YACS::ENGINE::ConditionInputPort Class Reference
#include <ConditionInputPort.hxx>
Inheritance diagram for YACS::ENGINE::ConditionInputPort:
Collaboration diagram for YACS::ENGINE::ConditionInputPort:
void exSaveInit ()
void exRestoreInit ()
bool isLinkedOutOfScope () const
void edNotifyReferencedBy (OutPort *fromPort, bool isLoopProof) override
void * get () const
void put (Any *data)
void releaseData () override
std::string dump ()
bool getValue () const
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Any * _value
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
 ConditionInputPort (const std::string &name, WhileLoop *node)
 ConditionInputPort (const ConditionInputPort &other, Node *newHelder)
virtual ~ConditionInputPort ()
OutPort * _outOfScopeBackLink
Friends
class WhileLoop
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 32 of file ConditionInputPort.hxx.
◆ ConditionInputPort() [1/2]
ConditionInputPort::ConditionInputPort ( const std::string &  name,
WhileLoop *  node
Definition at line 29 of file ConditionInputPort.cxx.
29 :InputPort(name,node,Runtime::_tc_bool),
30 DataPort(name,node,Runtime::_tc_bool),
32{
33}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
Referenced by clone().
◆ ConditionInputPort() [2/2]
ConditionInputPort::ConditionInputPort ( const ConditionInputPort &  other,
Node *  newHelder
Definition at line 35 of file ConditionInputPort.cxx.
35 :InputPort(other,newHelder),
36 DataPort(other,newHelder),Port(other,newHelder),
38{
39 if(other._value)
40 _value=other._value->clone();
41}
virtual Any * clone() const =0
References _value, and YACS::ENGINE::Any::clone().
◆ ~ConditionInputPort()
ConditionInputPort::~ConditionInputPort ( )
privatevirtual
Definition at line 43 of file ConditionInputPort.cxx.
44{
45 if(_value)
46 _value->decrRef();
47}
References _value, and YACS::ENGINE::RefCounter::decrRef().
◆ clone()
InputPort * ConditionInputPort::clone ( Node *  newHelder) const
privatevirtual
Implements YACS::ENGINE::InputPort.
Definition at line 66 of file ConditionInputPort.cxx.
67{
68 return new ConditionInputPort(*this,newHelder);
69}
ConditionInputPort(const std::string &name, WhileLoop *node)
References ConditionInputPort().
◆ dump()
std::string ConditionInputPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 121 of file ConditionInputPort.cxx.
122{
123 string xmldump;
124 if (_value->getBoolValue())
125 xmldump="<value><boolean>true</boolean></value>\n";
126 else
127 xmldump="<value><boolean>false</boolean></value>\n";
128 return xmldump;
129}
virtual bool getBoolValue() const =0
References _value, and YACS::ENGINE::Any::getBoolValue().
◆ edNotifyDereferencedBy()
void ConditionInputPort::edNotifyDereferencedBy ( OutPort *  fromPort)
Reimplemented from YACS::ENGINE::InPort.
Definition at line 87 of file ConditionInputPort.cxx.
88{
89 if(fromPort==_outOfScopeBackLink)
91 else
92 if(!((ComposedNode*)(_node))->isInMyDescendance(fromPort->getNode()))
93 throw Exception("ConditionInputPort::edNotifyDereferencedBy link does not exists");
95}
virtual void edNotifyDereferencedBy(OutPort *fromPort)
Definition: InPort.cxx:102
Node * getNode() const
Definition: Port.hxx:46
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, _outOfScopeBackLink, YACS::ENGINE::InPort::edNotifyDereferencedBy(), and YACS::ENGINE::Port::getNode().
◆ edNotifyReferencedBy()
void ConditionInputPort::edNotifyReferencedBy ( OutPort *  fromPort,
bool  isLoopProof
overridevirtual
[in]isLoopProof- Tells if the data coming from fromPort will be send again in case of this is initialized. This value is important if this is an InPort of a Node contained directly or not inside a Loop, ForEachLoop, OptimizerLoop. In this case, to optimize memory consumption (see squeezeMemory method), we need to know if data coming from fromPort will be generated again in case. If true (the default) it means that for that link is a link loop proof so no need to take care. If false, the link is not loop proof so event in the context of agressive memory management the data can't be safely released.
Definition at line 76 of file ConditionInputPort.cxx.
77{
78 if(!((ComposedNode*)(_node))->isInMyDescendance(fromPort->getNode()))
79 {
81 throw Exception("ConditionInputPort::edNotifyReferenced : already linked from outside");
82 _outOfScopeBackLink=fromPort;
83 }
84 InputPort::edNotifyReferencedBy(fromPort,isLoopProof);
85}
virtual void edNotifyReferencedBy(OutPort *fromPort, bool isLoopProof=true)
Definition: InPort.cxx:93
References YACS::ENGINE::Port::_node, _outOfScopeBackLink, YACS::ENGINE::InPort::edNotifyReferencedBy(), and YACS::ENGINE::Port::getNode().
◆ exRestoreInit()
void ConditionInputPort::exRestoreInit ( )
◆ exSaveInit()
void ConditionInputPort::exSaveInit ( )
◆ get()
void * ConditionInputPort::get ( ) const
Definition at line 97 of file ConditionInputPort.cxx.
98{
99 return (void *)_value;
100}
References _value.
◆ getAsString()
std::string ConditionInputPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 131 of file ConditionInputPort.cxx.
132{
133 return (getValue() ? "True" : "False");
134}
References getValue().
◆ getValue()
bool YACS::ENGINE::ConditionInputPort::getValue ( ) const
◆ isLinkedOutOfScope()
bool ConditionInputPort::isLinkedOutOfScope ( ) const
Definition at line 71 of file ConditionInputPort.cxx.
72{
73 return _outOfScopeBackLink!=0;
74}
References _outOfScopeBackLink.
Referenced by YACS::ENGINE::WhileLoop::exUpdateState().
◆ put() [1/2]
void ConditionInputPort::put ( Any *  data)
◆ put() [2/2]
void ConditionInputPort::put ( const void *  data)
Definition at line 102 of file ConditionInputPort.cxx.
103{
104 put((Any*)data);
105}
Definition: Any.hxx:79
References put().
Referenced by put().
◆ releaseData()
void ConditionInputPort::releaseData ( )
overridevirtual
Definition at line 107 of file ConditionInputPort.cxx.
108{
109 if(_value)
110 _value->decrRef();
111 _value=nullptr;
112}
◆ typeName()
virtual std::string YACS::ENGINE::ConditionInputPort::typeName ( )
Definition at line 57 of file ConditionInputPort.hxx.
57{return "YACS__ENGINE__ConditionInputPort";}
◆ WhileLoop
friend class WhileLoop
friend
Definition at line 34 of file ConditionInputPort.hxx.
◆ _outOfScopeBackLink
OutPort* YACS::ENGINE::ConditionInputPort::_outOfScopeBackLink
◆ _value
Any* YACS::ENGINE::ConditionInputPort::_value
