YACS::ENGINE::VisitorSaveSchema Class Reference
Base class for all visitors that save a schema. More...
#include <VisitorSaveSchema.hxx>
Inheritance diagram for YACS::ENGINE::VisitorSaveSchema:
Collaboration diagram for YACS::ENGINE::VisitorSaveSchema:
 VisitorSaveSchema (ComposedNode *root)
virtual ~VisitorSaveSchema ()
void openFileSchema (std::string xmlDump)
void closeFileSchema ()
virtual void visitBloc (Bloc *node)
virtual void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node) override
void visitForEachLoopDyn (ForEachLoopDyn *node) override
virtual void visitOptimizerLoop (OptimizerLoop *node)
virtual void visitDynParaLoop (DynParaLoop *node)
virtual void visitForLoop (ForLoop *node)
virtual void visitInlineNode (InlineNode *node)
virtual void visitInlineFuncNode (InlineFuncNode *node)
virtual void visitLoop (Loop *node)
virtual void visitProc (Proc *node)
virtual void visitServiceNode (ServiceNode *node)
virtual void visitServerNode (ServerNode *node)
virtual void visitServiceInlineNode (ServiceInlineNode *node)
virtual void visitSwitch (Switch *node)
virtual void visitWhileLoop (WhileLoop *node)
virtual void visitPresetNode (DataNode *node)
virtual void visitOutNode (DataNode *node)
virtual void visitStudyInNode (DataNode *node)
virtual void visitStudyOutNode (DataNode *node)
- Public Member Functions inherited from YACS::ENGINE::Visitor
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
virtual void writeProperties (Node *node)
virtual void dumpTypeCode (TypeCode *type, std::set< std::string > &typeNames, std::map< std::string, TypeCode * > &typeMap, int depth)
virtual void writeTypeCodes (Proc *proc)
virtual void writeContainers (Proc *proc)
virtual void writeComponentInstances (Proc *proc)
virtual void writeInputPorts (Node *node)
virtual void writeInputDataStreamPorts (Node *node)
virtual void writeOutputPorts (Node *node)
virtual void writeOutputDataStreamPorts (Node *node)
virtual void writeControls (ComposedNode *node)
virtual void writeSimpleDataLinks (ComposedNode *node)
virtual void writeSimpleStreamLinks (ComposedNode *node)
virtual void writeParameters (Proc *proc)
virtual void writeParametersNode (ComposedNode *proc, Node *node)
virtual void beginCase (Node *node)
virtual void endCase (Node *node)
std::set< Node * > getAllNodes (ComposedNode *node)
int depthNode (Node *node)
std::string indent (int val)
- Protected Member Functions inherited from YACS::ENGINE::Visitor
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
std::ofstream _out
std::map< int, std::string > _nodeStateName
std::map< std::string, Container * > _containerMap
std::map< ComponentInstance *, std::string > _componentInstanceMap
ComposedNode * _root
std::multimap< int, DataLinkInfo > _mapOfDLtoCreate
std::multimap< int, StreamLinkInfo > _mapOfSLtoCreate
- Protected Attributes inherited from YACS::ENGINE::Visitor
Can be specialized in runtime.
Definition at line 59 of file VisitorSaveSchema.hxx.
◆ VisitorSaveSchema()
VisitorSaveSchema::VisitorSaveSchema ( ComposedNode *  root)
Definition at line 61 of file VisitorSaveSchema.cxx.
61 : _root(root), Visitor(root)
62{
63}
Visitor(ComposedNode *root)
Definition: Visitor.cxx:28
◆ ~VisitorSaveSchema()
VisitorSaveSchema::~VisitorSaveSchema ( )
Definition at line 65 of file VisitorSaveSchema.cxx.
66{
67 if (_out)
68 {
69 _out << "</proc>" << endl;
70 _out.close();
71 }
72}
References _out.
◆ beginCase()
void VisitorSaveSchema::beginCase ( Node *  node)
Definition at line 1137 of file VisitorSaveSchema.cxx.
1138{
1139 Switch *myFather =dynamic_cast<Switch*>(node->getFather());
1140 if (myFather)
1141 {
1142 int depth = depthNode(node) -1;
1143 int myCase = myFather->getRankOfNode(node);
1144 if (myCase == Switch::ID_FOR_DEFAULT_NODE)
1145 _out << indent(depth) << "<default>" << endl;
1146 else
1147 _out << indent(depth) << "<case id=\"" << myCase << "\">" << endl;
1148 }
1149}
ComposedNode * getFather() const
Definition: Node.hxx:127
Definition: Switch.hxx:85
static const int ID_FOR_DEFAULT_NODE
Definition: Switch.hxx:91
int getRankOfNode(Node *node) const
Definition: Switch.cxx:752
References _out, depthNode(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::Switch::getRankOfNode(), YACS::ENGINE::Switch::ID_FOR_DEFAULT_NODE, and indent().
Referenced by visitBloc(), visitElementaryNode(), visitForEachLoop(), visitForEachLoopDyn(), visitForLoop(), visitInlineFuncNode(), visitInlineNode(), visitLoop(), visitOptimizerLoop(), YACS::ENGINE::VisitorSaveSalomeSchema::visitOutNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitPresetNode(), visitProc(), visitServerNode(), visitServiceInlineNode(), visitServiceNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyInNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyOutNode(), visitSwitch(), and visitWhileLoop().
◆ closeFileSchema()
◆ depthNode()
int VisitorSaveSchema::depthNode ( Node *  node)
Definition at line 1165 of file VisitorSaveSchema.cxx.
1166{
1167 int depth = 0;
1168 ComposedNode *father = node->getFather();
1169 while (father)
1170 {
1171 depth +=1;
1172 if (dynamic_cast<Switch*>(father)) depth +=1;
1173 if (father->getNumId() == _root->getNumId()) break;
1174 father = father->getFather();
1175 }
1176 return depth;
1177}
int getNumId()
return node instance identifiant, unique for each node instance
Definition: Node.cxx:643
References _root, YACS::ENGINE::Node::getFather(), and YACS::ENGINE::Node::getNumId().
Referenced by beginCase(), endCase(), visitBloc(), visitDynParaLoop(), visitForEachLoop(), visitForEachLoopDyn(), visitForLoop(), visitInlineFuncNode(), visitInlineNode(), visitLoop(), visitOptimizerLoop(), YACS::ENGINE::VisitorSaveSalomeSchema::visitOutNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitPresetNode(), visitServerNode(), visitServiceInlineNode(), visitServiceNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyInNode(), YACS::ENGINE::VisitorSaveSalomeSchema::visitStudyOutNode(), visitSwitch(), visitWhileLoop(), writeComponentInstances(), writeContainers(), writeControls(), YACS::ENGINE::VisitorSaveSalomeSchema::writeDataNodeParameters(), writeInputDataStreamPorts(), writeInputPorts(), YACS::ENGINE::VisitorSaveSalomeSchema::writeOutNodeParameters(), writeOutputDataStreamPorts(), writeOutputPorts(), writeProperties(), writeSimpleDataLinks(), writeSimpleStreamLinks(), YACS::ENGINE::VisitorSaveSalomeSchema::writeStudyInNodeParameters(), YACS::ENGINE::VisitorSaveSalomeSchema::writeStudyOutNodeParameters(), and writeTypeCodes().
◆ dumpTypeCode()
void VisitorSaveSchema::dumpTypeCode ( TypeCode *  type,
std::set< std::string > &  typeNames,
std::map< std::string, TypeCode * > &  typeMap,
int  depth
Definition at line 563 of file VisitorSaveSchema.cxx.
