mt19937ar.cxx
20#include <stdio.h>
21
22/* Period parameters */
23#define N 624
24#define M 397
25#define MATRIX_A 0x9908b0dfUL /* constant vector a */
26#define UPPER_MASK 0x80000000UL /* most significant w-r bits */
27#define LOWER_MASK 0x7fffffffUL /* least significant r bits */
28
29static unsigned long mt[N]; /* the array for the state vector */
30static int mti=N+1; /* mti==N+1 means mt[N] is not initialized */
31
32/* initializes mt[N] with a seed */
33void init_genrand(unsigned long s)
34{
35 mt[0]= s & 0xffffffffUL;
36 for (mti=1; mti<N; mti++) {
37 mt[mti] =
38 (1812433253UL * (mt[mti-1] ^ (mt[mti-1] >> 30)) + mti);
39 /* See Knuth TAOCP Vol2. 3rd Ed. P.106 for multiplier. */
40 /* In the previous versions, MSBs of the seed affect */
41 /* only MSBs of the array mt[]. */
42 /* 2002/01/09 modified by Makoto Matsumoto */
43 mt[mti] &= 0xffffffffUL;
44 /* for >32 bit machines */
45 }
46}
47
48/* initialize by an array with array-length */
49/* init_key is the array for initializing keys */
50/* key_length is its length */
51/* slight change for C++, 2004/2/26 */
52void init_by_array(unsigned long init_key[], int key_length)
53{
54 int i, j, k;
55 init_genrand(19650218UL);
56 i=1; j=0;
57 k = (N>key_length ? N : key_length);
58 for (; k; k--) {
59 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1664525UL))
60 + init_key[j] + j; /* non linear */
61 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */
62 i++; j++;
63 if (i>=N) { mt[0] = mt[N-1]; i=1; }
64 if (j>=key_length) j=0;
65 }
66 for (k=N-1; k; k--) {
67 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1566083941UL))
68 - i; /* non linear */
69 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */
70 i++;
71 if (i>=N) { mt[0] = mt[N-1]; i=1; }
72 }
73
74 mt[0] = 0x80000000UL; /* MSB is 1; assuring non-zero initial array */
75}
76
77/* generates a random number on [0,0xffffffff]-interval */
78unsigned long genrand_int32(void)
79{
80 unsigned long y;
81 static unsigned long mag01[2]={0x0UL, MATRIX_A};
82 /* mag01[x] = x * MATRIX_A for x=0,1 */
83
84 if (mti >= N) { /* generate N words at one time */
85 int kk;
86
87 if (mti == N+1) /* if init_genrand() has not been called, */
88 init_genrand(5489UL); /* a default initial seed is used */
89
90 for (kk=0;kk<N-M;kk++) {
91 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK);
92 mt[kk] = mt[kk+M] ^ (y >> 1) ^ mag01[y & 0x1UL];
93 }
94 for (;kk<N-1;kk++) {
95 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK);
96 mt[kk] = mt[kk+(M-N)] ^ (y >> 1) ^ mag01[y & 0x1UL];
97 }
98 y = (mt[N-1]&UPPER_MASK)|(mt[0]&LOWER_MASK);
99 mt[N-1] = mt[M-1] ^ (y >> 1) ^ mag01[y & 0x1UL];
100
101 mti = 0;
102 }
103
104 y = mt[mti++];
105
106 /* Tempering */
107 y ^= (y >> 11);
108 y ^= (y << 7) & 0x9d2c5680UL;
109 y ^= (y << 15) & 0xefc60000UL;
110 y ^= (y >> 18);
111
112 return y;
113}
114
115/* generates a random number on [0,0x7fffffff]-interval */
117{
118 return (long)(genrand_int32()>>1);
119}
120
121/* generates a random number on [0,1]-real-interval */
122double genrand_real1(void)
123{
124 return genrand_int32()*(1.0/4294967295.0);
125 /* divided by 2^32-1 */
126}
127
128/* generates a random number on [0,1)-real-interval */
129double genrand_real2(void)
130{
131 return genrand_int32()*(1.0/4294967296.0);
132 /* divided by 2^32 */
133}
134
135/* generates a random number on (0,1)-real-interval */
136double genrand_real3(void)
137{
138 return (((double)genrand_int32()) + 0.5)*(1.0/4294967296.0);
139 /* divided by 2^32 */
140}
141
142/* generates a random number on [0,1) with 53-bit resolution*/
143double genrand_res53(void)
144{
145 unsigned long a=genrand_int32()>>5, b=genrand_int32()>>6;
146 return(a*67108864.0+b)*(1.0/9007199254740992.0);
147}
148/* These real versions are due to Isaku Wada, 2002/01/09 added */
149
150#ifdef MT_TEST
151int main(void)
152{
153 int i;
154 unsigned long init[4]={0x123, 0x234, 0x345, 0x456}, length=4;
155 init_by_array(init, length);
156 printf("1000 outputs of genrand_int32()\n");
157 for (i=0; i<1000; i++) {
158 printf("%10lu ", genrand_int32());
159 if (i%5==4) printf("\n");
160 }
161 printf("\n1000 outputs of genrand_real2()\n");
162 for (i=0; i<1000; i++) {
163 printf("%10.8f ", genrand_real2());
164 if (i%5==4) printf("\n");
165 }
166 return 0;
167}
168#endif
#define N
Definition: mt19937ar.cxx:23
static int mti
Definition: mt19937ar.cxx:30
Definition: mt19937ar.cxx:78
#define MATRIX_A
Definition: mt19937ar.cxx:25
#define UPPER_MASK
Definition: mt19937ar.cxx:26
#define LOWER_MASK
Definition: mt19937ar.cxx:27
Definition: mt19937ar.cxx:129
#define M
Definition: mt19937ar.cxx:24
Definition: mt19937ar.cxx:33
long genrand_int31(void)
Definition: mt19937ar.cxx:116
Definition: mt19937ar.cxx:136
Definition: mt19937ar.cxx:52
Definition: mt19937ar.cxx:143
Definition: mt19937ar.cxx:122
Definition: mt19937ar.cxx:29
int main(void)
Definition: satest.cxx:22
