YACS::ENGINE::SalomeProc Class Reference
#include <SalomeProc.hxx>
Inheritance diagram for YACS::ENGINE::SalomeProc:
Collaboration diagram for YACS::ENGINE::SalomeProc:
 SalomeProc (const std::string &name)
virtual ~SalomeProc ()
virtual TypeCode * createInterfaceTc (const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
 Create an object reference TypeCode. More...
virtual TypeCode * createStructTc (const std::string &id, const std::string &name)
virtual void saveSchema (std::string xmlSchemaFile)
 Save Proc in XML schema file. More...
 Initialise the proc. More...
- Public Member Functions inherited from YACS::ENGINE::Proc
virtual ~Proc ()
virtual TypeCode * createType (const std::string &name, const std::string &kind)
virtual TypeCode * createSequenceTc (const std::string &id, const std::string &name, TypeCode *content)
 Create a sequence TypeCode. More...
virtual TypeCode * getTypeCode (const std::string &name)
virtual void setTypeCode (const std::string &name, TypeCode *t)
virtual Container * createContainer (const std::string &name, const std::string &kind="")
 Create a new Container and store it in containerMap. More...
virtual ComponentInstance * createComponentInstance (const std::string &componame, const std::string &name="", const std::string &kind="")
 Create a new ComponentInstance and add it into componentInstanceMap. More...
virtual void addComponentInstance (ComponentInstance *inst, const std::string &name="", bool resetCtr=false)
 Add a ComponentInstance into componentInstanceMap. More...
virtual void removeComponentInstance (ComponentInstance *inst)
 Remove a componentInstance from the componentInstanceMap. More...
virtual void removeContainer (Container *cont)
 Remove a container from the containerMap. More...
virtual Proc * getProc ()
 Return the proc (this) More...
virtual void updateContainersAndComponents ()
YACS::StatesForNode getNodeState (int numId)
std::string getNodeProgress (int numId)
int getGlobalProgressPercent ()
std::string getInPortValue (int nodeNumId, std::string portName)
std::string setInPortValue (std::string nodeName, std::string portName, std::string value)
std::string getOutPortValue (int nodeNumId, std::string portName)
std::string getNodeErrorDetails (int nodeNumId)
std::string getNodeErrorReport (int nodeNumId)
std::string getNodeContainerLog (int nodeNumId)
std::string getXMLState (int numId)
std::list< int > getNumIds ()
std::list< std::string > getIds ()
virtual Logger * getLogger (const std::string &name)
virtual bool getEdition ()
virtual void setEdition (bool edition)
virtual void modified ()
 Sets Proc in modified state and update state if in edition mode. More...
virtual void saveSchema (const std::string &xmlSchemaFile)
virtual void saveState (const std::string &xmlStateFile)
 Save Proc state in XML state file. More...
- Public Member Functions inherited from YACS::ENGINE::Bloc
 Bloc (const Bloc &other, ComposedNode *father, bool editionOnly)
 Bloc (const std::string &name)
 Create a Bloc node with a given name. More...
virtual ~Bloc ()
bool isFinished ()
 Indicate if the bloc execution is finished. More...
int getNumberOfCFLinks () const
void init (bool start=true)
 Initialize the bloc. More...
 Collect all nodes that are ready to execute. More...
void exUpdateState ()
 Update the bloc state. More...
bool edAddChild (Node *DISOWNnode)
 Add a child node to the bloc. More...
void edRemoveChild (Node *node)
std::list< Node * > getChildren () const
std::list< Node * > edGetDirectDescendants () const
std::vector< std::list< Node * > > splitIntoIndependantGraph () const
Node * getChildByShortName (const std::string &name) const
template<bool direction>
void findAllPathsStartingFrom (Node *start, std::list< std::vector< Node * > > &vec, std::map< Node *, std::set< Node * > > &accelStr) const
void findAllNodesStartingFrom (Node *start, std::set< Node * > &result, std::map< Node *, std::set< Node * > > &accelStr, LinkInfo &info) const
void removeRecursivelyRedundantCL ()
void fitToPlayGround (const PlayGround *pg)
void propagePlayGround (const PlayGround *pg)
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual bool edAddChild (Node *DISOWNnode)
virtual void edRemoveChild (Node *node)
 Remove a child node. More...
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
int getNumId ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
- Public Types inherited from YACS::ENGINE::Proc
typedef std::map< std::string, Logger * > LoggerMap
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
- Public Attributes inherited from YACS::ENGINE::Proc
std::map< std::string, Node * > nodeMap
std::map< std::string, ServiceNode * > serviceMap
std::map< std::string, InlineNode * > inlineMap
std::map< std::string, TypeCode * > typeMap
std::map< std::string, Container * > containerMap
std::map< std::string, ComponentInstance * > componentInstanceMap
std::vector< std::string > names
LoggerMap _loggers
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Protected Member Functions inherited from YACS::ENGINE::Proc
void removeContainers ()
- Protected Member Functions inherited from YACS::ENGINE::Bloc
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
bool areAllSubNodesFinished () const
bool areAllSubNodesDone () const
void checkNoCyclePassingThrough (Node *node)
std::vector< std::pair< OutGate *, InGate * > > getSetOfInternalCFLinks () const
YACS::Event updateStateOnFinishedEventFrom (Node *node)
YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Notify this bloc that a node has failed. More...
void initComputation () const
void performCFComputationsOnlyOneLevel (LinkInfo &info) const
void performCFComputations (LinkInfo &info) const
void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
bool areLinked (Node *start, Node *end, bool fw) const
 Check if two nodes are linked. More...
bool arePossiblyRunnableAtSameTime (Node *start, Node *end) const
 Check if two nodes can run in parallel. More...