564{
565 DynType kind = type->kind();
566 string typeName = type->name();
567 if (typeNames.find(typeName) != typeNames.end())
568 return;
569 switch(kind)
570 {
572 {
573 typeNames.insert(typeName);
574 _out << indent(depth) << "<type name=\"" << typeName << "\" kind=\"double\"/>" << endl;
575 break;
576 }
578 {
579 typeNames.insert(typeName);
580 _out << indent(depth) << "<type name=\"" << typeName << "\" kind=\"int\"/>" << endl;
581 break;
582 }
584 {
585 typeNames.insert(typeName);
586 _out << indent(depth) << "<type name=\"" << typeName << "\" kind=\"string\"/>" << endl;
587 break;
588 }
590 {
591 typeNames.insert(typeName);
592 _out << indent(depth) << "<type name=\"" << typeName << "\" kind=\"bool\"/>" << endl;
593 break;
594 }
596 {
597 TypeCodeObjref *objref = dynamic_cast<TypeCodeObjref*>(type);
598 std::list<TypeCodeObjref*> listOfBases = getListOfBases(objref);
599 //try to dump base classes
600 for(std::list<TypeCodeObjref*>::iterator il=listOfBases.begin(); il != listOfBases.end(); ++il)
601 {
602 if (typeNames.find((*il)->name()) == typeNames.end())
603 dumpTypeCode((*il),typeNames,typeMap,depth);
604 }
605 //effective dump
606 typeNames.insert(typeName);
607 _out << indent(depth) << "<objref name=\"" << typeName << "\" id=\""
608 << objref->id() << "\"";
609 if (listOfBases.empty())
610 _out << "/>" << endl;
611 else
612 {
613 _out << ">" << endl;
614 for(std::list<TypeCodeObjref*>::iterator il=listOfBases.begin(); il != listOfBases.end(); ++il)
615 {
616 _out << indent(depth+1) << "<base>";
617 _out << (*il)->name();
618 _out << "</base>" << endl;
619 }
620 _out << indent(depth) << "</objref>" << endl;
621 }
622 break;
623 }
625 {
626 TypeCode* content = (TypeCode*)type->contentType();
627 if (typeNames.find(content->name()) == typeNames.end())
628 {
629 //content type not dumped
630 dumpTypeCode(content,typeNames,typeMap,depth);
631 }
632 typeNames.insert(typeName);
633 _out << indent(depth) << "<sequence name=\"" << typeName << "\" content=\""
634 << content->name() << "\"/>" << endl;
635 break;
636 }
638 {
639 TypeCode* content = (TypeCode*)type->contentType();
640 if (typeNames.find(content->name()) == typeNames.end())
641 {
642 //content type not dumped
643 dumpTypeCode(content,typeNames,typeMap,depth);
644 }
645 typeNames.insert(typeName);
646 _out << indent(depth) << "<array name=\"" << typeName << "\" content=\""
647 << content->name() << "\"/>" << endl;
648 break;
649 }
651 {
652 TypeCodeStruct* tcStruct = dynamic_cast<TypeCodeStruct*>(type);
653 YASSERT(tcStruct);
654 int mbCnt = tcStruct->memberCount();
655 for (int i=0; i<mbCnt; i++)
656 {
657 TypeCode* member = tcStruct->memberType(i);
658 if (typeNames.find(member->name()) == typeNames.end())
659 {
660 //content type not dumped
661 dumpTypeCode(member,typeNames,typeMap,depth);
662 }
663 }
664 typeNames.insert(typeName);
665 _out << indent(depth) << "<struct name=\"" << typeName << "\">" << endl;
666 for (int i=0; i<mbCnt; i++)
667 {
668 TypeCode* member = tcStruct->memberType(i);
669 _out << indent(depth+1) << "<member name=\"" <<tcStruct->memberName(i) << "\" type=\"" << member->name() << "\"/>" << endl;
670 }
671 _out << indent(depth) << "</struct>" << endl;
672 break;
673 }
674 default:
675 {
676 string what = "wrong TypeCode: ";
677 throw Exception(what);
678 }
679 }
680}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Class for reference objects.
Definition: TypeCode.hxx:126
const char * id() const
Definition: TypeCode.cxx:327
Class for struct type.
Definition: TypeCode.hxx:228
const char * memberName(int index) const
Definition: TypeCode.cxx:819
TypeCode * memberType(int index) const
Definition: TypeCode.cxx:831
Definition: TypeCode.hxx:68
Definition: TypeCode.cxx:72
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:174
DynType kind() const
Definition: TypeCode.cxx:47
virtual void dumpTypeCode(TypeCode *type, std::set< std::string > &typeNames, std::map< std::string, TypeCode * > &typeMap, int depth)
std::list< TypeCodeObjref * > getListOfBases(TypeCodeObjref *objref)
Definition: Visitor.cxx:47
References _out, YACS::ENGINE::Array, YACS::ENGINE::Bool, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::Double, dumpTypeCode(), YACS::ENGINE::Visitor::getListOfBases(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::TypeCodeObjref::id(), indent(), YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::TypeCodeStruct::memberCount(), YACS::ENGINE::TypeCodeStruct::memberName(), YACS::ENGINE::TypeCodeStruct::memberType(), YACS::ENGINE::TypeCode::name(), YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, YACS::ENGINE::Struct, and YASSERT.
Referenced by dumpTypeCode(), and writeTypeCodes().
◆ endCase()
◆ getAllNodes()
std::set< Node * > VisitorSaveSchema::getAllNodes ( ComposedNode *  node)
Definition at line 1077 of file VisitorSaveSchema.cxx.
1078{
1079 set<Node *> ret;
1080 list< Node *> setOfNode = node->edGetDirectDescendants();
1081 for(list<Node *>::iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
1082 {
1083 if ( dynamic_cast<ComposedNode*> (*iter) )
1084 {
1085 set<Node *> myCurrentSet = getAllNodes(dynamic_cast<ComposedNode*> (*iter));
1086 ret.insert(myCurrentSet.begin(),myCurrentSet.end());
1087 ret.insert(*iter);
1088 }
1089 else
1090 {
1091 list<ElementaryNode *> myCurrentSet=(*iter)->getRecursiveConstituents();
1092 ret.insert(myCurrentSet.begin(),myCurrentSet.end());
1093 ret.insert(*iter);
1094 }
1095 }
1096 return ret;
1097}
virtual std::list< Node * > edGetDirectDescendants() const =0
std::set< Node * > getAllNodes(ComposedNode *node)
References YACS::ENGINE::ComposedNode::edGetDirectDescendants(), and getAllNodes().
Referenced by getAllNodes(), writeParameters(), and YACS::HMI::VisitorSaveGuiSchema::writePresentation().
◆ indent()
◆ openFileSchema()
void VisitorSaveSchema::openFileSchema ( std::string  xmlDump)
Definition at line 74 of file VisitorSaveSchema.cxx.
75{
76 _out.open(xmlSchema.c_str(), ios::out);
77 if (!_out)
78 {
79 string what = "Impossible to open file for writing: " + xmlSchema;
80 throw Exception(what);
81 }
82 _out << "<?xml version='1.0' encoding='iso-8859-1' ?>" << endl;
83}
References _out.
Referenced by main(), YACS::HMI::GenericGui::onExportSchema(), YACS::HMI::GenericGui::onExportSchemaAs(), YACS::HMI::GenericGui::onRunLoadedSchema(), YACS::ENGINE::SchemaSave::save(), YACS::ENGINE::Proc::saveSchema(), YACS::ENGINE::SalomeProc::saveSchema(), and YACS::ENGINE::VisitorSaveSalomeSchemaUnsafe().
◆ visitBloc()
void VisitorSaveSchema::visitBloc ( Bloc *  node)
Implements YACS::ENGINE::Visitor.
Definition at line 92 of file VisitorSaveSchema.cxx.
93{
94 DEBTRACE("START visitBloc " << _root->getChildName(node));
95 beginCase(node);
96 int depth = depthNode(node);
97 _out << indent(depth) << "<bloc name=\"" << node->getName() << "\"";
98 if (node->getState() == YACS::DISABLED)
99 _out << " state=\"disabled\">" << endl;
100 else
101 _out << ">" << endl;
102 writeProperties(node);
103 node->ComposedNode::accept(this);
104 writeControls(node);
107 _out << indent(depth) << "</bloc>" << endl;
108 endCase(node);
109 DEBTRACE("END visitBloc " << _root->getChildName(node));
110}
std::string getName() const
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
virtual void writeSimpleDataLinks(ComposedNode *node)
virtual void endCase(Node *node)
virtual void writeProperties(Node *node)
virtual void writeSimpleStreamLinks(ComposedNode *node)
virtual void writeControls(ComposedNode *node)
virtual void beginCase(Node *node)
@ DISABLED
Definition: define.hxx:50
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getState(), indent(), writeControls(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitDynParaLoop()
void VisitorSaveSchema::visitDynParaLoop ( DynParaLoop *  node)
Definition at line 200 of file VisitorSaveSchema.cxx.
201{
202 DEBTRACE("START visitDynParaLoop " << _root->getChildName(node));
203 int depth = depthNode(node);
204 if (node->getInitNode() != NULL)
205 {
206 _out << indent(depth+1) << "<initnode>" << endl;
207 node->getInitNode()->accept(this);
208 _out << indent(depth+1) << "</initnode>" << endl;
209 }
210 if (node->getExecNode() != NULL)
211 {
212 node->getExecNode()->accept(this);
213 }
214 if (node->getFinalizeNode() != NULL)
215 {
216 _out << indent(depth+1) << "<finalizenode>" << endl;
217 node->getFinalizeNode()->accept(this);
218 _out << indent(depth+1) << "</finalizenode>" << endl;
219 }
220 DEBTRACE("END visitDynParaLoop " << _root->getChildName(node));
221}
virtual void accept(Visitor *visitor)=0
References _out, _root, YACS::ENGINE::Node::accept(), DEBTRACE, depthNode(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::DynParaLoop::getExecNode(), YACS::ENGINE::DynParaLoop::getFinalizeNode(), YACS::ENGINE::DynParaLoop::getInitNode(), and indent().
