YACS::ENGINE::VisitorSaveSalomeSchema Class Reference
#include <VisitorSaveSalomeSchema.hxx>
Inheritance diagram for YACS::ENGINE::VisitorSaveSalomeSchema:
Collaboration diagram for YACS::ENGINE::VisitorSaveSalomeSchema:
 VisitorSaveSalomeSchema (ComposedNode *root)
virtual ~VisitorSaveSalomeSchema ()
virtual void visitPresetNode (DataNode *node)
virtual void visitOutNode (DataNode *node)
virtual void visitStudyInNode (DataNode *node)
virtual void visitStudyOutNode (DataNode *node)
- Public Member Functions inherited from YACS::ENGINE::VisitorSaveSchema
 VisitorSaveSchema (ComposedNode *root)
virtual ~VisitorSaveSchema ()
void openFileSchema (std::string xmlDump)
void closeFileSchema ()
virtual void visitBloc (Bloc *node)
virtual void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node) override
void visitForEachLoopDyn (ForEachLoopDyn *node) override
virtual void visitOptimizerLoop (OptimizerLoop *node)
virtual void visitDynParaLoop (DynParaLoop *node)
virtual void visitForLoop (ForLoop *node)
virtual void visitInlineNode (InlineNode *node)
virtual void visitInlineFuncNode (InlineFuncNode *node)
virtual void visitLoop (Loop *node)
virtual void visitProc (Proc *node)
virtual void visitServiceNode (ServiceNode *node)
virtual void visitServerNode (ServerNode *node)
virtual void visitServiceInlineNode (ServiceInlineNode *node)
virtual void visitSwitch (Switch *node)
virtual void visitWhileLoop (WhileLoop *node)
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
virtual void writeDataNodeParameters (DataNode *node)
virtual void writeStudyInNodeParameters (DataNode *node)
virtual void writeOutNodeParameters (DataNode *node)
virtual void writeStudyOutNodeParameters (DataNode *node)
- Protected Member Functions inherited from YACS::ENGINE::VisitorSaveSchema
virtual void writeProperties (Node *node)
virtual void dumpTypeCode (TypeCode *type, std::set< std::string > &typeNames, std::map< std::string, TypeCode * > &typeMap, int depth)
virtual void writeTypeCodes (Proc *proc)
virtual void writeContainers (Proc *proc)
virtual void writeComponentInstances (Proc *proc)
virtual void writeInputPorts (Node *node)
virtual void writeInputDataStreamPorts (Node *node)
virtual void writeOutputPorts (Node *node)
virtual void writeOutputDataStreamPorts (Node *node)
virtual void writeControls (ComposedNode *node)
virtual void writeSimpleDataLinks (ComposedNode *node)
virtual void writeSimpleStreamLinks (ComposedNode *node)
virtual void writeParameters (Proc *proc)
virtual void writeParametersNode (ComposedNode *proc, Node *node)
virtual void beginCase (Node *node)
virtual void endCase (Node *node)
std::set< Node * > getAllNodes (ComposedNode *node)
int depthNode (Node *node)
std::string indent (int val)
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
- Protected Attributes inherited from YACS::ENGINE::VisitorSaveSchema
std::ofstream _out
std::map< int, std::string > _nodeStateName
std::map< std::string, Container * > _containerMap
std::map< ComponentInstance *, std::string > _componentInstanceMap
ComposedNode * _root
std::multimap< int, DataLinkInfo > _mapOfDLtoCreate
std::multimap< int, StreamLinkInfo > _mapOfSLtoCreate
Definition at line 30 of file VisitorSaveSalomeSchema.hxx.
◆ VisitorSaveSalomeSchema()
VisitorSaveSalomeSchema::VisitorSaveSalomeSchema ( ComposedNode *  root)
Definition at line 42 of file VisitorSaveSalomeSchema.cxx.
43 : VisitorSaveSchema(root)
44{
45}
◆ ~VisitorSaveSalomeSchema()
VisitorSaveSalomeSchema::~VisitorSaveSalomeSchema ( )
Definition at line 47 of file VisitorSaveSalomeSchema.cxx.
48{
49}
◆ visitOutNode()
void VisitorSaveSalomeSchema::visitOutNode ( DataNode *  node)
Reimplemented from YACS::ENGINE::VisitorSaveSchema.
Definition at line 70 of file VisitorSaveSalomeSchema.cxx.
