YACS::ENGINE::Dispatcher Class Reference
Base class for dispatcher in observer pattern. More...
#include <Dispatcher.hxx>
Inheritance diagram for YACS::ENGINE::Dispatcher:
Collaboration diagram for YACS::ENGINE::Dispatcher:
virtual void dispatch (Node *object, const std::string &event)
virtual void dispatch2 (Node *object, const std::string &event, void *something)
virtual void dispatchFromClone (Node *originalInstance, const std::string &event, Node *clonedInstanceGeneratingEvent)
virtual void addObserver (Observer *observer, Node *object, const std::string &event)
virtual void removeObserver (Observer *observer, Node *object, const std::string &event)
virtual void printObservers ()
virtual ~Dispatcher ()
static Dispatcher * getDispatcher ()
static void setDispatcher (Dispatcher *dispatcher)
std::map< std::pair< Node *, std::string >, std::set< Observer * > > _observers
Static Protected Attributes
static Dispatcher * _singleton = 0
Dispatcher and Observer objects can be used to be notified about events that occurs in editing or executing a calculation schema.
When an object wants to notify an event, it calls the dispatch method of the dispatcher with 2 arguments : the object reference and an event type. The dispatcher which is a singleton is obtained by calling the class method getDispatcher. The dispatcher notifies all the registered observers by calling their notifyObserver method.
Observers can be registered by calling the addObserver method with two arguments : an object reference and an event type. This observer will be notify with events coming only from this object.
Limitation : emitting objects can be only Node
Definition at line 73 of file Dispatcher.hxx.
◆ ~Dispatcher()
Dispatcher::~Dispatcher ( )
Definition at line 50 of file Dispatcher.cxx.
51{
53}
Definition: Dispatcher.hxx:87
References _singleton.
◆ addObserver()
void Dispatcher::addObserver ( Observer *  observer,
Node *  object,
const std::string &  event
Definition at line 125 of file Dispatcher.cxx.
126{
127 _observers[std::pair<Node*,std::string>(object,event)].insert(observer);
128// printObservers();
129}
Definition: Dispatcher.hxx:86
References _observers.
Referenced by DefineCustomObservers(), and YACS::HMI::SubjectNode::SubjectNode().
◆ dispatch()
void Dispatcher::dispatch ( Node *  object,
Reimplemented in YACS::ENGINE::SALOMEDispatcher, and MyDispatcher.
Definition at line 85 of file Dispatcher.cxx.
86{
87 DEBTRACE("Dispatcher::dispatch " << event );
88 std::pair<Node*,std::string> key(object,event);
89 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
90 if(it!=_observers.end())
91 {
92 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
93 {
94 (*iter)->notifyObserver(object,event);
95 }
96 }
97}
References _observers, and DEBTRACE.
Referenced by YACS::ENGINE::Executor::sendEvent(), and YACS::ENGINE::Node::sendEvent().
◆ dispatch2()
void Dispatcher::dispatch2 ( Node *  object,
const std::string &  event,
void *  something
Definition at line 99 of file Dispatcher.cxx.
100{
101 std::pair<Node*,std::string> key(object,event);
102 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
103 if(it!=_observers.end())
104 {
105 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
106 {
107 (*iter)->notifyObserver2(object,event,something);
108 }
109 }
110}
Referenced by YACS::ENGINE::Node::sendEvent2().
◆ dispatchFromClone()
void Dispatcher::dispatchFromClone ( Node *  originalInstance,
Node *  clonedInstanceGeneratingEvent
Definition at line 112 of file Dispatcher.cxx.
113{
114 std::pair<Node*,std::string> key(originalInstance,event);
115 std::map< std::pair<Node*,std::string> , std::set<Observer*> >::const_iterator it(_observers.find(key));
116 if(it!=_observers.end())
117 {
118 for(std::set<Observer*>::const_iterator iter=(*it).second.begin();iter!=(*it).second.end();iter++)
119 {
120 (*iter)->notifyObserverFromClone(originalInstance,event,clonedInstanceGeneratingEvent);
121 }
122 }
123}
Referenced by YACS::ENGINE::Node::sendEvent().
◆ getDispatcher()
Dispatcher * Dispatcher::getDispatcher ( )
Definition at line 55 of file Dispatcher.cxx.
56{
58 {
60 }
62}
Definition: Dispatcher.hxx:74
Referenced by Yacs_i::addObserver(), YACS::ENGINE::Executor::sendEvent(), YACS::ENGINE::Node::sendEvent(), and YACS::ENGINE::Node::sendEvent2().
◆ printObservers()
void Dispatcher::printObservers ( )
Definition at line 69 of file Dispatcher.cxx.
70{
71 std::cerr << "Dispatcher::printObservers " << std::endl;
72 typedef std::map< std::pair<Node*,std::string> , std::set<Observer*> >::iterator it;
73 typedef std::set<Observer*>::iterator jt;
74
75 for(it i=_observers.begin();i!=_observers.end();i++)
76 {
77 std::cerr << "Node*: " << (*i).first.first << " event: " << (*i).first.second << std::endl;
78 for(jt j=(*i).second.begin();j!=(*i).second.end();j++)
79 {
80 std::cerr << "observer: " << *j << std::endl;
81 }
82 }
83}
References _observers, and yacsorb.CORBAEngineTest::i.
◆ removeObserver()
void Dispatcher::removeObserver ( Observer *  observer,
Node *  object,
Definition at line 131 of file Dispatcher.cxx.
132{
133 _observers[std::pair<Node*,std::string>(object,event)].erase(observer);
134// printObservers();
135}
Referenced by PluginObserverKeeper::clean().
◆ setDispatcher()
void Dispatcher::setDispatcher ( Dispatcher *  dispatcher)
◆ _observers
std::map< std::pair<Node*,std::string> , std::set<Observer*> > YACS::ENGINE::Dispatcher::_observers
◆ _singleton
Dispatcher * Dispatcher::_singleton = 0
staticprotected
Definition at line 87 of file Dispatcher.hxx.
Referenced by getDispatcher(), setDispatcher(), and ~Dispatcher().