◆ visitElementaryNode()
void VisitorSaveSchema::visitElementaryNode ( ElementaryNode *  node)
Definition at line 112 of file VisitorSaveSchema.cxx.
113{
114 DEBTRACE("START visitElementaryNode " << _root->getChildName(node));
115 beginCase(node);
116 writeProperties(node);
117 writeInputPorts(node);
119 writeOutputPorts(node);
121 endCase(node);
122 DEBTRACE("END visitElementaryNode " << _root->getChildName(node));
123}
virtual void writeInputDataStreamPorts(Node *node)
virtual void writeOutputDataStreamPorts(Node *node)
virtual void writeInputPorts(Node *node)
virtual void writeOutputPorts(Node *node)
References _root, beginCase(), DEBTRACE, endCase(), YACS::ENGINE::ComposedNode::getChildName(), writeInputDataStreamPorts(), writeInputPorts(), writeOutputDataStreamPorts(), writeOutputPorts(), and writeProperties().
◆ visitForEachLoop()
void VisitorSaveSchema::visitForEachLoop ( ForEachLoop *  node)
overridevirtual
Definition at line 125 of file VisitorSaveSchema.cxx.
126{
127 DEBTRACE("START visitForEachLoop " << _root->getChildName(node));
128 beginCase(node);
129 int depth = depthNode(node);
130
131 _out << indent(depth) << "<foreach name=\"" << node->getName() << "\"";
132 AnyInputPort *nbranch = static_cast<AnyInputPort*>(node->edGetNbOfBranchesPort());
133 if (node->getState() == YACS::DISABLED)
134 _out << " state=\"disabled\"";
135 if (!nbranch->isEmpty())
136 _out << " nbranch=\"" << nbranch->getIntValue() << "\"";
137 _out << " loopWeight=\"" << node->getWeight()->getSimpleLoopWeight() << "\"";
138 if (node->edGetSamplePort())
139 _out << " type=\"" << node->edGetSamplePort()->edGetType()->name() << "\"";
140 _out << ">" << endl;
141
142 writeProperties(node);
143 node->DynParaLoop::accept(this);
146 _out << indent(depth) << "</foreach>" << endl;
147 endCase(node);
148 DEBTRACE("END visitForEachLoop " << _root->getChildName(node));
149}
double getSimpleLoopWeight() const
TypeCode * edGetType() const
Definition: DataPort.hxx:53
InputPort * edGetNbOfBranchesPort()
Definition: DynParaLoop.hxx:83
OutputPort * edGetSamplePort()
Definition: DynParaLoop.hxx:90
ComplexWeight * getWeight()
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, YACS::ENGINE::DynParaLoop::edGetNbOfBranchesPort(), YACS::ENGINE::DynParaLoop::edGetSamplePort(), YACS::ENGINE::DataPort::edGetType(), endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ComplexWeight::getSimpleLoopWeight(), YACS::ENGINE::Node::getState(), YACS::ENGINE::DynParaLoop::getWeight(), indent(), YACS::ENGINE::AnyInputPort::isEmpty(), YACS::ENGINE::TypeCode::name(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitForEachLoopDyn()
void VisitorSaveSchema::visitForEachLoopDyn ( ForEachLoopDyn *  node)
overridevirtual
Definition at line 151 of file VisitorSaveSchema.cxx.
152{
153 DEBTRACE("START visitForEachLoopDyn " << _root->getChildName(node));
154 beginCase(node);
155 int depth = depthNode(node);
156
157 _out << indent(depth) << "<foreachdyn name=\"" << node->getName() << "\"";
158 if (node->getState() == YACS::DISABLED)
159 _out << " state=\"disabled\"";
160 _out << " loopWeight=\"" << node->getWeight()->getSimpleLoopWeight() << "\"";
161 if (node->edGetSamplePort())
162 _out << " type=\"" << node->edGetSamplePort()->edGetType()->name() << "\"";
163 _out << ">" << endl;
164
165 writeProperties(node);
166 node->DynParaLoop::accept(this);
169 _out << indent(depth) << "</foreachdyn>" << endl;
170 endCase(node);
171 DEBTRACE("END visitForEachLoopDyn " << _root->getChildName(node));
172}
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, YACS::ENGINE::DynParaLoop::edGetSamplePort(), YACS::ENGINE::DataPort::edGetType(), endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ComplexWeight::getSimpleLoopWeight(), YACS::ENGINE::Node::getState(), YACS::ENGINE::DynParaLoop::getWeight(), indent(), YACS::ENGINE::TypeCode::name(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitForLoop()
void VisitorSaveSchema::visitForLoop ( ForLoop *  node)
Definition at line 223 of file VisitorSaveSchema.cxx.
224{
225 DEBTRACE("START visitForLoop " << _root->getChildName(node));
226 beginCase(node);
227 int depth = depthNode(node);
228 AnyInputPort *nsteps = static_cast<AnyInputPort*>(node->edGetNbOfTimesInputPort());
229 _out << indent(depth) << "<forloop name=\"" << node->getName() << "\"";
230 if (node->getState() == YACS::DISABLED)
231 _out << " state=\"disabled\"";
232 if (nsteps->isEmpty())
233 _out << ">" << endl;
234 else
235 _out << " nsteps=\"" << nsteps->getIntValue() << "\">" << endl;
236 writeProperties(node);
237 node->ComposedNode::accept(this);
240 _out << indent(depth) << "</forloop>" << endl;
241 endCase(node);
242 DEBTRACE("END visitForLoop " << _root->getChildName(node));
243}
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, YACS::ENGINE::ForLoop::edGetNbOfTimesInputPort(), endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getState(), indent(), YACS::ENGINE::AnyInputPort::isEmpty(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitInlineFuncNode()
void VisitorSaveSchema::visitInlineFuncNode ( InlineFuncNode *  node)
Definition at line 285 of file VisitorSaveSchema.cxx.
286{
287 DEBTRACE("START visitInlineFuncNode " << _root->getChildName(node));
288 beginCase(node);
289 int depth = depthNode(node);
291 _out << indent(depth) << "<inline name=\"" << node->getName() << "\"";
292 else
293 {
294 _out << indent(depth) << "<remote name=\"" << node->getName() << "\"";
295 _out << " elementaryWeight=\"" << node->getWeight()->getElementaryWeight() << "\"";
296 }
297 if (node->getState() == YACS::DISABLED)
298 _out << " state=\"disabled\">" << endl;
299 else
300 _out << ">" << endl;
301 _out << indent(depth+1) << "<function name=\"" << node->getFname() << "\">" << endl;
302 _out << indent(depth+2) << "<code><![CDATA[";
303 _out << node->getScript();
304 _out << "]]></code>" << endl;
305 _out << indent(depth+1) << "</function>" << endl;
306
307 //add load container if node is remote
308 Container *cont = node->getContainer();
309 if (cont)
310 _out << indent(depth+1) << "<load container=\"" << cont->getName() << "\"/>" << endl;
311
312 writeProperties(node);
313 writeInputPorts(node);
315 writeOutputPorts(node);
317
319 _out << indent(depth) << "</inline>" << endl;
320 else
321 _out << indent(depth) << "</remote>" << endl;
322
323 endCase(node);
324 DEBTRACE("END visitInlineFuncNode " << _root->getChildName(node));
325}
double getElementaryWeight() const
virtual std::string getName() const
Definition: Container.hxx:81
virtual std::string getFname()
Definition: InlineNode.hxx:101
static const char LOCAL_STR[]
Definition: InlineNode.hxx:72
virtual Container * getContainer()
Definition: InlineNode.cxx:100
virtual std::string getExecutionMode()
Definition: InlineNode.cxx:95
virtual std::string getScript()
Definition: InlineNode.hxx:51
Definition: Node.hxx:125
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::InlineNode::getContainer(), YACS::ENGINE::ComplexWeight::getElementaryWeight(), YACS::ENGINE::InlineNode::getExecutionMode(), YACS::ENGINE::InlineFuncNode::getFname(), YACS::ENGINE::Container::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::InlineNode::getScript(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::ElementaryNode::getWeight(), indent(), YACS::ENGINE::InlineNode::LOCAL_STR, writeInputDataStreamPorts(), writeInputPorts(), writeOutputDataStreamPorts(), writeOutputPorts(), and writeProperties().
◆ visitInlineNode()
void VisitorSaveSchema::visitInlineNode ( InlineNode *  node)
Definition at line 245 of file VisitorSaveSchema.cxx.
