YACS::arraytypeParser Struct Reference
Class for XML-RPC array parser. More...
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::arraytypeParser:
Collaboration diagram for YACS::arraytypeParser:
virtual void pre ()
virtual void data (const std::string &d)
virtual std::string post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::vector< std::string > _arrays
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static arraytypeParser arrayParser
static parser main_parser
This class is used to parse XML data that describes a sequence in XML-RPC format
Its XML schema is:
  <xsd:complexType name="ArrayType">
    <xsd:element name="data" type="DataType" minOccurs="1" maxOccurs="1"/>
  </xsd:complexType>
Definition at line 149 of file xmlrpcParsers.hxx.
◆ data()
void YACS::arraytypeParser::data ( const std::string &  d)
Definition at line 206 of file xmlrpcParsers.cxx.
207 {
208 _arrays.push_back(d);
209 }
References _arrays.
Referenced by onEnd().
◆ onEnd()
void YACS::arraytypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 200 of file xmlrpcParsers.cxx.
201 {
202 std::string element(el);
203 if(element == "data")data(((datatypeParser*)child)->post());
204 }
virtual void data(const std::string &d)
virtual std::string post()
References data(), and post().
◆ onStart()
void YACS::arraytypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 189 of file xmlrpcParsers.cxx.
190 {
191 std::string element(el);
192 this->maxcount("data",1,element);
194 if(element == "data")pp=&datatypeParser::dataParser;
196 pp->init();
197 pp->pre();
198 pp->buildAttr(attr);
199 }
static datatypeParser dataParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), YACS::datatypeParser::dataParser, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
◆ post()
std::string YACS::arraytypeParser::post ( )
Definition at line 210 of file xmlrpcParsers.cxx.
211 {
212 mincount("data",1);
213 std::string value="<array>"+_arrays.back()+"</array>";
214 _arrays.pop_back();
215 return value;
216 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
References _arrays, and YACS::parser::mincount().
◆ pre()
void YACS::arraytypeParser::pre ( )
Definition at line 205 of file xmlrpcParsers.cxx.
205{ }
◆ _arrays
std::vector<std::string> YACS::arraytypeParser::_arrays
Definition at line 157 of file xmlrpcParsers.hxx.
Referenced by data(), and post().
◆ arrayParser
arraytypeParser YACS::arraytypeParser::arrayParser
Definition at line 151 of file xmlrpcParsers.hxx.
Referenced by YACS::valuetypeParser::onStart().
