33 static const char MSG[]=
"Bloc::fitToPlayGround : Not implemented yet for this type of node !";
34 class MyVisitor :
public Visitor
38 void visitBloc(
Bloc *node) { node->ComposedNode::accept(
this); }
42 _max_lev=std::max(_max_lev,_lev);
45 node->ComposedNode::accept(
this);
66 _cont.push_back(cont2);
71 void visitProc(
Proc *node) { node->ComposedNode::accept(
this); }
82 std::list<ForEachLoop *> _fes;
83 std::list< HomogeneousPoolContainer *> _cont;
84 std::set< HomogeneousPoolContainer * > _cont2;
89 std::map<ComposedNode *,YACS::BASES::AutoRefCnt<PartDefinition> > zeMap;
92 for(std::list<ForEachLoop *>::const_iterator it=vis._fes.begin();it!=vis._fes.end();it++)
93 (*it)->edGetNbOfBranchesPort()->edInit(1);
96 throw YACS::Exception(
"Bloc::fitToPlayGround : Not enough cores available to run the calculation !");
99 for(std::list<ForEachLoop *>::const_iterator it=vis._fes.begin();it!=vis._fes.end();it++)
101 std::map<ComposedNode *,YACS::BASES::AutoRefCnt<PartDefinition> >::iterator it2(zeMap.find(*it));
104 int maxLev((*it)->getExecNode()->getMaxLevelOfParallelism());
105 int a((*it2).second->getNumberOfCoresConsumed());
107 (*it)->edGetNbOfBranchesPort()->edInit(res);
109 for(std::set< HomogeneousPoolContainer * >::const_iterator it=vis._cont2.begin();it!=vis._cont2.end();it++)
114constexpr char MSG[]=
"Bloc::propagePlayGround : Not implemented yet for this type of node !";
126 template<
class NodeClass>
133 _cont2.insert(cont2);
149 std::set< HomogeneousPoolContainer * >
_cont2;
156 for(
auto cont : vis.
_cont2)
void visitServiceInlineNode(ServiceInlineNode *node)
void visitDynParaLoop(DynParaLoop *node)
void visitServiceNode(ServiceNode *node)
void visitStudyOutNode(DataNode *node)
void visitNodeWithContainer(NodeClass *node)
void visitBloc(Bloc *node)
void visitSwitch(Switch *node)
void visitLoop(Loop *node)
void visitInlineNode(InlineNode *node)
void visitOutNode(DataNode *node)
void visitPresetNode(DataNode *node)
void visitStudyInNode(DataNode *node)
void visitForLoop(ForLoop *node)
void visitElementaryNode(ElementaryNode *node)
void visitOptimizerLoop(OptimizerLoop *node)
void visitInlineFuncNode(InlineFuncNode *node)
void visitForEachLoop(ForEachLoop *node)
void visitWhileLoop(WhileLoop *node)
void visitProc(Proc *node)
void visitServerNode(ServerNode *node)
MyVisitorPropagate(ComposedNode *root)
void visitForEachLoopDyn(ForEachLoopDyn *node)
void removeRecursivelyRedundantCL()
void accept(Visitor *visitor)
void propagePlayGround(const PlayGround *pg)
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)
int getMaxLevelOfParallelism() const
Base class for dynamically (fully or semifully) built graphs.
InputPort * edGetNbOfBranchesPort()
Loop node for parametric calculation.
virtual Container * getContainer()
Base class for loop node.
int getNumberOfCoresAvailable() const
int getNumberOfWorkers(int nbCoresPerWorker) const