246{
247 DEBTRACE("START visitInlineNode " << _root->getChildName(node));
248 beginCase(node);
249 int depth = depthNode(node);
251 _out << indent(depth) << "<inline name=\"" << node->getName() << "\"";
252 else
253 {
254 _out << indent(depth) << "<remote name=\"" << node->getName() << "\"";
255 _out << " elementaryWeight=\"" << node->getWeight()->getElementaryWeight() << "\"";
256 }
257 if (node->getState() == YACS::DISABLED)
258 _out << " state=\"disabled\">" << endl;
259 else
260 _out << ">" << endl;
261 _out << indent(depth+1) << "<script><code><![CDATA[";
262 _out << node->getScript();
263 _out << "]]></code></script>" << endl;
264
265 //add load container if node is remote
266 Container *cont = node->getContainer();
267 if (cont)
268 _out << indent(depth+1) << "<load container=\"" << cont->getName() << "\"/>" << endl;
269
270 writeProperties(node);
271 writeInputPorts(node);
273 writeOutputPorts(node);
275
277 _out << indent(depth) << "</inline>" << endl;
278 else
279 _out << indent(depth) << "</remote>" << endl;
280
281 endCase(node);
282 DEBTRACE("END visitInlineNode " << _root->getChildName(node));
283}
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::InlineNode::getContainer(), YACS::ENGINE::ComplexWeight::getElementaryWeight(), YACS::ENGINE::InlineNode::getExecutionMode(), YACS::ENGINE::Container::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::InlineNode::getScript(), YACS::ENGINE::ElementaryNode::getState(), YACS::ENGINE::ElementaryNode::getWeight(), indent(), YACS::ENGINE::InlineNode::LOCAL_STR, writeInputDataStreamPorts(), writeInputPorts(), writeOutputDataStreamPorts(), writeOutputPorts(), and writeProperties().
◆ visitLoop()
void VisitorSaveSchema::visitLoop ( Loop *  node)
Definition at line 327 of file VisitorSaveSchema.cxx.
328{
329 DEBTRACE("START visitLoop " << _root->getChildName(node));
330 beginCase(node);
331 int depth = depthNode(node);
332 writeProperties(node);
333 node->ComposedNode::accept(this);
334 writeControls(node);
337 endCase(node);
338 DEBTRACE("END visitLoop " << _root->getChildName(node));
339}
References _root, beginCase(), DEBTRACE, depthNode(), endCase(), YACS::ENGINE::ComposedNode::getChildName(), writeControls(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitOptimizerLoop()
void VisitorSaveSchema::visitOptimizerLoop ( OptimizerLoop *  node)
Definition at line 174 of file VisitorSaveSchema.cxx.
175{
176 DEBTRACE("START visitOptimizerLoop " << _root->getChildName(node));
177 beginCase(node);
178 int depth = depthNode(node);
179
180 _out << indent(depth) << "<optimizer name=\"" << node->getName() << "\"";
181 AnyInputPort *nbranch = static_cast<AnyInputPort*>(node->edGetNbOfBranchesPort());
182 if (node->getState() == YACS::DISABLED)
183 _out << " state=\"disabled\"";
184 if (!nbranch->isEmpty())
185 _out << " nbranch=\"" << nbranch->getIntValue() << "\"";
186 _out << " loopWeight=\"" << node->getWeight()->getSimpleLoopWeight() << "\"";
187 _out << " lib=\"" << node->getAlgLib() << "\"";
188 _out << " entry=\"" << node->getSymbol() << "\"";
189 _out << ">" << endl;
190
191 writeProperties(node);
192 node->DynParaLoop::accept(this);
195 _out << indent(depth) << "</optimizer>" << endl;
196 endCase(node);
197 DEBTRACE("END visitOptimizerLoop " << _root->getChildName(node));
198}
virtual std::string getAlgLib() const
Return the name of the algorithm library.
virtual std::string getSymbol() const
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, YACS::ENGINE::DynParaLoop::edGetNbOfBranchesPort(), endCase(), YACS::ENGINE::OptimizerLoop::getAlgLib(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ComplexWeight::getSimpleLoopWeight(), YACS::ENGINE::Node::getState(), YACS::ENGINE::OptimizerLoop::getSymbol(), YACS::ENGINE::DynParaLoop::getWeight(), indent(), YACS::ENGINE::AnyInputPort::isEmpty(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitOutNode()
void VisitorSaveSchema::visitOutNode ( DataNode *  node)
Reimplemented in YACS::ENGINE::VisitorSaveSalomeSchema.
Definition at line 489 of file VisitorSaveSchema.cxx.
490{
491 DEBTRACE("START visitOutNode " << _root->getChildName(node));
492 DEBTRACE("END visitOutNode " << _root->getChildName(node));
493}
References _root, DEBTRACE, and YACS::ENGINE::ComposedNode::getChildName().
◆ visitPresetNode()
void VisitorSaveSchema::visitPresetNode ( DataNode *  node)
Definition at line 483 of file VisitorSaveSchema.cxx.
484{
485 DEBTRACE("START visitPresetNode " << _root->getChildName(node));
486 DEBTRACE("END visitPresetNode " << _root->getChildName(node));
487}
◆ visitProc()
void VisitorSaveSchema::visitProc ( Proc *  node)
Definition at line 341 of file VisitorSaveSchema.cxx.
342{
343 DEBTRACE("START visitProc " << node->getName());
344 _out << "<proc name=\""<< node->getName() << "\">" << endl;
345 beginCase(node);
346 writeProperties(node);
347 writeTypeCodes(node);
348 writeContainers(node);
350 node->ComposedNode::accept(this);
351 writeControls(node);
354 writeParameters(node);
355 endCase(node);
356 DEBTRACE("END visitProc " << node->getName());
357}
virtual void writeParameters(Proc *proc)
virtual void writeTypeCodes(Proc *proc)
virtual void writeContainers(Proc *proc)
virtual void writeComponentInstances(Proc *proc)
References _out, beginCase(), DEBTRACE, endCase(), YACS::ENGINE::ComposedNode::getName(), writeComponentInstances(), writeContainers(), writeControls(), writeParameters(), writeProperties(), writeSimpleDataLinks(), writeSimpleStreamLinks(), and writeTypeCodes().
◆ visitServerNode()
void VisitorSaveSchema::visitServerNode ( ServerNode *  node)
Definition at line 418 of file VisitorSaveSchema.cxx.
419{
420 DEBTRACE("START visitServerNode " << _root->getChildName(node));
421 beginCase(node);
422 int depth = depthNode(node);
423 _out << indent(depth) << "<server name=\"" << node->getName() << "\"";
424 if (node->getState() == YACS::DISABLED)
425 _out << " state=\"disabled\">" << endl;
426 else
427 _out << ">" << endl;
428 Container *cont = node->getContainer();
429 map<string, Container*>::const_iterator it;
430 for (it = _containerMap.begin(); it != _containerMap.end(); ++it)
431 {
432 if (it->second == cont) break;
433 }
434 if (it != _containerMap.end())
435 _out << indent(depth+1) << "<loadcontainer>" << it->first << "</loadcontainer>" << endl;
436 /*else
437 {
438 _out << indent(depth+1) << "<node>" << _contnentInstanceMap[cont] << "</node>" << endl;
439 }*/
440 _out << indent(depth+1) << "<method>" << node->getFname() << "</method>" << endl;
441 _out << indent(depth+2) << "<script><code><![CDATA[";
442 _out << node->getScript();
443 _out << "]]></code></script>" << endl;
444 //_out << indent(depth+1) << "</function>" << endl;
445 writeProperties(node);
446 writeInputPorts(node);
448 writeOutputPorts(node);
450 _out << indent(depth) << "</server>" << endl;
451 endCase(node);
452 DEBTRACE("END visitServerNode " << _root->getChildName(node));
453}
References _containerMap, _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::InlineNode::getContainer(), YACS::ENGINE::InlineFuncNode::getFname(), YACS::ENGINE::Node::getName(), YACS::ENGINE::InlineNode::getScript(), YACS::ENGINE::ElementaryNode::getState(), indent(), writeInputDataStreamPorts(), writeInputPorts(), writeOutputDataStreamPorts(), writeOutputPorts(), and writeProperties().
◆ visitServiceInlineNode()
void VisitorSaveSchema::visitServiceInlineNode ( ServiceInlineNode *  node)
Definition at line 455 of file VisitorSaveSchema.cxx.
