SceneBlocItem.cxx
20#include "SceneBlocItem.hxx"
21#include "Scene.hxx"
22#include "Menus.hxx"
23#include "QtGuiContext.hxx"
24#include "guiObservers.hxx"
25#include "ComposedNode.hxx"
26#include "Proc.hxx"
27#include "OutputPort.hxx"
28#include "OutGate.hxx"
29#include "InputPort.hxx"
30#include "InGate.hxx"
31
32#include <sstream>
33
34#include <gvc.h>
35
36#include <Qtx.h> // for Localizer
37
38#include "Resource.hxx"
39
40//#define _DEVDEBUG_
41#include "YacsTrace.hxx"
42
43using namespace std;
44using namespace YACS::ENGINE;
45using namespace YACS::HMI;
46
50#define DPI 72.
51
52SceneBlocItem::SceneBlocItem(QGraphicsScene *scene, SceneItem *parent,
53 QString label, Subject *subject)
54 : SceneComposedNodeItem(scene, parent, label, subject)
55{
56 DEBTRACE("SceneBlocItem::SceneBlocItem " <<label.toStdString());
57 _format = "%1"; // --- format to convert a float without locale: ex. 9.81
58}
59
61{
62}
63
65
69{
70#ifdef _DEVDEBUG_
71 DEBTRACE("SceneBlocItem::arrangeChildNodes");
72 clock_t start_t, end_t;
73 start_t = clock();
74#endif //_DEVDEBUG_
75
76
77 SubjectComposedNode *scnode = dynamic_cast<SubjectComposedNode*>(getSubject());
78 YASSERT(scnode);
79 ComposedNode *cnode = dynamic_cast<ComposedNode*>(scnode->getNode());
80 YASSERT(cnode);
81
82 // ---- Create a graphviz context
83
84 // Graphviz is sensitive to locale : set the mimimal one ("C")for numeric
85 Qtx::Localizer loc;
86
87 //aginit();
88 GVC_t* aGvc = gvContext();
89
90 // ---- Create a graph
91
92 _graph = agopen((char*)( cnode->getName().c_str()), Agdirected, NULL);
93
94 // ---- Initialize and set attributes for the graph
95
96 agattr(_graph, AGRAPH, const_cast<char*>("compound"), const_cast<char*>("true"));
97 agattr(_graph, AGRAPH, const_cast<char*>("rankdir"), const_cast<char*>("LR"));
98 agattr(_graph, AGRAPH, const_cast<char*>("dpi"), const_cast<char*>("72"));
99 agattr(_graph, AGRAPH, const_cast<char*>("label"), const_cast<char*>("myLabel"));
100 agattr(_graph, AGRAPH, const_cast<char*>("labelloc"), const_cast<char*>("top"));
101 agattr(_graph, AGRAPH, const_cast<char*>("fontsize"), const_cast<char*>("24"));
102 agattr(_graph, AGRAPH, const_cast<char*>("splines"), const_cast<char*>(""));
103
104 // --- Initialize attributes for nodes
105
106 agattr(_graph, AGNODE, const_cast<char*>("height"), const_cast<char*>("" ));
107 agattr(_graph, AGNODE, const_cast<char*>("width"), const_cast<char*>("" ));
108 agattr(_graph, AGNODE, const_cast<char*>("shape"), const_cast<char*>("" ));
109 agattr(_graph, AGNODE, const_cast<char*>("fixedsize"), const_cast<char*>("false" ));
110
111 // ---- Bind graph to graphviz context - must be done before layout
112 // ---- Compute a layout
113
114 try
115 {
116 getNodesInfo(cnode);
117 // createGraphvizNodes(cnode);
118 DEBTRACE("end of graphviz input");
119#ifdef _DEVDEBUG_
120 agwrite(_graph, stderr);
121#endif
122 //DEBTRACE("external render for test");
123 //gvRenderFilename(aGvc, _mainGraph, "dot", "graph1.dot");
124 DEBTRACE("compute layout");
125 gvLayout(aGvc, _graph, "dot");
126 DEBTRACE("external render for test");
127#ifdef _DEVDEBUG_
128 gvRenderFilename(aGvc, _graph, "dot", "graph2.dot");
129#endif
130 }
131 catch (std::exception &e)
132 {
133 DEBTRACE("Exception Graphviz layout: " << e.what());
134 return;
135 }
136 catch (...)
