Dispatcher.cxx
20#include "Dispatcher.hxx"
21#include "Node.hxx"
22#include <iostream>
23
24//#define _DEVDEBUG_
25#include "YacsTrace.hxx"
26
27using namespace YACS::ENGINE;
28
29Observer::~Observer()
30{
31}
32
33void Observer::notifyObserver(Node* object, const std::string& event)
34{
35 DEBTRACE("notifyObserver " << event << object );
36}
37
38void Observer::notifyObserver2(Node* object,const std::string& event, void *something)
39{
40 DEBTRACE("notifyObserver2 " << event << object );
41}
42
43void Observer::notifyObserverFromClone(Node *originalInstance, const std::string& event, Node *clonedInstanceGeneratingEvent)
44{
45 DEBTRACE("notifyObserverFromClone " << event << originalInstance );
46}
47
49
51{
53}
54
56{
58 {
60 }
62}
63
65{
67}
68
70{
71 std::cerr << "Dispatcher::printObservers " << std::endl;
72 typedef std::map< std::pair<Node*,std::string> , std::set<Observer*> >::iterator it;
73 typedef std::set<Observer*>::iterator jt;
74
75 for(it i=_observers.begin();i!=_observers.end();i++)
76 {
77 std::cerr << "Node*: " << (*i).first.first << " event: " << (*i).first.second << std::endl;
78 for(jt j=(*i).second.begin();j!=(*i).second.end();j++)
79 {
80 std::cerr << "observer: " << *j << std::endl;
81 }
82 }
83}
84
85void Dispatcher::dispatch(Node* object, const std::string& event)
86{
87 DEBTRACE("Dispatcher::dispatch " << event );
88 std::pair<Node*,std::string> key(object,event);
89 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
90 if(it!=_observers.end())
91 {
92 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
93 {
94 (*iter)->notifyObserver(object,event);
95 }
96 }
97}
98
99void Dispatcher::dispatch2(Node* object,const std::string& event, void *something)
100{
101 std::pair<Node*,std::string> key(object,event);
102 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
103 if(it!=_observers.end())
104 {
105 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
106 {
107 (*iter)->notifyObserver2(object,event,something);
108 }
109 }
110}
111
112void Dispatcher::dispatchFromClone(Node *originalInstance, const std::string& event, Node *clonedInstanceGeneratingEvent)
113{
114 std::pair<Node*,std::string> key(originalInstance,event);
115 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
116 if(it!=_observers.end())
117 {
118 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
119 {
120 (*iter)->notifyObserverFromClone(originalInstance,event,clonedInstanceGeneratingEvent);
121 }
122 }
123}
124
125void Dispatcher::addObserver(Observer* observer,Node* object, const std::string& event)
126{
127 _observers[std::pair<Node*,std::string>(object,event)].insert(observer);
128// printObservers();
129}
130
131void Dispatcher::removeObserver(Observer* observer,Node* object, const std::string& event)
132{
133 _observers[std::pair<Node*,std::string>(object,event)].erase(observer);
134// printObservers();
135}
Base class for dispatcher in observer pattern.
Definition: Dispatcher.hxx:74
virtual void dispatchFromClone(Node *originalInstance, const std::string &event, Node *clonedInstanceGeneratingEvent)
Definition: Dispatcher.cxx:112
virtual void printObservers()
Definition: Dispatcher.cxx:69
virtual void addObserver(Observer *observer, Node *object, const std::string &event)
Definition: Dispatcher.cxx:125
static Dispatcher * _singleton
Definition: Dispatcher.hxx:87
virtual void dispatch(Node *object, const std::string &event)
Definition: Dispatcher.cxx:85
std::map< std::pair< Node *, std::string >, std::set< Observer * > > _observers
Definition: Dispatcher.hxx:86
virtual void removeObserver(Observer *observer, Node *object, const std::string &event)
Definition: Dispatcher.cxx:131
static Dispatcher * getDispatcher()
Definition: Dispatcher.cxx:55
virtual void dispatch2(Node *object, const std::string &event, void *something)
Definition: Dispatcher.cxx:99
static void setDispatcher(Dispatcher *dispatcher)
Definition: Dispatcher.cxx:64
Base class for all nodes.
Definition: Node.hxx:70
Base class for observer in observer pattern.
Definition: Dispatcher.hxx:46
virtual void notifyObserverFromClone(Node *originalInstance, const std::string &event, Node *clonedInstanceGeneratingEvent)
Definition: Dispatcher.cxx:43
virtual void notifyObserver(Node *object, const std::string &event)
Definition: Dispatcher.cxx:33
virtual void notifyObserver2(Node *object, const std::string &event, void *something)
Definition: Dispatcher.cxx:38
dispatcher
Definition: CItems.py:28
