YACS::ENGINE::SALOMEDispatcher Class Reference
#include <SALOMEDispatcher.hxx>
Inheritance diagram for YACS::ENGINE::SALOMEDispatcher:
Collaboration diagram for YACS::ENGINE::SALOMEDispatcher:
 SALOMEDispatcher ()
void dispatch (Node *object, const std::string &event)
void addObserver (YACS_ORB::Observer_ptr observer, int numid, std::string event)
virtual ~SALOMEDispatcher ()
- Public Member Functions inherited from YACS::ENGINE::Dispatcher
virtual void dispatch (Node *object, const std::string &event)
virtual void dispatch2 (Node *object, const std::string &event, void *something)
virtual void dispatchFromClone (Node *originalInstance, const std::string &event, Node *clonedInstanceGeneratingEvent)
virtual void addObserver (Observer *observer, Node *object, const std::string &event)
virtual void removeObserver (Observer *observer, Node *object, const std::string &event)
virtual void printObservers ()
virtual ~Dispatcher ()
static void setSALOMEDispatcher ()
static SALOMEDispatcher * getSALOMEDispatcher ()
- Static Public Member Functions inherited from YACS::ENGINE::Dispatcher
static Dispatcher * getDispatcher ()
static void setDispatcher (Dispatcher *dispatcher)
static void * ThDisp (void *a)
Static Protected Attributes
static std::map< std::pair< int, std::string >, std::set< YACS_ORB::Observer_ptr > > _observers
static SALOMEDispatcher * _disp = 0
static YACS::BASES::Semaphore _s1
static std::list< std::pair< Node *, std::string > > _listOfEvents
- Static Protected Attributes inherited from YACS::ENGINE::Dispatcher
static Dispatcher * _singleton = 0
- Protected Attributes inherited from YACS::ENGINE::Dispatcher
std::map< std::pair< Node *, std::string >, std::set< Observer * > > _observers
Definition at line 38 of file SALOMEDispatcher.hxx.
◆ SALOMEDispatcher()
SALOMEDispatcher::SALOMEDispatcher ( )
Definition at line 35 of file SALOMEDispatcher.cxx.
36{
37}
Referenced by setSALOMEDispatcher().
◆ ~SALOMEDispatcher()
SALOMEDispatcher::~SALOMEDispatcher ( )
Definition at line 39 of file SALOMEDispatcher.cxx.
40{
41}
◆ addObserver()
void SALOMEDispatcher::addObserver ( YACS_ORB::Observer_ptr  observer,
int  numid,
std::string  event
Definition at line 73 of file SALOMEDispatcher.cxx.
76{
77 _observers[std::pair<int,std::string>(numid,event)].insert(YACS_ORB::Observer::_duplicate(observer));
78}
References _observers.
◆ dispatch()
void SALOMEDispatcher::dispatch ( Node *  object,
const std::string &  event
Reimplemented from YACS::ENGINE::Dispatcher.
Definition at line 55 of file SALOMEDispatcher.cxx.
56{
57 DEBTRACE("SALOMEDispatcher::dispatch " << event << " " << object->getNumId());
58 CORBA::Long numId = object->getNumId();
59 typedef set<YACS_ORB::Observer_ptr>::iterator jt;
60 std::pair<int,std::string> key(numId, event);
61 for(jt iter = _observers[key].begin(); iter!=_observers[key].end(); iter++)
62 {
63 if (! CORBA::is_nil(*iter))
64 {
65 DEBTRACE("numId, event " << numId << " " << event );
66 (*iter)->notifyObserver(numId, event.c_str());
67 }
68 else
69 DEBTRACE("************************** dispatch on a CORBA::nil *******************************");
70 }
71}
References _observers, and DEBTRACE.
◆ getSALOMEDispatcher()
SALOMEDispatcher * SALOMEDispatcher::getSALOMEDispatcher ( )
Definition at line 50 of file SALOMEDispatcher.cxx.
51{
52 return _disp;
53}
References _disp.
◆ setSALOMEDispatcher()
void SALOMEDispatcher::setSALOMEDispatcher ( )
Definition at line 43 of file SALOMEDispatcher.cxx.
44{
45 DEBTRACE("SALOMEDispatcher::setSALOMEDispatcher");
48}
static void setDispatcher(Dispatcher *dispatcher)
Definition: Dispatcher.cxx:64
References _disp, DEBTRACE, SALOMEDispatcher(), and YACS::ENGINE::Dispatcher::setDispatcher().
◆ ThDisp()
static void * YACS::ENGINE::SALOMEDispatcher::ThDisp ( void *  a)
staticprotected
◆ _disp
SALOMEDispatcher * SALOMEDispatcher::_disp = 0
staticprotected
Definition at line 49 of file SALOMEDispatcher.hxx.
Referenced by getSALOMEDispatcher(), and setSALOMEDispatcher().
◆ _listOfEvents
std::list< std::pair<Node*,std::string> > YACS::ENGINE::SALOMEDispatcher::_listOfEvents
staticprotected
Definition at line 52 of file SALOMEDispatcher.hxx.
◆ _observers
map< pair< int, string >, set< YACS_ORB::Observer_ptr > > SALOMEDispatcher::_observers
staticprotected
Definition at line 48 of file SALOMEDispatcher.hxx.
Referenced by addObserver(), and dispatch().
◆ _s1
YACS::BASES::Semaphore YACS::ENGINE::SALOMEDispatcher::_s1
staticprotected
Definition at line 51 of file SALOMEDispatcher.hxx.
