YACS::presetdatatypeParser Struct Reference
Class for presetdata parser. More...
#include <presetParsers.hxx>
Inheritance diagram for YACS::presetdatatypeParser:
Collaboration diagram for YACS::presetdatatypeParser:
virtual void type (const std::string &type)
virtual void ref (const std::string &ref)
virtual void pre ()
virtual void value (const std::string &value)
virtual myoutport & post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
myoutport _param
std::string _type
std::string _ref
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static presetdatatypeParser presetdataParser
static parser main_parser
Its XML schema is:
    <xsd:complexType name="PresetType">
      <xsd:attribute name="name" type="xsd:string" use="required"/>
      <xsd:attribute name="type" type="xsd:string" use="required"/>
      <xsd:element name="value" type="ValueType" minOccurs="1" maxOccurs="1"/>
    </xsd:complexType>
Definition at line 43 of file presetParsers.hxx.
◆ buildAttr()
virtual void YACS::presetdatatypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 65 of file presetParsers.hxx.
66 {
67 if (!attr)
68 return;
69 DEBTRACE("presetdatatypeParser::buildAttr");
70 required("name",attr);
71 required("type",attr);
72 for (int i = 0; attr[i]; i += 2)
73 {
74 if(std::string(attr[i]) == "name")name(attr[i+1]);
75 if(std::string(attr[i]) == "type")type(attr[i+1]);
76 if(std::string(attr[i]) == "ref")ref(attr[i+1]);
77 }
78 }
virtual void ref(const std::string &ref)
virtual void type(const std::string &type)
References DEBTRACE, yacsorb.CORBAEngineTest::i, name(), ref(), YACS::parser::required(), and type().
virtual void YACS::presetdatatypeParser::name ( const std::string &  name)
Definition at line 79 of file presetParsers.hxx.
80 {
81 DEBTRACE("presetdatatypeParser::name");
83 _name=name;
84 }
std::string _name
Definition: factory.hxx:80
References myinport::_name, _name, _param, DEBTRACE, and name().
Referenced by buildAttr(), and name().
◆ onEnd()
virtual void YACS::presetdatatypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 59 of file presetParsers.hxx.
60 {
61 DEBTRACE("presetdatatypeParser::onEnd");
62 std::string element(el);
63 if(element == "value")value(((valuetypeParser*)child)->post());
64 }
virtual void value(const std::string &value)
virtual myoutport & post()
References DEBTRACE, post(), and value().
◆ onStart()
virtual void YACS::presetdatatypeParser::onStart ( const XML_Char *  el,
Definition at line 47 of file presetParsers.hxx.
48 {
49 DEBTRACE("presetdatatypeParser::onStart");
50 std::string element(el);
51 this->maxcount("value",1,element);
53 if(element == "value")pp=&valuetypeParser::valueParser;
55 pp->init();
56 pp->pre();
57 pp->buildAttr(attr);
58 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
static valuetypeParser valueParser
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), and YACS::valuetypeParser::valueParser.
◆ post()
virtual myoutport & YACS::presetdatatypeParser::post ( )
Definition at line 108 of file presetParsers.hxx.
109 {
110 DEBTRACE("presetdatatypeParser::post");
111 //a parameter can have a ref attribute OR one value element
112 if(_ref == "undef")
113 mincount("value",1);
114 else
115 _param.setProperty("value",_ref);
116 return _param;
117 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
void setProperty(const std::string &name, const std::string &value)
Definition: factory.hxx:87
References _param, _ref, DEBTRACE, YACS::parser::mincount(), and myinport::setProperty().
Referenced by onEnd().
◆ pre()
virtual void YACS::presetdatatypeParser::pre ( )
Definition at line 97 of file presetParsers.hxx.
98 {
99 DEBTRACE("presetdatatypeParser::pre");
100 _ref="undef";
101 _param.clear();
102 }
void clear()
Definition: factory.hxx:83
References _param, _ref, myinport::clear(), and DEBTRACE.
◆ ref()
virtual void YACS::presetdatatypeParser::ref ( const std::string &  ref)
Definition at line 92 of file presetParsers.hxx.
93 {
94 _ref=ref;
95 }
References _ref, and ref().
Referenced by buildAttr(), and ref().
◆ type()
virtual void YACS::presetdatatypeParser::type ( const std::string &  type)
Definition at line 85 of file presetParsers.hxx.
86 {
87 DEBTRACE("presetdatatypeParser::type");
89 _type=type;
90 }
std::string _type
Definition: factory.hxx:81
References _param, myinport::_type, _type, DEBTRACE, and type().
Referenced by buildAttr(), and type().
◆ value()
virtual void YACS::presetdatatypeParser::value ( const std::string &  value)
Definition at line 103 of file presetParsers.hxx.
104 {
105 DEBTRACE("presetdatatypeParser::value " << value);
106 _param.setProperty("value",value);
107 }
References _param, DEBTRACE, myinport::setProperty(), and value().
Referenced by gui.panels.PanelInPort::handleRestore(), gui.panels.PanelOutPort::handleRestore(), gui.panels.PanelInPort::handleSave(), onEnd(), and value().
◆ _name
std::string YACS::presetdatatypeParser::_name
Definition at line 119 of file presetParsers.hxx.
Referenced by name().
◆ _param
myoutport YACS::presetdatatypeParser::_param
Definition at line 118 of file presetParsers.hxx.
Referenced by name(), post(), pre(), type(), and value().
◆ _ref
std::string YACS::presetdatatypeParser::_ref
Definition at line 121 of file presetParsers.hxx.
Referenced by post(), pre(), and ref().
◆ _type
std::string YACS::presetdatatypeParser::_type
Definition at line 120 of file presetParsers.hxx.
Referenced by type().
◆ presetdataParser
presetdatatypeParser YACS::presetdatatypeParser::presetdataParser
Definition at line 45 of file presetParsers.hxx.
Referenced by YACS::presettypeParser< T >::onStart().