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 Check control flow links. More...
void seekOkAndUseless1 (std::vector< Node * > &okAndUseless1, std::set< Node * > &allNodes) const
void seekUseless2 (std::vector< Node * > &useless2, std::set< Node * > &allNodes) const
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
- Static Protected Member Functions inherited from YACS::ENGINE::Bloc
static void verdictForOkAndUseless1 (const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::vector< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
static void verdictForCollapses (const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::set< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
- Protected Attributes inherited from YACS::ENGINE::Proc
bool _edition
int _compoinstctr
- Protected Attributes inherited from YACS::ENGINE::Bloc
std::list< Node * > _setOfNode
std::map< Node *, std::set< Node * > > * _fwLinks
 For internal calculations. More...
std::map< Node *, std::set< Node * > > * _bwLinks
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Definition at line 36 of file SalomeProc.hxx.
◆ SalomeProc()
SalomeProc::SalomeProc ( const std::string &  name)
Definition at line 32 of file SalomeProc.cxx.
32 :Proc(name)
33{
34 // create default container with some default properties
35 Container* cont=createContainer("DefaultContainer");
36 cont->setProperty("name", "localhost");
37 cont->setProperty("container_name","FactoryServer");
38 cont->decrRef();
39}
virtual void setProperty(const std::string &name, const std::string &value)=0
virtual Container * createContainer(const std::string &name, const std::string &kind="")
Definition: Proc.cxx:506
Proc(const std::string &name)
Definition: Proc.cxx:48
References YACS::ENGINE::Proc::createContainer(), YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::Container::setProperty().
◆ ~SalomeProc()
SalomeProc::~SalomeProc ( )
Definition at line 57 of file SalomeProc.cxx.
58{
59}
◆ createInterfaceTc()
TypeCode * SalomeProc::createInterfaceTc ( const std::string &  id,
const std::string &  name,
idthe TypeCode repository id
namethe TypeCode name
ltca liste of object reference TypeCode to use as base types for this type
the created TypeCode
Reimplemented from YACS::ENGINE::Proc.
Definition at line 41 of file SalomeProc.cxx.
43{
44 std::string myName;
45 if(id == "") myName = "IDL:" + name + ":1.0";
46 else myName = id;
47 return Proc::createInterfaceTc(myName,name,ltc);
48}
virtual TypeCode * createInterfaceTc(const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
Definition: Proc.cxx:132
References YACS::ENGINE::Proc::createInterfaceTc().
◆ createStructTc()
TypeCode * SalomeProc::createStructTc ( const std::string &  id,
Definition at line 49 of file SalomeProc.cxx.
50{
51 std::string myName;
52 if(id == "") myName = "IDL:" + name + ":1.0";
53 else myName = id;
54 return Proc::createStructTc(myName,name);
55}
virtual TypeCode * createStructTc(const std::string &id, const std::string &name)
Definition: Proc.cxx:161
References YACS::ENGINE::Proc::createStructTc().
◆ init()
void SalomeProc::init ( bool  start = true)
Reimplemented from YACS::ENGINE::Bloc.
Definition at line 74 of file SalomeProc.cxx.
75{
76 //initialise Python module salome with the study id given by value
77 std::string cmd="import salome;salome.salome_init()";
78 PyGILState_STATE gstate = PyGILState_Ensure(); // acquire the Global Interpreter Lock
79 PyRun_SimpleString(cmd.c_str());
80 PyGILState_Release(gstate); // Release the Global Interpreter Lock
81 Proc::init(start);
82}
void init(bool start=true)
Definition: Bloc.cxx:95
References YACS::ENGINE::Bloc::init().
◆ saveSchema()
void SalomeProc::saveSchema ( std::string  xmlSchemaFile)
xmlSchemaFilethe file name
Definition at line 65 of file SalomeProc.cxx.
66{
68 vss.openFileSchema(xmlSchemaFile);
69 accept(&vss);
70 vss.closeFileSchema();
71}
virtual void accept(Visitor *visitor)
Definition: Proc.cxx:199
References YACS::ENGINE::Proc::accept(), YACS::ENGINE::VisitorSaveSchema::closeFileSchema(), and YACS::ENGINE::VisitorSaveSchema::openFileSchema().
◆ typeName()
virtual std::string YACS::ENGINE::SalomeProc::typeName ( )
Definition at line 44 of file SalomeProc.hxx.
44{return "YACS__ENGINE__SalomeProc";}
