mt19937ar.cxx File Reference
#include <stdio.h>
Include dependency graph for mt19937ar.cxx:
#define N   624
#define M   397
#define MATRIX_A   0x9908b0dfUL /* constant vector a */
#define UPPER_MASK   0x80000000UL /* most significant w-r bits */
#define LOWER_MASK   0x7fffffffUL /* least significant r bits */
void init_genrand (unsigned long s)
void init_by_array (unsigned long init_key[], int key_length)
unsigned long genrand_int32 (void)
long genrand_int31 (void)
double genrand_real1 (void)
double genrand_real2 (void)
double genrand_real3 (void)
double genrand_res53 (void)
Variables
static unsigned long mt [N]
static int mti =N+1
◆ LOWER_MASK
Definition at line 27 of file mt19937ar.cxx.
◆ M
#define M   397
Definition at line 24 of file mt19937ar.cxx.
◆ MATRIX_A
Definition at line 25 of file mt19937ar.cxx.
◆ N
#define N   624
Definition at line 23 of file mt19937ar.cxx.
◆ UPPER_MASK
Definition at line 26 of file mt19937ar.cxx.
◆ genrand_int31()
long genrand_int31 ( void  )
Definition at line 116 of file mt19937ar.cxx.
117{
118 return (long)(genrand_int32()>>1);
119}
unsigned long genrand_int32(void)
Definition: mt19937ar.cxx:78
References genrand_int32().
◆ genrand_int32()
unsigned long genrand_int32 ( void  )
Definition at line 78 of file mt19937ar.cxx.
79{
80 unsigned long y;
81 static unsigned long mag01[2]={0x0UL, MATRIX_A};
82 /* mag01[x] = x * MATRIX_A for x=0,1 */
83
84 if (mti >= N) { /* generate N words at one time */
85 int kk;
86
87 if (mti == N+1) /* if init_genrand() has not been called, */
88 init_genrand(5489UL); /* a default initial seed is used */
89
90 for (kk=0;kk<N-M;kk++) {
91 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK);
92 mt[kk] = mt[kk+M] ^ (y >> 1) ^ mag01[y & 0x1UL];
93 }
94 for (;kk<N-1;kk++) {
95 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK);
96 mt[kk] = mt[kk+(M-N)] ^ (y >> 1) ^ mag01[y & 0x1UL];
97 }
98 y = (mt[N-1]&UPPER_MASK)|(mt[0]&LOWER_MASK);
99 mt[N-1] = mt[M-1] ^ (y >> 1) ^ mag01[y & 0x1UL];
100
101 mti = 0;
102 }
103
104 y = mt[mti++];
105
106 /* Tempering */
107 y ^= (y >> 11);
108 y ^= (y << 7) & 0x9d2c5680UL;
109 y ^= (y << 15) & 0xefc60000UL;
110 y ^= (y >> 18);
111
112 return y;
113}
#define N
Definition: mt19937ar.cxx:23
static int mti
Definition: mt19937ar.cxx:30
#define MATRIX_A
Definition: mt19937ar.cxx:25
#define UPPER_MASK
Definition: mt19937ar.cxx:26
#define LOWER_MASK
Definition: mt19937ar.cxx:27
#define M
Definition: mt19937ar.cxx:24
void init_genrand(unsigned long s)
Definition: mt19937ar.cxx:33
static unsigned long mt[N]
Definition: mt19937ar.cxx:29
References init_genrand(), LOWER_MASK, M, MATRIX_A, mt, mti, N, and UPPER_MASK.
Referenced by genrand_int31(), genrand_real1(), genrand_real2(), genrand_real3(), and genrand_res53().
◆ genrand_real1()
double genrand_real1 ( void  )
Definition at line 122 of file mt19937ar.cxx.
123{
124 return genrand_int32()*(1.0/4294967295.0);
125 /* divided by 2^32-1 */
126}
Referenced by Sphere::fill(), and Cube::tire().
◆ genrand_real2()
double genrand_real2 ( void  )
Definition at line 129 of file mt19937ar.cxx.
130{
131 return genrand_int32()*(1.0/4294967296.0);
132 /* divided by 2^32 */
133}
◆ genrand_real3()
double genrand_real3 ( void  )
Definition at line 136 of file mt19937ar.cxx.
137{
138 return (((double)genrand_int32()) + 0.5)*(1.0/4294967296.0);
139 /* divided by 2^32 */
140}
Referenced by randGauss().
◆ genrand_res53()
double genrand_res53 ( void  )
Definition at line 143 of file mt19937ar.cxx.
144{
145 unsigned long a=genrand_int32()>>5, b=genrand_int32()>>6;
146 return(a*67108864.0+b)*(1.0/9007199254740992.0);
147}
References gui.CONNECTOR::a, gui.CONNECTOR::b, and genrand_int32().
◆ init_by_array()
void init_by_array ( unsigned long  init_key[],
int  key_length
Definition at line 52 of file mt19937ar.cxx.
53{
54 int i, j, k;
55 init_genrand(19650218UL);
56 i=1; j=0;
57 k = (N>key_length ? N : key_length);
58 for (; k; k--) {
59 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1664525UL))
60 + init_key[j] + j; /* non linear */
61 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */
62 i++; j++;
63 if (i>=N) { mt[0] = mt[N-1]; i=1; }
64 if (j>=key_length) j=0;
65 }
66 for (k=N-1; k; k--) {
67 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1566083941UL))
68 - i; /* non linear */
69 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */
70 i++;
71 if (i>=N) { mt[0] = mt[N-1]; i=1; }
72 }
73
74 mt[0] = 0x80000000UL; /* MSB is 1; assuring non-zero initial array */
75}
References yacsorb.CORBAEngineTest::i, init_genrand(), mt, and N.
Referenced by initrand().
◆ init_genrand()
void init_genrand ( unsigned long  s)
Definition at line 33 of file mt19937ar.cxx.
34{
35 mt[0]= s & 0xffffffffUL;
36 for (mti=1; mti<N; mti++) {
37 mt[mti] =
38 (1812433253UL * (mt[mti-1] ^ (mt[mti-1] >> 30)) + mti);
39 /* See Knuth TAOCP Vol2. 3rd Ed. P.106 for multiplier. */
40 /* In the previous versions, MSBs of the seed affect */
41 /* only MSBs of the array mt[]. */
42 /* 2002/01/09 modified by Makoto Matsumoto */
43 mt[mti] &= 0xffffffffUL;
44 /* for >32 bit machines */
45 }
46}
References mt, mti, and N.
Referenced by genrand_int32(), and init_by_array().
Variable Documentation
◆ mt
unsigned long mt[N]
Definition at line 29 of file mt19937ar.cxx.
Referenced by genrand_int32(), init_by_array(), and init_genrand().
◆ mti
int mti =N+1
Definition at line 30 of file mt19937ar.cxx.
Referenced by genrand_int32(), and init_genrand().
