YACS::ENGINE::VisitorSalomeSaveState Class Reference
#include <VisitorSalomeSaveState.hxx>
Inheritance diagram for YACS::ENGINE::VisitorSalomeSaveState:
Collaboration diagram for YACS::ENGINE::VisitorSalomeSaveState:
 VisitorSalomeSaveState (ComposedNode *root)
virtual ~VisitorSalomeSaveState ()
virtual void visitForEachLoop (ForEachLoop *node)
- Public Member Functions inherited from YACS::ENGINE::VisitorSaveState
 VisitorSaveState (ComposedNode *root)
virtual ~VisitorSaveState ()
void openFileDump (const std::string &xmlDump)
void closeFileDump ()
virtual void visitBloc (Bloc *node)
virtual void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node) override
void visitForEachLoopDyn (ForEachLoopDyn *node) override
virtual void visitOptimizerLoop (OptimizerLoop *node)
virtual void visitDynParaLoop (DynParaLoop *node)
virtual void visitForLoop (ForLoop *node)
virtual void visitInlineNode (InlineNode *node)
virtual void visitInlineFuncNode (InlineFuncNode *node)
virtual void visitLoop (Loop *node)
virtual void visitProc (Proc *node)
virtual void visitServiceNode (ServiceNode *node)
virtual void visitServerNode (ServerNode *node)
virtual void visitServiceInlineNode (ServiceInlineNode *node)
virtual void visitSwitch (Switch *node)
virtual void visitWhileLoop (WhileLoop *node)
virtual void visitPresetNode (DataNode *node)
virtual void visitOutNode (DataNode *node)
virtual void visitStudyInNode (DataNode *node)
virtual void visitStudyOutNode (DataNode *node)
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
- Protected Member Functions inherited from YACS::ENGINE::Visitor
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
- Protected Attributes inherited from YACS::ENGINE::VisitorSaveState
std::ofstream _out
std::map< int, std::string > _nodeStateName
ComposedNode * _root
Definition at line 31 of file VisitorSalomeSaveState.hxx.
◆ VisitorSalomeSaveState()
VisitorSalomeSaveState::VisitorSalomeSaveState ( ComposedNode *  root)
Definition at line 31 of file VisitorSalomeSaveState.cxx.
33{
34}
VisitorSaveState(ComposedNode *root)
◆ ~VisitorSalomeSaveState()
VisitorSalomeSaveState::~VisitorSalomeSaveState ( )
Definition at line 36 of file VisitorSalomeSaveState.cxx.
37{
38}
◆ visitForEachLoop()
void VisitorSalomeSaveState::visitForEachLoop ( ForEachLoop *  node)
Reimplemented from YACS::ENGINE::VisitorSaveState.
Definition at line 40 of file VisitorSalomeSaveState.cxx.
41{
42 node->ComposedNode::accept(this);
43 if (!_out) throw Exception("No file open for dump state");
44 std::string name = _root->getName();
45 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
46 DEBTRACE("VisitorSaveState::visitForEachLoop ------ " << name);
47 _out << " <node type='forEachLoop'>" << std::endl;
48 _out << " <name>" << name << "</name>" << std::endl;
49 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << std::endl;
50// VisitorSaveState::visitForEachLoop(node);
51 std::list<InputPort *> setOfInputPort = node->getLocalInputPorts();
52 std::list<InputPort *>::iterator iter;
53 for(iter = setOfInputPort.begin(); iter != setOfInputPort.end(); iter++)
54 {
55 _out << " <inputPort>" << std::endl;
56 _out << " <name>" << (*iter)->getName() << "</name>" << std::endl;
57 try
58 {
59 _out << " ";
60 _out << (*iter)->dump();
61 }
62 catch (YACS::Exception &e)
63 {
64 DEBTRACE("caught YACS:Exception: " << e.what());
65 _out << "<value><error><![CDATA[" << e.what() << "]]></error></value>" << std::endl;
66 }
67 _out << " </inputPort>" << std::endl;
68 }
69
71 if(YACS::LOADED == state ||
75 YACS::PAUSE == state ||
80 {
81 ForEachLoopPassedData* processedData = node->getProcessedData();
82 if(processedData)
83 {
84 const std::vector<unsigned int>& processedIndexes = processedData->getIds();
85 std::vector<SequenceAny *>::const_iterator it_outputs;
86 std::vector<std::string>::const_iterator it_names;
87
88 for(it_outputs = processedData->getOutputs().begin(), it_names = processedData->getOutputNames().begin();
89 it_names != processedData->getOutputNames().end();
90 it_outputs++, it_names++)
91 {
92 _out << " <loopOutputPort>" << std::endl;
93 _out << " <name>" << (*it_names) << "</name>" << std::endl;
94 for(unsigned int i = 0; i < (*it_outputs)->size(); i++)
95 {
96 AnyPtr value = (*(*it_outputs))[i];
97 _out << " <sample><index>" << processedIndexes[i]<< "</index>";
98 if(value)
99 _out << convertNeutralXml(value->getType(), value);
100 else
101 _out << "<value>None</value>";
102 _out << " </sample>" << std::endl;
103 }
104 _out << " </loopOutputPort>" << std::endl;
105 }
106
107 delete processedData;
108 processedData = NULL;
109 }
110 }
111 _out << " </node>" << std::endl;
112}
: Allow to manage memory of instances of T. The only constraint on T is to have method incrRef and De...
Definition: SharedPtr.hxx:30
std::string getName() const
std::list< InputPort * > getLocalInputPorts() const
redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself
ForEachLoopPassedData * getProcessedData() const
const std::vector< unsigned int > & getIds() const
const std::vector< std::string > & getOutputNames() const
const std::vector< SequenceAny * > & getOutputs() const
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
Definition: Visitor.hxx:85
const char * what(void) const noexcept
Definition: Exception.cxx:50
std::string convertNeutralXml(const TypeCode *t, YACS::ENGINE::Any *data)
StatesForNode
Definition: define.hxx:34
@ FAILED
Definition: define.hxx:51
@ EXECFAILED
Definition: define.hxx:46
@ LOADED
Definition: define.hxx:39
@ ACTIVATED
Definition: define.hxx:41
@ INTERNALERR
Definition: define.hxx:49
@ SUSPENDED
Definition: define.hxx:44
@ PAUSE
Definition: define.hxx:47
@ TORECONNECT
Definition: define.hxx:48
@ ERROR
Definition: define.hxx:52
References YACS::ENGINE::VisitorSaveState::_nodeStateName, YACS::ENGINE::VisitorSaveState::_out, YACS::ENGINE::Visitor::_root, YACS::ACTIVATED, YACS::ENGINE::convertNeutralXml(), DEBTRACE, YACS::ERROR, YACS::EXECFAILED, YACS::FAILED, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ForEachLoopPassedData::getIds(), YACS::ENGINE::ForEachLoopGen::getLocalInputPorts(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ForEachLoopPassedData::getOutputNames(), YACS::ENGINE::ForEachLoopPassedData::getOutputs(), YACS::ENGINE::ForEachLoopGen::getProcessedData(), YACS::ENGINE::Node::getState(), yacsorb.CORBAEngineTest::i, YACS::INTERNALERR, YACS::LOADED, YACS::PAUSE, yacsorb.CORBAEngineTest::state, YACS::SUSPENDED, YACS::TORECONNECT, and YACS::Exception::what().