137 {
138 DEBTRACE("Unknown Exception Graphviz layout ");
139 return;
140 }
141#ifdef _DEVDEBUG_
142 {
143 end_t = clock();
144 double passe = (end_t -start_t);
145 passe = passe/CLOCKS_PER_SEC;
146 DEBTRACE("graphviz : " << passe);
147 start_t = end_t;
148 }
149#endif //_DEVDEBUG_
150 DEBTRACE("start of display");
151 // ---- layout Canvas nodes recursively
152
153 arrangeCanvasNodes(cnode);
154
155 DEBTRACE("clean up graphviz");
156 // ---- Delete layout
157
158 gvFreeLayout(aGvc, _graph);
159
160 // ---- Free graph structures
161
162 agclose(_graph) ;
163
164 // ---- Free context and return number of errors
165
166 gvFreeContext( aGvc );
167
168 // --- update scene
169#ifdef _DEVDEBUG_
170 {
171 end_t = clock();
172 double passe = (end_t -start_t);
173 passe = passe/CLOCKS_PER_SEC;
174 DEBTRACE("display : " << passe);
175 start_t = end_t;
176 }
177#endif //_DEVDEBUG_
178}
179
181{
183
184 // --- Create Nodes = direct descendants in the bloc
185
186 list<Node*> children = cnode->edGetDirectDescendants();
187 for (list<Node*>::iterator it = children.begin(); it != children.end(); ++it)
188 {
189 Agnode_t* aNode = agnode(_graph, (char*)(proc->getChildName(*it).c_str()), 1);
190 DEBTRACE("Add node in graph: " << agnameof(aNode));
191
194 double nh = sci->getHeight();
195 double nw = sci->getWidth();
196 double lh = nh/DPI;
197 double lw = nw/DPI;
198
199 QString height, width;
200 height = QString(_format.c_str()).arg(lh, 0, 'g', 3);
201 width = QString(_format.c_str()).arg(lw, 0, 'g', 3);
202
203 DEBTRACE(agnameof(aNode) << " (" << nh << "," << nw << ") = (" << height.toStdString() << " ; " << width.toStdString() <<")");
204 agset(aNode, const_cast<char*>("height"), height.toLatin1().data());
205 agset(aNode, const_cast<char*>("width"), width.toLatin1().data());
206 agset(aNode, const_cast<char*>("shape"), const_cast<char*>("box") );
207 agset(aNode, const_cast<char*>("fixedsize"), const_cast<char*>("true") );
208 }
209
210 // --- Create edges (i.e. links)
211
212 Agnode_t* aNode = NULL;
213 for (aNode = agfstnode(_graph); aNode; aNode = agnxtnode(_graph, aNode))
214 {
215 string aNodeName = agnameof(aNode);
216 DEBTRACE("--- tail node " << aNodeName);
217 Agnode_t* aTailNode = aNode;
218 Node* outNode = proc->getChildByName(string(agnameof(aTailNode)));
219 if (outNode->getFather() != cnode)
220 {
221 DEBTRACE(" =========== problem here ! =============================");
222 continue; // Create edges only with outgoing nodes directly in bloc
223 }
224
225 // --- control link from node, keep only link staying inside the bloc
226
227 {
228 OutGate *outGate = outNode->getOutGate();
229 list<InGate*> setOfInGate = outGate->edSetInGate();
230 list<InGate*>::const_iterator itin = setOfInGate.begin();
231 for (; itin != setOfInGate.end(); ++itin)
232 {
233 Node *inNode = (*itin)->getNode();
234 string inName = proc->getChildName(inNode);
235 DEBTRACE("--- control link from tail node: --- "<<inName);
236 // --- isInMyDescendance(this) return this
237 // isInMyDescendance(inNode) return direct child if inNode is a direct child or grandchild
238 if (Node *inDCNode = cnode->isInMyDescendance(inNode))
239 {
240 DEBTRACE("--- edge inside the bloc " << inDCNode->getName());
241 string inDCName = proc->getChildName(inDCNode);
242 Agnode_t* aHeadNode = agnode(_graph, (char*)(inDCName.c_str()), 1);
243 Agedge_t* anEdge = agedge(_graph, aTailNode, aHeadNode, NULL, 1);
244 DEBTRACE("--- control link from tail node: --- " << agnameof(aNode) << " --> " << inDCName);
