SALOMEDispatcher.cxx
20#include "SALOMEDispatcher.hxx"
21#include "Node.hxx"
23#include <iostream>
24
25//#define _DEVDEBUG_
26#include "YacsTrace.hxx"
27
28using namespace std;
29using namespace YACS::BASES;
30using namespace YACS::ENGINE;
31
32map< pair<int,string> , set<YACS_ORB::Observer_ptr> > SALOMEDispatcher::_observers;
33SALOMEDispatcher* SALOMEDispatcher::_disp = 0;
34
35SALOMEDispatcher::SALOMEDispatcher()
36{
37}
38
40{
41}
42
44{
45 DEBTRACE("SALOMEDispatcher::setSALOMEDispatcher");
48}
49
51{
52 return _disp;
53}
54
55void SALOMEDispatcher::dispatch(Node* object, const std::string& event)
56{
57 DEBTRACE("SALOMEDispatcher::dispatch " << event << " " << object->getNumId());
58 CORBA::Long numId = object->getNumId();
59 typedef set<YACS_ORB::Observer_ptr>::iterator jt;
60 std::pair<int,std::string> key(numId, event);
61 for(jt iter = _observers[key].begin(); iter!=_observers[key].end(); iter++)
62 {
63 if (! CORBA::is_nil(*iter))
64 {
65 DEBTRACE("numId, event " << numId << " " << event );
66 (*iter)->notifyObserver(numId, event.c_str());
67 }
68 else
69 DEBTRACE("************************** dispatch on a CORBA::nil *******************************");
70 }
71}
72
73void SALOMEDispatcher::addObserver(YACS_ORB::Observer_ptr observer,
74 int numid,
75 std::string event)
76{
77 _observers[std::pair<int,std::string>(numid,event)].insert(YACS_ORB::Observer::_duplicate(observer));
78}
static void setDispatcher(Dispatcher *dispatcher)
Definition: Dispatcher.cxx:64
Base class for all nodes.
Definition: Node.hxx:70
static SALOMEDispatcher * _disp
void addObserver(YACS_ORB::Observer_ptr observer, int numid, std::string event)
void dispatch(Node *object, const std::string &event)
static SALOMEDispatcher * getSALOMEDispatcher()
static std::map< std::pair< int, std::string >, std::set< YACS_ORB::Observer_ptr > > _observers