71{
72 DEBTRACE("START visitOutNode " << _root->getChildName(node));
73 beginCase(node);
74 int depth = depthNode(node);
75 _out << indent(depth) << "<outnode name=\"" << node->getName() << "\"";
76 string ref = node->getRef();
77 if (!ref.empty()) _out << " ref=\"" << ref << "\"";
78 if (node->getState() == YACS::DISABLED)
79 _out << " state=\"disabled\">" << endl;
80 else
81 _out << ">" << endl;
83 writeProperties(node);
84 _out << indent(depth) << "</outnode>" << endl;
85 endCase(node);
86 DEBTRACE("END visitOutNode " << _root->getChildName(node));
87}
virtual std::string getRef()
Definition: DataNode.cxx:39
YACS::StatesForNode getState() const
Definition: Node.hxx:125
virtual void writeOutNodeParameters(DataNode *node)
virtual void endCase(Node *node)
virtual void writeProperties(Node *node)
virtual void beginCase(Node *node)
@ DISABLED
Definition: define.hxx:50
Definition: CONNECTOR.py:120
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::_root, YACS::ENGINE::VisitorSaveSchema::beginCase(), DEBTRACE, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::DISABLED, YACS::ENGINE::VisitorSaveSchema::endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::DataNode::getRef(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::VisitorSaveSchema::indent(), gui.CONNECTOR::ref(), writeOutNodeParameters(), and YACS::ENGINE::VisitorSaveSchema::writeProperties().
◆ visitPresetNode()
void VisitorSaveSalomeSchema::visitPresetNode ( DataNode *  node)
Definition at line 51 of file VisitorSaveSalomeSchema.cxx.
52{
53 DEBTRACE("START visitPresetNode " << _root->getChildName(node));
54 beginCase(node);
55 int depth = depthNode(node);
56 _out << indent(depth) << "<datanode name=\"" << node->getName() << "\"";
57 string ref = node->getRef();
58 if (!ref.empty()) _out << " ref=\"" << ref << "\"";
59 if (node->getState() == YACS::DISABLED)
60 _out << " state=\"disabled\">" << endl;
61 else
62 _out << ">" << endl;
64 writeProperties(node);
65 _out << indent(depth) << "</datanode>" << endl;
66 endCase(node);
67 DEBTRACE("END visitPresetNode " << _root->getChildName(node));
68}
virtual void writeDataNodeParameters(DataNode *node)
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::_root, YACS::ENGINE::VisitorSaveSchema::beginCase(), DEBTRACE, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::DISABLED, YACS::ENGINE::VisitorSaveSchema::endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::DataNode::getRef(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::VisitorSaveSchema::indent(), gui.CONNECTOR::ref(), writeDataNodeParameters(), and YACS::ENGINE::VisitorSaveSchema::writeProperties().
◆ visitStudyInNode()
void VisitorSaveSalomeSchema::visitStudyInNode ( DataNode *  node)
Definition at line 89 of file VisitorSaveSalomeSchema.cxx.
90{
91 DEBTRACE("START visitStudyInNode " << _root->getChildName(node));
92 beginCase(node);
93 int depth = depthNode(node);
94 _out << indent(depth) << "<datanode name=\"" << node->getName() << "\" kind=\"study\"";
95 string ref = node->getRef();
96 if (!ref.empty()) _out << " ref=\"" << ref << "\"";
97 if (node->getState() == YACS::DISABLED)
98 _out << " state=\"disabled\">" << endl;
99 else
100 _out << ">" << endl;
102 writeProperties(node);
103 _out << indent(depth) << "</datanode>" << endl;
104 endCase(node);
105 DEBTRACE("END visitStudyInNode " << _root->getChildName(node));
106}
virtual void writeStudyInNodeParameters(DataNode *node)
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::_root, YACS::ENGINE::VisitorSaveSchema::beginCase(), DEBTRACE, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::DISABLED, YACS::ENGINE::VisitorSaveSchema::endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::DataNode::getRef(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::VisitorSaveSchema::indent(), gui.CONNECTOR::ref(), YACS::ENGINE::VisitorSaveSchema::writeProperties(), and writeStudyInNodeParameters().
◆ visitStudyOutNode()
void VisitorSaveSalomeSchema::visitStudyOutNode ( DataNode *  node)
Definition at line 108 of file VisitorSaveSalomeSchema.cxx.
109{
110 DEBTRACE("START visitStudyOutNode " << _root->getChildName(node));
111 beginCase(node);
112 int depth = depthNode(node);
113 _out << indent(depth) << "<outnode name=\"" << node->getName() << "\" kind=\"study\"";
114 string ref = node->getRef();
115 if (!ref.empty()) _out << " ref=\"" << ref << "\"";
116 if (node->getState() == YACS::DISABLED)
117 _out << " state=\"disabled\">" << endl;
118 else
119 _out << ">" << endl;
121 writeProperties(node);
122 _out << indent(depth) << "</outnode>" << endl;
123 endCase(node);
124 DEBTRACE("END visitStudyOutNode " << _root->getChildName(node));
125}
virtual void writeStudyOutNodeParameters(DataNode *node)
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::_root, YACS::ENGINE::VisitorSaveSchema::beginCase(), DEBTRACE, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::DISABLED, YACS::ENGINE::VisitorSaveSchema::endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::DataNode::getRef(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::VisitorSaveSchema::indent(), gui.CONNECTOR::ref(), YACS::ENGINE::VisitorSaveSchema::writeProperties(), and writeStudyOutNodeParameters().
