gui.CONNECTOR.CONNECTOR Class Reference
def __init__ (self)
def Connect (self, object, channel, function, args)
def Disconnect (self, object, channel, function, args)
def Emit (self, object, channel, *args)
Public Attributes
 connections
Definition at line 46 of file CONNECTOR.py.
◆ __init__()
def gui.CONNECTOR.CONNECTOR.__init__ (   self)
Definition at line 48 of file CONNECTOR.py.
48 def __init__(self):
49 self.connections={}
50
◆ Connect()
def gui.CONNECTOR.CONNECTOR.Connect (   self,
  object,
  channel,
  function,
  args
Definition at line 51 of file CONNECTOR.py.
51 def Connect(self, object, channel, function, args):
52
53 idx = id(object)
54 if idx in self.connections:
55 channels = self.connections[idx]
56 else:
57 channels = self.connections[idx] = {}
58
59 if channel in channels:
60 receivers = channels[channel]
61 else:
62 receivers = channels[channel] = []
63
64 for funct,fargs in receivers[:]:
65 if funct() is None:
66 receivers.remove((funct,fargs))
67 elif (function,args) == (funct(),fargs):
68 receivers.remove((funct,fargs))
69
70 receivers.append((ref(function),args))
71
72
73
Definition: CONNECTOR.py:120
References gui.CONNECTOR.CONNECTOR.connections, and gui.CONNECTOR.ref().
◆ Disconnect()
def gui.CONNECTOR.CONNECTOR.Disconnect (   self,
  object,
  channel,
  function,
  args
Definition at line 74 of file CONNECTOR.py.
74 def Disconnect(self, object, channel, function, args):
75 try:
76 receivers = self.connections[id(object)][channel]
77 except KeyError:
78 raise ConnectorError('no receivers for channel %s of %s' % (channel, object))
79
80 for funct,fargs in receivers[:]:
81 if funct() is None:
82 receivers.remove((funct,fargs))
83
84 for funct,fargs in receivers:
85 if (function,args) == (funct(),fargs):
86 receivers.remove((funct,fargs))
87 if not receivers:
88 # the list of receivers is empty now, remove the channel
89 channels = self.connections[id(object)]
90 del channels[channel]
91 if not channels:
92 # the object has no more channels
93 del self.connections[id(object)]
94 return
95
96 raise ConnectorError('receiver %s%s is not connected to channel %s of %s' \
97 % (function, args, channel, object))
98
99
References gui.CONNECTOR.CONNECTOR.connections.
◆ Emit()
def gui.CONNECTOR.CONNECTOR.Emit (   self,
  object,
  channel,
*  args
Definition at line 100 of file CONNECTOR.py.
100 def Emit(self, object, channel, *args):
101
102 try:
103 receivers = self.connections[id(object)][channel]
104 except KeyError:
105 return
106
109 for rfunc, fargs in copy(receivers):
110 try:
111 func=rfunc()
112 if func:
113 func(*args + fargs)
114 else:
115 # Le receveur a disparu
116 if (rfunc,fargs) in receivers:receivers.remove((rfunc,fargs))
117 except:
118 traceback.print_exc()
119
◆ connections