456{
457 DEBTRACE("START visitServiceInlineNode " << _root->getChildName(node));
458 beginCase(node);
459 int depth = depthNode(node);
460 _out << indent(depth) << "<serviceInline name=\"" << node->getName() << "\"";
461 if (node->getState() == YACS::DISABLED)
462 _out << " state=\"disabled\">" << endl;
463 else
464 _out << ">" << endl;
465
466 ComponentInstance *compo = node->getComponent();
467 if (compo)
468 _out << indent(depth+1) << compo->getFileRepr() << endl;
469
470 _out << indent(depth+1) << "<function name=\"" << node->getMethod() << "\">" << endl;
471 _out << indent(depth+2) << "<code><![CDATA[";
472 _out << node->getScript();
473 _out << "]]></code>" << endl;
474 _out << indent(depth+1) << "</function>" << endl;
475 writeProperties(node);
476 writeInputPorts(node);
477 writeOutputPorts(node);
478 _out << indent(depth) << "</serviceInline>" << endl;
479 endCase(node);
480 DEBTRACE("END visitServiceInlineNode " << _root->getChildName(node));
481}
virtual std::string getFileRepr() const
For dump in file.
virtual std::string getMethod()
Definition: ServiceNode.hxx:51
virtual ComponentInstance * getComponent()
Return the associated component instance.
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getFileRepr(), YACS::ENGINE::ServiceNode::getMethod(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ServiceInlineNode::getScript(), YACS::ENGINE::ElementaryNode::getState(), indent(), writeInputPorts(), writeOutputPorts(), and writeProperties().
◆ visitServiceNode()
void VisitorSaveSchema::visitServiceNode ( ServiceNode *  node)
Definition at line 359 of file VisitorSaveSchema.cxx.
360{
361 DEBTRACE("START visitServiceNode " << _root->getChildName(node));
362 beginCase(node);
363 int depth = depthNode(node);
364 _out << indent(depth) << "<service name=\"" << node->getName() << "\"";
365 if (node->getState() == YACS::DISABLED)
366 _out << " state=\"disabled\">" << endl;
367 else
368 _out << ">" << endl;
369 if (node->getKind() == "xmlsh")
370 {
371 _out << indent(depth+1) << "<kind>xmlsh</kind>" << endl;
372 _out << indent(depth+1) << "<ref>" << node->getRef() << "</ref>" << endl;
373 }
374 else
375 {
376 ComponentInstance *compo = node->getComponent();
377 if (compo && !compo->isAnonymous())
378 {
379 _out << indent(depth+1) << "<componentinstance>" << compo->getInstanceName() << "</componentinstance>" << endl;
380 }
381 else if (compo && (_componentInstanceMap.find(compo) == _componentInstanceMap.end()))
382 {
383 _out << indent(depth+1) << compo->getFileRepr() << endl;
385 Container *cont = compo->getContainer();
386 if (cont)
387 {
388 map<string, Container*>::const_iterator it;
389 for (it = _containerMap.begin(); it != _containerMap.end(); ++it)
390 {
391 if (it->second == cont) break;
392 }
393 if (it != _containerMap.end())
394 _out << indent(depth+1) << "<load container=\"" << it->first << "\"/>" << endl;
395 }
396 }
397 else if(compo)
398 {
399 _out << indent(depth+1) << "<node>" << _componentInstanceMap[compo] << "</node>" << endl;
400 }
401 else
402 {
403 _out << indent(depth+1) << "<component>" << "UNKNOWN" << "</component>" << endl;
404 }
405 }
406 _out << indent(depth+1) << "<method>" << node->getMethod() << "</method>" << endl;
407
408 writeProperties(node);
409 writeInputPorts(node);
411 writeOutputPorts(node);
413 _out << indent(depth) << "</service>" << endl;
414 endCase(node);
415 DEBTRACE("END visitServiceNode " << _root->getChildName(node));
416}
const std::string & getInstanceName() const
Return the service node kind.
Definition: ServiceNode.cxx:50
virtual std::string getRef()
References _componentInstanceMap, _containerMap, _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::ENGINE::ComponentInstance::getFileRepr(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::ENGINE::ServiceNode::getKind(), YACS::ENGINE::ServiceNode::getMethod(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ServiceNode::getRef(), YACS::ENGINE::ElementaryNode::getState(), indent(), YACS::ENGINE::ComponentInstance::isAnonymous(), writeInputDataStreamPorts(), writeInputPorts(), writeOutputDataStreamPorts(), writeOutputPorts(), and writeProperties().
◆ visitStudyInNode()
void VisitorSaveSchema::visitStudyInNode ( DataNode *  node)
Definition at line 495 of file VisitorSaveSchema.cxx.
496{
497 DEBTRACE("START visitStudyInNode " << _root->getChildName(node));
498 DEBTRACE("END visitStudyInNode " << _root->getChildName(node));
499}
◆ visitStudyOutNode()
void VisitorSaveSchema::visitStudyOutNode ( DataNode *  node)
Definition at line 501 of file VisitorSaveSchema.cxx.
502{
503 DEBTRACE("START visitStudyOutNode " << _root->getChildName(node));
504 DEBTRACE("END visitStudyOutNode " << _root->getChildName(node));
505}
◆ visitSwitch()
void VisitorSaveSchema::visitSwitch ( Switch *  node)
Definition at line 508 of file VisitorSaveSchema.cxx.
509{
510 DEBTRACE("START visitSwitch " << _root->getChildName(node));
511 beginCase(node);
512 int depth = depthNode(node);
513 AnyInputPort *condition = static_cast<AnyInputPort*>(node->edGetConditionPort());
514 _out << indent(depth) << "<switch name=\"" << node->getName() << "\"";
515 if (node->getState() == YACS::DISABLED)
516 _out << " state=\"disabled\"";
517 if (condition->isEmpty())
518 _out << ">" << endl;
519 else
520 _out << " select=\"" << condition->getIntValue() << "\">" << endl;
521 writeProperties(node);
522 node->ComposedNode::accept(this);
523 writeControls(node);
526 _out << indent(depth) << "</switch>" << endl;
527 endCase(node);
528 DEBTRACE("END visitSwitch " << _root->getChildName(node));
529}
InputPort * edGetConditionPort()
Definition: Switch.hxx:115
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, YACS::ENGINE::Switch::edGetConditionPort(), endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getState(), indent(), YACS::ENGINE::AnyInputPort::isEmpty(), writeControls(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ visitWhileLoop()
void VisitorSaveSchema::visitWhileLoop ( WhileLoop *  node)
Definition at line 531 of file VisitorSaveSchema.cxx.
532{
533 DEBTRACE("START visitWhileLoop " << _root->getChildName(node));
534 beginCase(node);
535 int depth = depthNode(node);
536 _out << indent(depth) << "<while name=\"" << node->getName() << "\"";
537 if (node->getState() == YACS::DISABLED)
538 _out << " state=\"disabled\">" << endl;
539 else
540 _out << ">" << endl;
541 writeProperties(node);
542 node->ComposedNode::accept(this);
545 _out << indent(depth) << "</while>" << endl;
546 endCase(node);
547 DEBTRACE("END visitWhileLoop " << _root->getChildName(node));
548}
References _out, _root, beginCase(), DEBTRACE, depthNode(), YACS::DISABLED, endCase(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getState(), indent(), writeProperties(), writeSimpleDataLinks(), and writeSimpleStreamLinks().
◆ writeComponentInstances()
void VisitorSaveSchema::writeComponentInstances ( Proc *  proc)
Definition at line 697 of file VisitorSaveSchema.cxx.
698{
699 int depth = depthNode(proc)+1;
700 std::map<std::string, ComponentInstance*>::const_iterator it;
701 for (it = proc->componentInstanceMap.begin(); it != proc->componentInstanceMap.end(); it++)
702 {
703 string name = it->first;
704 ComponentInstance* inst=it->second;
705 if(!inst->isAnonymous())
706 {
707 _out << indent(depth) << "<componentinstance name=\"" << inst->getInstanceName() << "\">" << endl;
708 _out << indent(depth+1) << "<component>" << inst->getCompoName() << "</component>" << endl;
709
710 Container *cont = inst->getContainer();
711 if (cont)
712 _out << indent(depth+1) << "<load container=\"" << cont->getName() << "\"/>" << endl;
713
714 std::map<std::string, std::string> properties = inst->getProperties();
715 std::map<std::string, std::string>::const_iterator itm;
716 for(itm = properties.begin(); itm != properties.end(); ++itm)
717 _out << indent(depth+1) << "<property name=\"" << (*itm).first
718 << "\" value=\"" << (*itm).second << "\"/>" << endl;
719
720 _out << indent(depth) << "</componentinstance>" << endl;
721 }
722 }
723}
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
std::map< std::string, std::string > getProperties() const
References _out, YACS::ENGINE::Proc::componentInstanceMap, depthNode(), YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::ENGINE::Container::getName(), YACS::ENGINE::PropertyInterface::getProperties(), indent(), and YACS::ENGINE::ComponentInstance::isAnonymous().
Referenced by visitProc().
◆ writeContainers()
void VisitorSaveSchema::writeContainers ( Proc *  proc)
Definition at line 725 of file VisitorSaveSchema.cxx.