◆ writeDataNodeParameters()
void VisitorSaveSalomeSchema::writeDataNodeParameters ( DataNode *  node)
Definition at line 127 of file VisitorSaveSalomeSchema.cxx.
128{
129 int depth = depthNode(node)+1;
130 list<OutputPort*> listOfOutputPorts = node->getSetOfOutputPort();
131 for (list<OutputPort*>::iterator it = listOfOutputPorts.begin(); it != listOfOutputPorts.end(); ++it)
132 {
133 _out << indent(depth) << "<parameter name=\"" << (*it)->getName() << "\" type=\""
134 << (*it)->edGetType()->name() << "\">" << endl;
135 OutputPresetPort *outp = dynamic_cast<OutputPresetPort*>(*it);
136 YASSERT(outp);
137 _out << indent(depth+1) << outp->getData();
138 _out << indent(depth) << "</parameter>" << endl;
139 }
140}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::list< OutputPort * > getSetOfOutputPort() const
Class for PRESET output Ports.
Definition: PresetPorts.hxx:33
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::ENGINE::OutputPresetPort::getData(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::ENGINE::VisitorSaveSchema::indent(), and YASSERT.
Referenced by visitPresetNode().
◆ writeOutNodeParameters()
void VisitorSaveSalomeSchema::writeOutNodeParameters ( DataNode *  node)
Definition at line 156 of file VisitorSaveSalomeSchema.cxx.
157{
158 int depth = depthNode(node)+1;
159 list<InputPort*> listOfInputPorts = node->getSetOfInputPort();
160 for (list<InputPort*>::iterator it = listOfInputPorts.begin(); it != listOfInputPorts.end(); ++it)
161 {
162 _out << indent(depth) << "<parameter name=\"" << (*it)->getName() << "\" type=\""
163 << (*it)->edGetType()->name() << "\"/>" << endl;
164 }
165}
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::ENGINE::ElementaryNode::getSetOfInputPort(), and YACS::ENGINE::VisitorSaveSchema::indent().
Referenced by visitOutNode().
◆ writeStudyInNodeParameters()
void VisitorSaveSalomeSchema::writeStudyInNodeParameters ( DataNode *  node)
Definition at line 142 of file VisitorSaveSalomeSchema.cxx.
143{
144 int depth = depthNode(node)+1;
145 list<OutputPort*> listOfOutputPorts = node->getSetOfOutputPort();
146 for (list<OutputPort*>::iterator it = listOfOutputPorts.begin(); it != listOfOutputPorts.end(); ++it)
147 {
148 _out << indent(depth) << "<parameter name=\"" << (*it)->getName() << "\" type=\""
149 << (*it)->edGetType()->name() << "\" ref=\"";
150 OutputStudyPort *outp = dynamic_cast<OutputStudyPort*>(*it);
151 YASSERT(outp);
152 _out << outp->getData() << "\"/>" << endl;
153 }
154}
Class for Study output Ports.
Definition: StudyPorts.hxx:33
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::ENGINE::OutputStudyPort::getData(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::ENGINE::VisitorSaveSchema::indent(), and YASSERT.
Referenced by visitStudyInNode().
◆ writeStudyOutNodeParameters()
void VisitorSaveSalomeSchema::writeStudyOutNodeParameters ( DataNode *  node)
Definition at line 167 of file VisitorSaveSalomeSchema.cxx.
168{
169 int depth = depthNode(node)+1;
170 list<InputPort*> listOfInputPorts = node->getSetOfInputPort();
171 for (list<InputPort*>::iterator it = listOfInputPorts.begin(); it != listOfInputPorts.end(); ++it)
172 {
173 _out << indent(depth) << "<parameter name=\"" << (*it)->getName() << "\" type=\""
174 << (*it)->edGetType()->name() << "\" ref=\"";
175 InputStudyPort *inp = dynamic_cast<InputStudyPort*>(*it);
176 YASSERT(inp);
177 _out << inp->getData() << "\"/>" << endl;
178 }
179}
Class for Study input Ports.
Definition: StudyPorts.hxx:51
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::ENGINE::VisitorSaveSchema::depthNode(), YACS::ENGINE::InputStudyPort::getData(), YACS::ENGINE::ElementaryNode::getSetOfInputPort(), YACS::ENGINE::VisitorSaveSchema::indent(), and YASSERT.
Referenced by visitStudyOutNode().