245 }
246 }
247 }
248
249 // --- datalink from node, keep only link staying inside the bloc
250
251 {
252 list<OutPort*> outPortList = outNode->getSetOfOutPort();
253 list<OutPort*>::const_iterator itou = outPortList.begin();
254 for (; itou != outPortList.end(); ++itou)
255 {
256 set<InPort*> inPortList = (*itou)->edSetInPort();
257 set<InPort*>::const_iterator itin = inPortList.begin();
258 for (; itin != inPortList.end(); ++itin)
259 {
260 Node *inNode = (*itin)->getNode();
261 string inName = proc->getChildName(inNode);
262 DEBTRACE("------ data link from tail node: ---- ");
263 if (Node *inDCNode = cnode->isInMyDescendance(inNode))
264 {
265 DEBTRACE("--- edge inside the bloc " << inDCNode->getName());
266 string inDCName = proc->getChildName(inDCNode);
267 Agnode_t* aHeadNode = agnode(_graph, (char*)(inDCName.c_str()), 1);
268 Agedge_t* anEdge = agedge(_graph, aTailNode, aHeadNode, NULL, 1);
269 DEBTRACE("------ data link from tail node: ---- " << agnameof(aNode) << " --> " << inDCName);
270 }
271 }
272 }
273 }
274 }
275}
276
277
279{
280 DEBTRACE("SceneBlocItem::arrangeCanvasNodes");
282
285 SceneComposedNodeItem *sceneCompo = dynamic_cast<SceneComposedNodeItem*>(sci);
286 YASSERT(sceneCompo);
287 qreal yHead = sceneCompo->getHeaderBottom() + Resource::Space_Margin;
288 qreal xOffset = Resource::Space_Margin;
289
290 list<Node*> children = cnode->edGetDirectDescendants();
291 for (list<Node*>::iterator it = children.begin(); it != children.end(); ++it)
292 {
293 Agnode_t* aNode = agnode(_graph, (char*)(proc->getChildName(*it).c_str()), 1);
294 DEBTRACE("Get node in graph: " << agnameof(aNode));
297
298 qreal xCenter = ND_coord(aNode).x;
299 qreal yCenter = ND_coord(aNode).y;
300 qreal halfWidth = sci->boundingRect().width()/2.;
301 qreal halfHeight = sci->boundingRect().height()/2.;
302
303 sci->setPos(xOffset + xCenter -halfWidth, yHead + yCenter -halfHeight);
304 SceneNodeItem *scni = dynamic_cast<SceneNodeItem*>(sci);
305 if (scni) scni->setExpandedPos(QPointF(xOffset + xCenter -halfWidth, yHead + yCenter -halfHeight));
306 }
307 sceneCompo->checkGeometryChange();
309 {
312 SceneComposedNodeItem *proc = dynamic_cast<SceneComposedNodeItem*>(item);
313 proc->rebuildLinks();
314 }
315
316}
#define DPI
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::string getName() const
virtual std::list< Node * > edGetDirectDescendants() const =0
Node * isInMyDescendance(Node *nodeToTest) const
Returns the parent of a node that is the direct child of this node.
Base class for all nodes.
Definition: Node.hxx:70
ComposedNode * getFather() const
Definition: Node.hxx:127
OutGate * getOutGate()
Definition: Node.hxx:124
std::list< OutPort * > getSetOfOutPort() const
Definition: Node.cxx:299
std::list< InGate * > edSetInGate() const
Definition: OutGate.cxx:112
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
Definition: guiContext.hxx:50
std::map< YACS::HMI::Subject *, YACS::HMI::SceneItem * > _mapOfSceneItem
static int Space_Margin
Definition: Resource.hxx:311
virtual void arrangeCanvasNodes(YACS::ENGINE::ComposedNode *cnode)
virtual void arrangeChildNodes()
Auto-arrange nodes inside a schema using Graphviz C API.
virtual void getNodesInfo(YACS::ENGINE::ComposedNode *cnode)
virtual QRectF boundingRect() const
Definition: SceneItem.cxx:215
virtual void checkGeometryChange()
Definition: SceneItem.cxx:248
virtual qreal getHeaderBottom()
void setExpandedPos(QPointF epos)
static bool _autoComputeLinks
Definition: Scene.hxx:37