726{
727 int depth = depthNode(proc)+1;
729 map<string, Container*>::const_iterator it;
730 for (it = _containerMap.begin(); it != _containerMap.end(); it++)
731 {
732 string name = it->first;
733 _out << indent(depth) << "<container name=\"" << name << "\">" << endl;
734 _out << indent(depth+1) << "<property name=\"" << Container::KIND_ENTRY << "\" value=\"" << it->second->getKind() << "\"/>" << endl;
735 _out << indent(depth+1) << "<property name=\"" << Container::AOC_ENTRY << "\" value=\"" << (int)it->second->isAttachedOnCloning() << "\"/>" << endl;
736 map<string, string> properties = (it->second)->getProperties();
737 map<string, string>::iterator itm;
738 for(itm = properties.begin(); itm != properties.end(); ++itm)
739 {
740 if((*itm).first==Container::KIND_ENTRY)
741 continue;
742 if((*itm).first==Container::AOC_ENTRY)
743 continue;
745 {
746 _out << indent(depth+1) << "<property name=\"" << (*itm).first << "\" value=\"" << (*itm).second << "\"/>" << endl;
747 }
748 else
749 {
750 _out << indent(depth+1) << "<initializescriptkey><code><![CDATA[" << (*itm).second << "]]></code></initializescriptkey>" << endl;
751 }
752 }
753 _out << indent(depth) << "</container>" << endl;
754 }
755}
static const char KIND_ENTRY[]
Definition: Container.hxx:87
static const char AOC_ENTRY[]
Definition: Container.hxx:88
std::map< std::string, Container * > getContainerMap(Proc *proc)
Definition: Visitor.cxx:42
References _containerMap, _out, YACS::ENGINE::Container::AOC_ENTRY, depthNode(), YACS::ENGINE::Visitor::getContainerMap(), indent(), YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY, and YACS::ENGINE::Container::KIND_ENTRY.
◆ writeControls()
void VisitorSaveSchema::writeControls ( ComposedNode *  node)
Definition at line 824 of file VisitorSaveSchema.cxx.
825{
826 int depth = depthNode(node)+1;
827 list<Node*> setOfChildren = node->edGetDirectDescendants();
828 for (list<Node*>::iterator ic = setOfChildren.begin(); ic != setOfChildren.end(); ++ic)
829 {
830 // --- Control links from direct descendant to nodes inside the bloc
831 list<InGate*> setOfInGates = (*ic)->getOutGate()->edSetInGate();
832 for (list<InGate*>::iterator ig = setOfInGates.begin(); ig != setOfInGates.end(); ++ig)
833 {
834 Node *to = (*ig)->getNode();
835 if (node->isInMyDescendance(to))
836 {
837 Node *from = (*ic);
838 _out << indent(depth) << "<control> <fromnode>" << node->getChildName(from) << "</fromnode> ";
839 _out << "<tonode>" << node->getChildName(to) << "</tonode> </control>" << endl;
840 }
841 }
842 // --- Control links from nodes inside the bloc to direct descendant
843 // avoid links between direct descendants (already done above)
844 list<OutGate*> listOfOutGates = (*ic)->getInGate()->getBackLinks();
845 for (list<OutGate*>::iterator ig = listOfOutGates.begin(); ig != listOfOutGates.end(); ++ig)
846 {
847 Node *from = (*ig)->getNode();
848 if ((node->isInMyDescendance(from)) && (from->getFather()->getNumId() != node->getNumId()))
849 {
850 Node *to = *ic;
851 _out << indent(depth) << "<control> <fromnode>" << node->getChildName(from) << "</fromnode> ";
852 _out << "<tonode>" << node->getChildName(to) << "</tonode> </control>" << endl;
853 }
854 }
855 }
856}
Node * isInMyDescendance(Node *nodeToTest) const
Returns the parent of a node that is the direct child of this node.
Base class for all nodes.
Definition: Node.hxx:70
References _out, depthNode(), YACS::ENGINE::ComposedNode::edGetDirectDescendants(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::Node::getNumId(), indent(), and YACS::ENGINE::ComposedNode::isInMyDescendance().
Referenced by visitBloc(), visitLoop(), visitProc(), and visitSwitch().
◆ writeInputDataStreamPorts()
void VisitorSaveSchema::writeInputDataStreamPorts ( Node *  node)
Definition at line 769 of file VisitorSaveSchema.cxx.
770{
771 int depth = depthNode(node)+1;
772 list<InputDataStreamPort*> listOfInputPorts = node->getSetOfInputDataStreamPort();
773 for (list<InputDataStreamPort*>::iterator it = listOfInputPorts.begin(); it != listOfInputPorts.end(); ++it)
774 {
775 std::map<std::string,std::string> aPropMap = (*it)->getProperties();
776 if ( aPropMap.empty() )
777 _out << indent(depth) << "<instream name=\"" << (*it)->getName() << "\" type=\""
778 << (*it)->edGetType()->name() << "\"/>" << endl;
779 else
780 {
781 _out << indent(depth) << "<instream name=\"" << (*it)->getName() << "\" type=\""
782 << (*it)->edGetType()->name() << "\">" << endl;
783 for (std::map<std::string,std::string>::iterator itP = aPropMap.begin(); itP != aPropMap.end(); itP++)
784 _out << indent(depth+1) << "<property name=\"" << (*itP).first << "\" value=\""
785 << (*itP).second << "\"/>" << endl;
786 _out << indent(depth) << "</instream>" << endl;
787 }
788 }
789}
virtual std::list< InputDataStreamPort * > getSetOfInputDataStreamPort() const =0
References _out, depthNode(), YACS::ENGINE::Node::getSetOfInputDataStreamPort(), and indent().
Referenced by visitElementaryNode(), visitInlineFuncNode(), visitInlineNode(), visitServerNode(), and visitServiceNode().
◆ writeInputPorts()
void VisitorSaveSchema::writeInputPorts ( Node *  node)
Definition at line 758 of file VisitorSaveSchema.cxx.
759{
760 int depth = depthNode(node)+1;
761 list<InputPort*> listOfInputPorts = node->getSetOfInputPort();
762 for (list<InputPort*>::iterator it = listOfInputPorts.begin(); it != listOfInputPorts.end(); ++it)
763 {
764 _out << indent(depth) << "<inport name=\"" << (*it)->getName() << "\" type=\""
765 << (*it)->edGetType()->name() << "\"/>" << endl;
766 }
767}
virtual std::list< InputPort * > getSetOfInputPort() const =0
References _out, depthNode(), YACS::ENGINE::Node::getSetOfInputPort(), and indent().
Referenced by visitElementaryNode(), visitInlineFuncNode(), visitInlineNode(), visitServerNode(), visitServiceInlineNode(), and visitServiceNode().
◆ writeOutputDataStreamPorts()
void VisitorSaveSchema::writeOutputDataStreamPorts ( Node *  node)
Definition at line 802 of file VisitorSaveSchema.cxx.
803{
804 int depth = depthNode(node)+1;
805 list<OutputDataStreamPort*> listOfOutputPorts = node->getSetOfOutputDataStreamPort();
806 for (list<OutputDataStreamPort*>::iterator it = listOfOutputPorts.begin(); it != listOfOutputPorts.end(); ++it)
807 {
808 std::map<std::string,std::string> aPropMap = (*it)->getProperties();
809 if ( aPropMap.empty() )
810 _out << indent(depth) << "<outstream name=\"" << (*it)->getName() << "\" type=\""
811 << (*it)->edGetType()->name() << "\"/>" << endl;
812 else
813 {
814 _out << indent(depth) << "<outstream name=\"" << (*it)->getName() << "\" type=\""
815 << (*it)->edGetType()->name() << "\">" << endl;
816 for (std::map<std::string,std::string>::iterator itP = aPropMap.begin(); itP != aPropMap.end(); itP++)
817 _out << indent(depth+1) << "<property name=\"" << (*itP).first << "\" value=\""
818 << (*itP).second << "\"/>" << endl;
819 _out << indent(depth) << "</outstream>" << endl;
820 }
821 }
822}
virtual std::list< OutputDataStreamPort * > getSetOfOutputDataStreamPort() const =0
References _out, depthNode(), YACS::ENGINE::Node::getSetOfOutputDataStreamPort(), and indent().
◆ writeOutputPorts()
void VisitorSaveSchema::writeOutputPorts ( Node *  node)
Definition at line 791 of file VisitorSaveSchema.cxx.
792{
793 int depth = depthNode(node)+1;
794 list<OutputPort*> listOfOutputPorts = node->getSetOfOutputPort();
795 for (list<OutputPort*>::iterator it = listOfOutputPorts.begin(); it != listOfOutputPorts.end(); ++it)
796 {
797 _out << indent(depth) << "<outport name=\"" << (*it)->getName() << "\" type=\""
798 << (*it)->edGetType()->name() << "\"/>" << endl;
799 }
800}
virtual std::list< OutputPort * > getSetOfOutputPort() const =0
References _out, depthNode(), YACS::ENGINE::Node::getSetOfOutputPort(), and indent().
