAComponent.cxx.
181{
182 //no real need to clone a CORBA Component : there is no component instance loading
183 incrRef();
184 return (ComponentInstance*)this;
185 //return new CORBAComponent(*this);
186}
References YACS::ENGINE::RefCounter::incrRef().
◆ cloneAlways()
ComponentInstance * CORBAComponent::cloneAlways ( ) const
Definition at line 188 of file CORBAComponent.cxx.
189{
190 return new CORBAComponent(*this);
191}
CORBAComponent(const std::string &name)
References CORBAComponent().
◆ createNode()
ServiceNode * CORBAComponent::createNode ( const std::string &  name)
a new CORBANode node
Definition at line 172 of file CORBAComponent.cxx.
173{
174 CORBANode* node= new CORBANode(name);
175 node->setComponent(this);
176 return node;
177}
Class for CORBA Service Node.
Definition: CORBANode.hxx:45
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ServiceNode::setComponent().
◆ getCompoPtr()
CORBA::Object_ptr CORBAComponent::getCompoPtr ( )
Definition at line 83 of file CORBAComponent.cxx.
84{
85#ifdef REFCNT
86 std::cerr << "CORBAComponent::getCompoPtr:refCount: " <<_objComponent->_PR_getobj()->pd_refCount << std::endl;
87#endif
88 return CORBA::Object::_duplicate(_objComponent);
89}
◆ getFileRepr()
std::string CORBAComponent::getFileRepr ( ) const
For dump in file.
Reimplemented from YACS::ENGINE::ComponentInstance.
Definition at line 193 of file CORBAComponent.cxx.
194{
195 ostringstream stream;
196 stream << "<ref>" << getCompoName() << "</ref>";
197 return stream.str();
198}
References YACS::ENGINE::ComponentInstance::getCompoName().
◆ getKind()
std::string CORBAComponent::getKind ( ) const
A runtime can provide several implementations of a component instance. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode is they have the same kind.
Definition at line 66 of file CORBAComponent.cxx.
67{
68 return KIND;
69}
References KIND.
◆ getKindForNode()
std::string CORBAComponent::getKindForNode ( ) const
Definition at line 71 of file CORBAComponent.cxx.
72{
73 return KIND;
74}
References KIND.
◆ isLoaded()
bool CORBAComponent::isLoaded ( Task *  askingNode) const
Definition at line 92 of file CORBAComponent.cxx.
93{
94 if(CORBA::is_nil(_objComponent))
95 return false;
96 else
97 return true;
98}
◆ load()
void CORBAComponent::load ( Task *  askingNode)
Load the component.
Definition at line 101 of file CORBAComponent.cxx.
102{
103 DEBTRACE( "CORBAComponent::load" );
104 try
105 {
106 DEBTRACE( "+++++++++++++++++" << getCompoName() << " +++++++++++++++++" );
108#ifdef REFCNT
109 std::cerr << "CORBAComponent::load:refCount: " <<_objComponent->_PR_getobj()->pd_refCount << std::endl;
110#endif
111 }
112 catch(CORBA::COMM_FAILURE& ex)
113 {
114 cerr << "Caught system exception COMM_FAILURE -- unable to contact the "
115 << "object." << endl;
116 throw Exception("Execution problem");
117 }
118 catch(CORBA::SystemException& ex)
119 {
120 cerr << "Caught a CORBA::SystemException." ;
121 CORBA::Any tmp;
122 tmp <<= ex;
123 CORBA::TypeCode_var tc = tmp.type();
124 const char *p = tc->name();
125 if ( *p != '\0' )
126 cerr <<p;
127 else
128 cerr << tc->id();
129 cerr << endl;
130 throw Exception("Execution problem");
131 }
132 catch(CORBA::Exception& ex)
133 {
134 cerr << "Caught CORBA::Exception. " ;
135 CORBA::Any tmp;
136 tmp <<= ex;
137 CORBA::TypeCode_var tc = tmp.type();
138 const char *p = tc->name();
139 if ( *p != '\0' )
140 cerr <<p;
141 else
142 cerr << tc->id();
143 cerr << endl;
144 throw Exception("Execution problem");
145 }
146 catch(omniORB::fatalException& fe)
147 {
148 cerr << "Caught omniORB::fatalException:" << endl;
149 cerr << " file: " << fe.file() << endl;
150 cerr << " line: " << fe.line() << endl;
151 cerr << " mesg: " << fe.errmsg() << endl;
152 throw Exception("Execution problem");
153 }
154 catch(...)
155 {
156 cerr << "Caught unknown exception." << endl;
157 throw Exception("Execution problem");
158 }
159 if( CORBA::is_nil(_objComponent) )
160 {
161 cerr << "Can't get reference to object (or it was nil)." << endl;
162 throw Exception("Execution problem");
163 }
164 //TODO: if IOR is valid but the component does not exist, it works (bad)
165}
CORBA::Object_var getFromNS(const char *entry) const
Proc * p
Definition: driver.cxx:216
References _objComponent, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::RuntimeSALOME::getFromNS(), YACS::ENGINE::getSALOMERuntime(), and p.
◆ unload()
void CORBAComponent::unload ( Task *  askingNode)
Definition at line 77 of file CORBAComponent.cxx.
78{
79 //Not implemented
80 std::cerr << "CORBAComponent::unload : not implemented " << std::endl;
81}
◆ _objComponent
CORBA::Object_var YACS::ENGINE::CORBAComponent::_objComponent
Definition at line 55 of file CORBAComponent.hxx.
Referenced by CORBAComponent(), getCompoPtr(), isLoaded(), load(), and ~CORBAComponent().
◆ KIND
const char CORBAComponent::KIND ="CORBA"
