YACS::HMI::SceneObserverItem Class Reference
#include <SceneObserverItem.hxx>
Inheritance diagram for YACS::HMI::SceneObserverItem:
Collaboration diagram for YACS::HMI::SceneObserverItem:
 SceneObserverItem (QGraphicsScene *scene, SceneItem *parent, QString label, Subject *subject)
virtual ~SceneObserverItem ()
virtual void activateSelection (bool selected)
virtual QString getToolTip ()
- Public Member Functions inherited from YACS::HMI::SceneItem
 SceneItem (QGraphicsScene *scene, SceneItem *parent, QString label)
virtual ~SceneItem ()
virtual QRectF boundingRect () const
virtual QRectF childrenBoundingRect () const
virtual void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget)
virtual void setTopLeft (QPointF topLeft)
virtual void checkGeometryChange ()
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
void setParent (SceneItem *parent)
void setEventPos (QPointF point)
virtual void updateChildItems ()
virtual void updateLinks ()
virtual void shrinkExpandLink (bool se)
virtual void shrinkExpandRecursive (bool isExpanding, bool fromHere, ShrinkMode theShrinkMode)
bool isAncestorShrinked ()
- Public Member Functions inherited from YACS::HMI::AbstractSceneItem
 AbstractSceneItem (QGraphicsScene *scene, SceneItem *parent, QString label)
virtual ~AbstractSceneItem ()
virtual QRectF boundingRect () const =0
virtual void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget)=0
virtual void setTopLeft (QPointF topLeft)=0
int getLevel ()
void setLevel ()
virtual void checkGeometryChange ()=0
virtual void reorganize ()
virtual QString getLabel ()
virtual void addHeader ()
virtual void addProgressItem ()
virtual qreal getHeaderBottom ()
qreal getWidth ()
qreal getHeight ()
virtual void setWidth (qreal width)
 AbstractSceneItem cannot be resized (only ComposedNodeItem can) More...
virtual void setHeight (qreal height)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)=0
virtual void setGeometryOptimization (bool optimize)
SceneItem * getParent ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual void mousePressEvent (QGraphicsSceneMouseEvent *event)
virtual void mouseMoveEvent (QGraphicsSceneMouseEvent *event)
virtual void mouseReleaseEvent (QGraphicsSceneMouseEvent *event)
virtual QColor getBrushColor ()
virtual QString getMimeFormat ()
- Protected Member Functions inherited from YACS::HMI::SceneItem
virtual void hoverEnterEvent (QGraphicsSceneHoverEvent *event)
virtual void hoverMoveEvent (QGraphicsSceneHoverEvent *event)
virtual void hoverLeaveEvent (QGraphicsSceneHoverEvent *event)
virtual QColor getPenColor ()
QColor hoverColor (QColor origColor)
- Protected Member Functions inherited from YACS::HMI::AbstractSceneItem
virtual QRectF childBoundingRect (AbstractSceneItem *child) const
Subject * _subject
bool _draging
bool _dragModifier
bool _emphasized
- Protected Attributes inherited from YACS::HMI::SceneItem
bool _hover
bool _ancestorShrinked
QPointF _eventPos
- Protected Attributes inherited from YACS::HMI::AbstractSceneItem
SceneItem * _parent
YACS::HMI::Scene * _scene
QString _label
int _level
qreal _width
qreal _height
qreal _incHeight
QColor _penColor
QColor _brushColor
QColor _hiPenColor
QColor _hiBrushColor
bool _hasHeader
bool _optimize
bool _dragable
enum Qt::MouseButton _dragButton
bool _destructible
static void setEventMap ()
- Public Attributes inherited from YACS::HMI::SceneItem
bool _blocX
bool _blocY
Definition at line 31 of file SceneObserverItem.hxx.
◆ SceneObserverItem()
SceneObserverItem::SceneObserverItem ( QGraphicsScene *  scene,
SceneItem *  parent,
QString  label,
Subject *  subject
Definition at line 42 of file SceneObserverItem.cxx.