◆ writeParameters()
void VisitorSaveSchema::writeParameters ( Proc *  proc)
Definition at line 1099 of file VisitorSaveSchema.cxx.
1100{
1101 // set<Node*> nodeSet = proc->getAllRecursiveConstituents();
1102 set<Node*> nodeSet = getAllNodes(proc);
1103 for (set<Node*>::iterator iter = nodeSet.begin(); iter != nodeSet.end(); ++iter)
1104 {
1105 // ElementaryNode *node = dynamic_cast<ElementaryNode*>(*iter);
1106 // if (node)
1107 // writeParametersNode(proc,node);
1108 writeParametersNode(proc,(*iter));
1109 }
1110}
virtual void writeParametersNode(ComposedNode *proc, Node *node)
References getAllNodes(), and writeParametersNode().
◆ writeParametersNode()
void VisitorSaveSchema::writeParametersNode ( ComposedNode *  proc,
Node *  node
Definition at line 1112 of file VisitorSaveSchema.cxx.
1113{
1114 int depth = 1;
1115 list<InputPort *> setOfInputPort = node->getLocalInputPorts();
1116 list<InputPort *>::iterator iter;
1117 for(iter = setOfInputPort.begin(); iter != setOfInputPort.end(); ++iter)
1118 {
1119 if (!(*iter)->isEmpty())
1120 {
1121 _out << indent(depth) << "<parameter>" << endl;
1122 _out << indent(depth+1) << "<tonode>" << proc->getChildName(node) << "</tonode>";
1123 _out << "<toport>" << (*iter)->getName() << "</toport>" <<endl;
1124 try
1125 {
1126 _out << indent(depth+1) << (*iter)->dump();
1127 }
1128 catch (YACS::Exception &e)
1129 {
1130 _out << "<value><error><![CDATA[" << e.what() << "]]></error></value>" << endl;
1131 }
1132 _out << indent(depth) << "</parameter>" << endl;
1133 }
1134 }
1135}
virtual std::list< InputPort * > getLocalInputPorts() const =0
const char * what(void) const noexcept
Definition: Exception.cxx:50
References _out, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getLocalInputPorts(), indent(), and YACS::Exception::what().
Referenced by writeParameters().
◆ writeProperties()
void VisitorSaveSchema::writeProperties ( Node *  node)
Definition at line 551 of file VisitorSaveSchema.cxx.
552{
553 int depth = depthNode(node)+1;
554 map<string,string> properties = getNodeProperties(node);
555 map<string,string>::const_iterator it;
556 for(it = properties.begin(); it != properties.end(); ++it)
557 {
558 _out << indent(depth) << "<property name=\"" << it->first
559 << "\" value=\"" << it->second << "\"/>" << endl;
560 }
561}
std::map< std::string, std::string > getNodeProperties(Node *node)
Definition: Visitor.cxx:32
References _out, depthNode(), YACS::ENGINE::Visitor::getNodeProperties(), and indent().
◆ writeSimpleDataLinks()
void VisitorSaveSchema::writeSimpleDataLinks ( ComposedNode *  node)
Write simple data links from and to direct children of node (grand children already done). First, for all output ports of direct children, write links where the input port is inside the node scope. Keep in memory the links where the input port is outside the node scope. Second, retreive links where the output port is inside the scope, using the links kept in memory and not yet written.
Definition at line 865 of file VisitorSaveSchema.cxx.
866{
867 int depth = depthNode(node)+1;
868 list<Node*> setOfChildren = node->edGetDirectDescendants();
869
870 list<Node*> setOfChildrenPlusSplitters = setOfChildren;
871
872 for (list<Node*>::iterator ic = setOfChildren.begin(); ic != setOfChildren.end(); ++ic)
873 // add "splitter" node of ForEachLoop nodes to the set of children
874 if ( dynamic_cast<ForEachLoopGen*>( *ic ) )
875 {
877 if(find(setOfChildrenPlusSplitters.begin(),setOfChildrenPlusSplitters.end(),nodeToInsert)==setOfChildrenPlusSplitters.end())
878 setOfChildrenPlusSplitters.push_back(nodeToInsert);
879 }
880
881 // --- first pass, write links where the input port is inside the node scope. Keep in memory others.
882
883 for (list<Node*>::iterator ic = setOfChildrenPlusSplitters.begin(); ic != setOfChildrenPlusSplitters.end(); ++ic)
884 {
885 Node* from = *ic;
886 list<OutputPort*> listOP = from->getLocalOutputPorts();
887 for (list<OutputPort*>::iterator io = listOP.begin(); io != listOP.end(); ++io)
888 {
889 OutputPort* anOP = *io;
890 set<InPort*> setIP = anOP->edSetInPort();
891 for (set<InPort*>::iterator iip = setIP.begin(); iip != setIP.end(); ++iip)
892 {
893 InPort *anIP = *iip;
894 Node* to = anIP->getNode();
895 DEBTRACE("from " << from->getName() << " outputPort " << anOP->getName()
896 << " to " << to->getName() << " inputPort " << anIP->getName() );
897 Node* child = node->isInMyDescendance(to);
898 if (child && (child->getNumId() != node->getNumId())
899 && (from->getNumId() != to->getNumId()))
900 {
901 DEBTRACE( "BINGO!" );
902
903 string fromName;
904 if ( dynamic_cast<SplitterNode*>(from) && dynamic_cast<ForEachLoopGen*>(from->getFather()) )
905 fromName = from->getFather()->getName();
906 else
907 fromName = node->getChildName(from);
908
909 string childName;
910 if ( dynamic_cast<SplitterNode*>(to) && dynamic_cast<ForEachLoopGen*>(to->getFather()) )
911 childName = node->getChildName(to->getFather());
912 else
913 childName = node->getChildName(to);
914 _out << indent(depth) << "<datalink control=\"false\">" << endl;
915 _out << indent(depth+1) << "<fromnode>" << fromName << "</fromnode> ";
916 _out << "<fromport>" << anOP->getName() << "</fromport>" << endl;
917 _out << indent(depth+1) << "<tonode>" << childName << "</tonode> ";
918 _out << "<toport>" << anIP->getName() << "</toport>" << endl;
919 _out << indent(depth) << "</datalink>" << endl;
920 }
921 else
922 { // --- store info to create the link later, given the input port
923 DEBTRACE( "For later" );
924 struct DataLinkInfo aLink = { from, to, anOP, anIP, false };
925 _mapOfDLtoCreate.insert(make_pair(anIP->getNumId(), aLink));
926 }
927 }
928 }
929 }
930
931 // --- second pass, retreive links where the output port is inside the scope.
932
933 if (!dynamic_cast<Switch*>(node)) // xml parser does not take into account datalinks in a switch context
934 {
935 std::multimap<int, DataLinkInfo>::iterator pos;
936 for (pos = _mapOfDLtoCreate.begin(); pos != _mapOfDLtoCreate.end(); ++pos)
937 {
938 Node* to = (pos->second).to;
939 Node* child = node->isInMyDescendance(to);
940 if (child && (child->getNumId() != node->getNumId()))
941 {
942 InPort* anIP = (pos->second).inp;
943 int portId = anIP->getNumId();
944 Node* from = (pos->second).from;
945 child = node->isInMyDescendance(from);
946 if (child && (child->getNumId() != node->getNumId()))
947 if((from->getNumId() != to->getNumId()) || dynamic_cast<Loop*>(node))
948 {
949 string childName = node->getChildName(from);
950 OutPort *anOP = (pos->second).outp;
951 (pos->second).toDelete = true;
952 _out << indent(depth) << "<datalink control=\"false\">" << endl;
953 _out << indent(depth+1) << "<fromnode>" << childName << "</fromnode> ";
954 _out << "<fromport>" << anOP->getName() << "</fromport>" << endl;
955 _out << indent(depth+1) << "<tonode>" << node->getChildName(to) << "</tonode> ";
956 _out << "<toport>" << anIP->getName() << "</toport>" << endl;
957 _out << indent(depth) << "</datalink>" << endl;
958 }
959 }
960 }
961
962 // --- remove the link written from the multimap
963
964 for (pos = _mapOfDLtoCreate.begin(); pos != _mapOfDLtoCreate.end();)
965 {
966 if ((pos->second).toDelete)
967 _mapOfDLtoCreate.erase(pos++); // be careful not to saw off the branch on which you are sitting!
968 else
969 ++pos;
970 }
971 }
972}
Definition: DataPort.hxx:55
static const char NAME_OF_SPLITTERNODE[]
Base class for loop node.
