MyVisitorPropagate Class Reference
Inheritance diagram for MyVisitorPropagate:
Collaboration diagram for MyVisitorPropagate:
 MyVisitorPropagate (ComposedNode *root)
void visitBloc (Bloc *node)
void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node)
void visitForEachLoopDyn (ForEachLoopDyn *node)
void visitOptimizerLoop (OptimizerLoop *node)
void visitDynParaLoop (DynParaLoop *node)
void visitForLoop (ForLoop *node)
template<class NodeClass >
void visitNodeWithContainer (NodeClass *node)
void visitInlineNode (InlineNode *node)
void visitInlineFuncNode (InlineFuncNode *node)
void visitLoop (Loop *node)
void visitProc (Proc *node)
void visitServiceNode (ServiceNode *node)
void visitServerNode (ServerNode *node)
void visitServiceInlineNode (ServiceInlineNode *node)
void visitSwitch (Switch *node)
void visitWhileLoop (WhileLoop *node)
void visitPresetNode (DataNode *node)
void visitOutNode (DataNode *node)
void visitStudyInNode (DataNode *node)
void visitStudyOutNode (DataNode *node)
- Public Member Functions inherited from YACS::ENGINE::Visitor
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
Public Attributes
std::set< HomogeneousPoolContainer * > _cont2
- Protected Member Functions inherited from YACS::ENGINE::Visitor
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
- Protected Attributes inherited from YACS::ENGINE::Visitor
ComposedNode * _root
Definition at line 115 of file Bloc_impl.cxx.
◆ MyVisitorPropagate()
MyVisitorPropagate::MyVisitorPropagate ( ComposedNode *  root)
Definition at line 118 of file Bloc_impl.cxx.
118:Visitor(root) { }
Visitor(ComposedNode *root)
Definition: Visitor.cxx:28
◆ visitBloc()
void MyVisitorPropagate::visitBloc ( Bloc *  node)
Implements YACS::ENGINE::Visitor.
Definition at line 119 of file Bloc_impl.cxx.
119{ node->ComposedNode::accept(this); }
◆ visitDynParaLoop()
void MyVisitorPropagate::visitDynParaLoop ( DynParaLoop *  node)
Definition at line 124 of file Bloc_impl.cxx.
124{ throw YACS::Exception(MSG); }
constexpr char MSG[]
Definition: Bloc_impl.cxx:114
References MSG.
◆ visitElementaryNode()
void MyVisitorPropagate::visitElementaryNode ( ElementaryNode *  node)
Definition at line 120 of file Bloc_impl.cxx.
120{ }
◆ visitForEachLoop()
void MyVisitorPropagate::visitForEachLoop ( ForEachLoop *  node)
Definition at line 121 of file Bloc_impl.cxx.
121{ node->ComposedNode::accept(this); }
◆ visitForEachLoopDyn()
void MyVisitorPropagate::visitForEachLoopDyn ( ForEachLoopDyn *  node)
Definition at line 122 of file Bloc_impl.cxx.
122{ node->ComposedNode::accept(this); }
◆ visitForLoop()
void MyVisitorPropagate::visitForLoop ( ForLoop *  node)
Definition at line 125 of file Bloc_impl.cxx.
125{ throw YACS::Exception(MSG); }
References MSG.
◆ visitInlineFuncNode()
void MyVisitorPropagate::visitInlineFuncNode ( InlineFuncNode *  node)
Definition at line 136 of file Bloc_impl.cxx.
136{ visitInlineNode(node); }
void visitInlineNode(InlineNode *node)
Definition: Bloc_impl.cxx:135
◆ visitInlineNode()
void MyVisitorPropagate::visitInlineNode ( InlineNode *  node)
Definition at line 135 of file Bloc_impl.cxx.
135{ this->visitNodeWithContainer<InlineNode>(node); }
◆ visitLoop()
void MyVisitorPropagate::visitLoop ( Loop *  node)
Definition at line 137 of file Bloc_impl.cxx.
137{ throw YACS::Exception(MSG); }
References MSG.
◆ visitNodeWithContainer()
void MyVisitorPropagate::visitNodeWithContainer ( NodeClass *  node)
Definition at line 127 of file Bloc_impl.cxx.
128 {
129 Container *cont(node->getContainer());
130 HomogeneousPoolContainer *cont2(dynamic_cast<HomogeneousPoolContainer *>(cont));
131 if(!cont2)
132 return ;
133 _cont2.insert(cont2);
134 }
Definition: Bloc_impl.cxx:149
◆ visitOptimizerLoop()
void MyVisitorPropagate::visitOptimizerLoop ( OptimizerLoop *  node)
Definition at line 123 of file Bloc_impl.cxx.
123{ throw YACS::Exception(MSG); }
References MSG.
◆ visitOutNode()
void MyVisitorPropagate::visitOutNode ( DataNode *  node)
Definition at line 145 of file Bloc_impl.cxx.
145{ throw YACS::Exception(MSG); }
References MSG.
◆ visitPresetNode()
void MyVisitorPropagate::visitPresetNode ( DataNode *  node)
Definition at line 144 of file Bloc_impl.cxx.
144{ throw YACS::Exception(MSG); }
References MSG.
◆ visitProc()
void MyVisitorPropagate::visitProc ( Proc *  node)
Definition at line 138 of file Bloc_impl.cxx.
138{ node->ComposedNode::accept(this); }
◆ visitServerNode()
void MyVisitorPropagate::visitServerNode ( ServerNode *  node)
Definition at line 140 of file Bloc_impl.cxx.
140{ visitInlineNode(node); }
◆ visitServiceInlineNode()
void MyVisitorPropagate::visitServiceInlineNode ( ServiceInlineNode *  node)
Definition at line 141 of file Bloc_impl.cxx.
141{ throw YACS::Exception(MSG); }
References MSG.
◆ visitServiceNode()
void MyVisitorPropagate::visitServiceNode ( ServiceNode *  node)
Definition at line 139 of file Bloc_impl.cxx.
139{ this->visitNodeWithContainer<ServiceNode>(node); }
◆ visitStudyInNode()
void MyVisitorPropagate::visitStudyInNode ( DataNode *  node)
Definition at line 146 of file Bloc_impl.cxx.
146{ throw YACS::Exception(MSG); }
References MSG.
◆ visitStudyOutNode()
void MyVisitorPropagate::visitStudyOutNode ( DataNode *  node)
Definition at line 147 of file Bloc_impl.cxx.
147{ throw YACS::Exception(MSG); }
References MSG.
◆ visitSwitch()
void MyVisitorPropagate::visitSwitch ( Switch *  node)
Definition at line 142 of file Bloc_impl.cxx.
142{ throw YACS::Exception(MSG); }
References MSG.
◆ visitWhileLoop()
void MyVisitorPropagate::visitWhileLoop ( WhileLoop *  node)
Definition at line 143 of file Bloc_impl.cxx.
143{ throw YACS::Exception(MSG); }
References MSG.
◆ _cont2
std::set< HomogeneousPoolContainer * > MyVisitorPropagate::_cont2
Definition at line 149 of file Bloc_impl.cxx.
Referenced by YACS::ENGINE::Bloc::propagePlayGround().