44 : SceneItem(scene, parent, label), GuiObserver()
45{
46 _subject = subject;
47 _draging = false;
48 _dragModifier = false;
49 _emphasized = false;
50 _subject->attach(this);
52}
std::map< YACS::HMI::Subject *, YACS::HMI::SceneItem * > _mapOfSceneItem
SceneItem(QGraphicsScene *scene, SceneItem *parent, QString label)
Definition: SceneItem.cxx:191
virtual void attach(GuiObserver *obs)
References _draging, _dragModifier, _emphasized, YACS::HMI::QtGuiContext::_mapOfSceneItem, _subject, YACS::HMI::Subject::attach(), and YACS::HMI::QtGuiContext::getQtCurrent().
◆ ~SceneObserverItem()
SceneObserverItem::~SceneObserverItem ( )
◆ activateSelection()
void SceneObserverItem::activateSelection ( bool  selected)
Reimplemented from YACS::HMI::AbstractSceneItem.
Definition at line 190 of file SceneObserverItem.cxx.
191{
192 DEBTRACE("SceneObserverItem::activateSelection " << _label.toStdString()<< " " << selected);
193 _subject->select(true);
194}
virtual void select(bool isSelected)
References YACS::HMI::AbstractSceneItem::_label, _subject, DEBTRACE, and YACS::HMI::Subject::select().
◆ getBrushColor()
◆ getMimeFormat()
QString SceneObserverItem::getMimeFormat ( )
Reimplemented in YACS::HMI::SceneNodeItem, and YACS::HMI::SceneOutPortItem.
Definition at line 201 of file SceneObserverItem.cxx.
202{
203 return "yacs/subject";
204}
Referenced by mouseMoveEvent().
◆ getSubject()
◆ getToolTip()
QString SceneObserverItem::getToolTip ( )
generic behaviour for headers: obtain the tooltip from parent. Method to be redefined in derived classes.
Reimplemented from YACS::HMI::SceneItem.
Definition at line 89 of file SceneObserverItem.cxx.
90{
91 DEBTRACE("SceneObserverItem::getToolTip");
92 if (!_subject)
93 return _label;
94 if ( !QtGuiContext::getQtCurrent() || !QtGuiContext::getQtCurrent()->_mapOfSchemaItem.count(_subject))
95 return _label;
96 QString val ="";
98 val = item->data(0, Qt::ToolTipRole).toString();
99 return val;
100}
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
References YACS::HMI::AbstractSceneItem::_label, YACS::HMI::QtGuiContext::_mapOfSchemaItem, _subject, YACS::HMI::SchemaItem::data(), DEBTRACE, and YACS::HMI::QtGuiContext::getQtCurrent().
◆ mouseMoveEvent()
void SceneObserverItem::mouseMoveEvent ( QGraphicsSceneMouseEvent *  event)
creation of mime data if drag detected. setData mime type must be coherent with SchemaModel::mimeTypes to allow drop on port item in tree view
Reimplemented in YACS::HMI::SceneNodeItem.
Definition at line 123 of file SceneObserverItem.cxx.
124{
125 if (_draging)
126 {
127 //DEBTRACE("_draging");
128 if (QLineF(event->screenPos(),
129 event->buttonDownScreenPos(_dragButton)).length()
130 < QApplication::startDragDistance())
131 {
132 return;
133 }
134 DEBTRACE("in drag");
135 QDrag *drag = new QDrag(event->widget());
136 ItemMimeData *mime = new ItemMimeData;
137 drag->setMimeData(mime);
138 mime->setSubject(_subject);
139 mime->setData(getMimeFormat(), "_subject");
140 if(_dragModifier)
141 mime->setControl(false);
142 else
143 mime->setControl(true);
144
145 QPixmap pixmap(34, 34);
146 pixmap.fill(Qt::white);
147
148 QPainter painter(&pixmap);
149 painter.translate(15, 15);
150 painter.setRenderHint(QPainter::Antialiasing);
151 paint(&painter, 0, 0);
152 painter.end();
153
154 pixmap.setMask(pixmap.createHeuristicMask());
155
156 drag->setPixmap(pixmap);
157 drag->setHotSpot(QPoint(15, 20));
158
159 drag->exec();
160 //restore non drag state
161 setCursor(Qt::ArrowCursor);
162 _draging = false;
163 _dragModifier = false;
164 }
165}
Definition: SceneItem.hxx:111
virtual void setSubject(Subject *sub)
virtual void setControl(bool control)
virtual void paint(QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget)
Definition: SceneItem.cxx:229
References YACS::HMI::AbstractSceneItem::_dragButton, _draging, _dragModifier, _subject, DEBTRACE, getMimeFormat(), YACS::HMI::SceneItem::paint(), YACS::HMI::ItemMimeData::setControl(), and YACS::HMI::ItemMimeData::setSubject().