Definition: Loop.hxx:147
virtual std::list< OutputPort * > getLocalOutputPorts() const =0
virtual Node * getChildByName(const std::string &name) const =0
std::set< InPort * > edSetInPort() const
Definition: OutputPort.cxx:239
Node * getNode() const
Definition: Port.hxx:46
int getNumId() const
Definition: Port.hxx:48
References _mapOfDLtoCreate, _out, DEBTRACE, depthNode(), YACS::ENGINE::ComposedNode::edGetDirectDescendants(), YACS::ENGINE::OutputPort::edSetInPort(), YACS::ENGINE::Node::getChildByName(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::Node::getLocalOutputPorts(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::Node::getNumId(), YACS::ENGINE::Port::getNumId(), indent(), YACS::ENGINE::ComposedNode::isInMyDescendance(), and YACS::ENGINE::ForEachLoopGen::NAME_OF_SPLITTERNODE.
Referenced by visitBloc(), visitForEachLoop(), visitForEachLoopDyn(), visitForLoop(), visitLoop(), visitOptimizerLoop(), visitProc(), visitSwitch(), and visitWhileLoop().
◆ writeSimpleStreamLinks()
void VisitorSaveSchema::writeSimpleStreamLinks ( ComposedNode *  node)
Definition at line 974 of file VisitorSaveSchema.cxx.
975{
976 int depth = depthNode(node)+1;
977 list<Node*> setOfChildren = node->edGetDirectDescendants();
978
979 // --- first pass, write links where the input port is inside the node scope. Keep in memory others.
980
981 for (list<Node*>::iterator ic = setOfChildren.begin(); ic != setOfChildren.end(); ++ic)
982 {
983 Node* from = *ic;
984 if ( dynamic_cast<ComposedNode*>(from) ) continue;
985 list<OutputDataStreamPort*> listOP = from->getSetOfOutputDataStreamPort();
986 for (list<OutputDataStreamPort*>::iterator io = listOP.begin(); io != listOP.end(); ++io)
987 {
988 OutputDataStreamPort* anOP = *io;
989 set<InPort*> setIP = anOP->edSetInPort();
990 for (set<InPort*>::iterator iip = setIP.begin(); iip != setIP.end(); ++iip)
991 {
992 InPort *anIP = *iip;
993 Node* to = anIP->getNode();
994 DEBTRACE("from " << from->getName() << " outputPort " << anOP->getName()
995 << " to " << to->getName() << " inputPort " << anIP->getName() );
996 Node* child = node->isInMyDescendance(to);
997 if (child && (child->getNumId() != node->getNumId())
998 && (from->getNumId() != to->getNumId()))
999 {
1000 DEBTRACE( "BINGO!" );
1001 string childName = node->getChildName(to);
1002 _out << indent(depth) << "<stream>" << endl;
1003 _out << indent(depth+1) << "<fromnode>" << node->getChildName(from) << "</fromnode> ";
1004 _out << "<fromport>" << anOP->getName() << "</fromport>" << endl;
1005 _out << indent(depth+1) << "<tonode>" << childName << "</tonode> ";
1006 _out << "<toport>" << anIP->getName() << "</toport>" << endl;
1007
1008 std::map<std::string,std::string> aPropMap = dynamic_cast<InputDataStreamPort*>(anIP)->getProperties();
1009 for (std::map<std::string,std::string>::iterator itP = aPropMap.begin(); itP != aPropMap.end(); itP++)
1010 {
1011 string notAlinkProperty = "DependencyType";
1012 if (notAlinkProperty != (*itP).first)
1013 _out << indent(depth+1) << "<property name=\"" << (*itP).first << "\" value=\""
1014 << (*itP).second << "\"/>" << endl;
1015 }
1016 _out << indent(depth) << "</stream>" << endl;
1017 }
1018 else
1019 { // --- store info to create the link later, given the input port
1020 DEBTRACE("For later" );
1021 struct StreamLinkInfo aLink = { from, to, anOP, anIP, false };
1022 _mapOfSLtoCreate.insert(make_pair(anIP->getNumId(), aLink));
1023 }
1024 }
1025 }
1026 }
1027
1028 // --- second pass, retreive links where the output port is inside the scope.
1029
1030 if (!dynamic_cast<Switch*>(node)) // xml parser does not take into account datalinks in a switch context
1031 {
1032 std::multimap<int, StreamLinkInfo>::iterator pos;
1033 for (pos = _mapOfSLtoCreate.begin(); pos != _mapOfSLtoCreate.end(); ++pos)
1034 {
1035 Node* to = (pos->second).to;
1036 Node* child = node->isInMyDescendance(to);
1037 if (child && (child->getNumId() != node->getNumId()))
1038 {
1039 InPort* anIP = (pos->second).inp;
1040 int portId = anIP->getNumId();
1041 Node* from = (pos->second).from;
1042 child = node->isInMyDescendance(from);
1043 if (child && (child->getNumId() != node->getNumId()))
1044 if((from->getNumId() != to->getNumId()) || dynamic_cast<Loop*>(node))
1045 {
1046 string childName = node->getChildName(from);
1047 OutputDataStreamPort *anOP = (pos->second).outp;
1048 (pos->second).toDelete = true;
1049 _out << indent(depth) << "<stream>" << endl;
1050 _out << indent(depth+1) << "<fromnode>" << childName << "</fromnode> ";
1051 _out << "<fromport>" << anOP->getName() << "</fromport>" << endl;
1052 _out << indent(depth+1) << "<tonode>" << node->getChildName(to) << "</tonode> ";
1053 _out << "<toport>" << anIP->getName() << "</toport>" << endl;
1054
1055 std::map<std::string,std::string> aPropMap = dynamic_cast<InputDataStreamPort*>(anIP)->getProperties();
1056 for (std::map<std::string,std::string>::iterator itP = aPropMap.begin(); itP != aPropMap.end(); itP++)
1057 _out << indent(depth+1) << "<property name=\"" << (*itP).first << "\" value=\""
1058 << (*itP).second << "\"/>" << endl;
1059
1060 _out << indent(depth) << "</stream>" << endl;
1061 }
1062 }
1063 }
1064
1065 // --- remove the link written from the multimap
1066
1067 for (pos = _mapOfSLtoCreate.begin(); pos != _mapOfSLtoCreate.end();)
1068 {
1069 if ((pos->second).toDelete)
1070 _mapOfSLtoCreate.erase(pos++); // be careful not to saw off the branch on which you are sitting!
1071 else
1072 ++pos;
1073 }
1074 }
1075}
References _mapOfSLtoCreate, _out, DEBTRACE, depthNode(), YACS::ENGINE::ComposedNode::edGetDirectDescendants(), YACS::ENGINE::OutputDataStreamPort::edSetInPort(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::Node::getNumId(), YACS::ENGINE::Port::getNumId(), YACS::ENGINE::Node::getSetOfOutputDataStreamPort(), indent(), and YACS::ENGINE::ComposedNode::isInMyDescendance().
◆ writeTypeCodes()
void VisitorSaveSchema::writeTypeCodes ( Proc *  proc)
Definition at line 682 of file VisitorSaveSchema.cxx.
683{
684 int depth = depthNode(proc)+1;
685 map<string, TypeCode*> typeMap = getTypeCodeMap(proc);
686 map<string, TypeCode*>::const_iterator it;
687 set<string> typeNames;
688
689 // --- force definition of simple types first
690
691 for (it = typeMap.begin(); it != typeMap.end(); it++)
692 {
693 dumpTypeCode(it->second,typeNames,typeMap,depth);
694 }
695}
std::map< std::string, TypeCode * > getTypeCodeMap(Proc *proc)
Definition: Visitor.cxx:37
References depthNode(), dumpTypeCode(), and YACS::ENGINE::Visitor::getTypeCodeMap().
◆ _componentInstanceMap
std::map<ComponentInstance*, std::string> YACS::ENGINE::VisitorSaveSchema::_componentInstanceMap
Definition at line 112 of file VisitorSaveSchema.hxx.
Referenced by visitServiceNode().
◆ _containerMap
std::map<std::string, Container*> YACS::ENGINE::VisitorSaveSchema::_containerMap
Definition at line 111 of file VisitorSaveSchema.hxx.
Referenced by visitServerNode(), visitServiceNode(), and writeContainers().
◆ _mapOfDLtoCreate
std::multimap<int, DataLinkInfo> YACS::ENGINE::VisitorSaveSchema::_mapOfDLtoCreate
Definition at line 114 of file VisitorSaveSchema.hxx.
Referenced by writeSimpleDataLinks().
◆ _mapOfSLtoCreate
std::multimap<int, StreamLinkInfo> YACS::ENGINE::VisitorSaveSchema::_mapOfSLtoCreate
Definition at line 115 of file VisitorSaveSchema.hxx.
Referenced by writeSimpleStreamLinks().
◆ _nodeStateName
std::map<int, std::string> YACS::ENGINE::VisitorSaveSchema::_nodeStateName
Definition at line 110 of file VisitorSaveSchema.hxx.
◆ _out
◆ _root