Referenced by YACS::HMI::SceneNodeItem::mouseMoveEvent().
◆ mousePressEvent()
void SceneObserverItem::mousePressEvent ( QGraphicsSceneMouseEvent *  event)
Definition at line 102 of file SceneObserverItem.cxx.
103{
104 DEBTRACE("SceneObserverItem::mousePressEvent " << _label.toStdString()
105 << " " << acceptedMouseButtons ());
106 if (!_scene->isZooming())
107 {
108 _subject->select(true);
109 if (_dragable && (event->button() == _dragButton) && QtGuiContext::getQtCurrent()->isEdition())
110 {
111 setCursor(Qt::ClosedHandCursor);
112 _draging = true;
113 _dragModifier= event->modifiers() & (Qt::ControlModifier | Qt::ShiftModifier);
114 }
115 }
116}
Definition: SceneItem.hxx:98
bool isZooming()
Definition: Scene.cxx:64
References YACS::HMI::AbstractSceneItem::_dragable, YACS::HMI::AbstractSceneItem::_dragButton, _draging, _dragModifier, YACS::HMI::AbstractSceneItem::_label, YACS::HMI::AbstractSceneItem::_scene, _subject, DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::isEdition(), YACS::HMI::Scene::isZooming(), and YACS::HMI::Subject::select().
Referenced by YACS::HMI::SceneNodeItem::mousePressEvent().
◆ mouseReleaseEvent()
void SceneObserverItem::mouseReleaseEvent ( QGraphicsSceneMouseEvent *  event)
Definition at line 167 of file SceneObserverItem.cxx.
168{
169 if (_draging)
170 {
171 setCursor(Qt::ArrowCursor);
172 }
173 _draging = false;
174 _dragModifier = false;
175}
References _draging, and _dragModifier.
Referenced by YACS::HMI::SceneNodeItem::mouseReleaseEvent().
◆ select()
void SceneObserverItem::select ( bool  isSelected)
Reimplemented from YACS::HMI::GuiObserver.
Reimplemented in YACS::HMI::SceneLinkItem.
Definition at line 77 of file SceneObserverItem.cxx.
78{
79 DEBTRACE("SceneObserverItem::select " << _label.toStdString() << " " << isSelected);
80 if (isSelected)
81 {
82// _scene->clearSelection();
83 setSelected(true);
85 }
86 else setSelected(false);
87}
void setSelectedSubject(YACS::HMI::Subject *sub)
References YACS::HMI::AbstractSceneItem::_label, _subject, DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::QtGuiContext::setSelectedSubject().
Referenced by YACS::HMI::SceneLinkItem::select().
◆ update()
void SceneObserverItem::update ( GuiEvent  event,
int  type,
Subject *  son
Reimplemented in YACS::HMI::SceneComposedNodeItem, YACS::HMI::SceneDataPortItem, YACS::HMI::SceneElementaryNodeItem, YACS::HMI::SceneLinkItem, and YACS::HMI::SceneNodeItem.
Definition at line 59 of file SceneObserverItem.cxx.
60{
61 DEBTRACE(" SceneObserverItem::update " << eventName(event)<< " " << type << " " << son);
62 switch (event)
63 {
65 DEBTRACE("SceneObserverItem::update EMPHASIZE " << type);
66 if (type)
67 _emphasized = true;
68 else
69 _emphasized = false;
70 QGraphicsItem::update();
71 break;
72 default:
73 ;
74 }
75}
References _emphasized, DEBTRACE, YACS::HMI::EMPHASIZE, and YACS::HMI::GuiObserver::eventName().
Referenced by gui.graph.MyCanvas::customEvent(), YACS::HMI::SceneDataPortItem::update(), and YACS::HMI::SceneNodeItem::update().
◆ _draging
bool YACS::HMI::SceneObserverItem::_draging
◆ _dragModifier
bool YACS::HMI::SceneObserverItem::_dragModifier
◆ _emphasized
◆ _subject
