YACS::structdatatypeParser Struct Reference
Class for XML-RPC struct parser. More...
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::structdatatypeParser:
Collaboration diagram for YACS::structdatatypeParser:
virtual void pre ()
virtual void member (const std::string &d)
virtual std::string post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _members
std::vector< std::string > _membersStack
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static structdatatypeParser structdataParser
static parser main_parser
This class is used to parse XML data that describes a sequence in XML-RPC format
Its XML schema is:
  <xsd:complexType name="StructDataType">
    <xsd:element name="member" type="MemberDataType" minOccurs="1"/>
  </xsd:complexType>
Definition at line 126 of file xmlrpcParsers.hxx.
◆ member()
void YACS::structdatatypeParser::member ( const std::string &  d)
Definition at line 177 of file xmlrpcParsers.cxx.
178 {
180 }
References _members.
Referenced by onEnd().
◆ onEnd()
void YACS::structdatatypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 167 of file xmlrpcParsers.cxx.
168 {
169 std::string element(el);
170 if(element == "member")member(((memberdatatypeParser*)child)->post());
171 }
virtual void member(const std::string &d)
virtual std::string post()
References member(), and post().
◆ onStart()
void YACS::structdatatypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 157 of file xmlrpcParsers.cxx.
158 {
159 std::string element(el);
161 if(element == "member")pp=&memberdatatypeParser::memberdataParser;
163 pp->init();
164 pp->pre();
165 pp->buildAttr(attr);
166 }
static memberdatatypeParser memberdataParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::memberdatatypeParser::memberdataParser, YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
◆ post()
std::string YACS::structdatatypeParser::post ( )
Definition at line 181 of file xmlrpcParsers.cxx.
182 {
183 std::string value="<struct>"+_members+"</struct>";
184 _members=_membersStack.back();
185 _membersStack.pop_back();
186 return value;
187 }
References _members, and _membersStack.
◆ pre()
void YACS::structdatatypeParser::pre ( )
Definition at line 172 of file xmlrpcParsers.cxx.
173 {
174 _membersStack.push_back(_members);
175 _members="";
176 }
◆ _members
std::string YACS::structdatatypeParser::_members
Definition at line 134 of file xmlrpcParsers.hxx.
Referenced by member(), post(), and pre().
◆ _membersStack
std::vector<std::string> YACS::structdatatypeParser::_membersStack
Definition at line 135 of file xmlrpcParsers.hxx.
Referenced by post(), and pre().
◆ structdataParser
structdatatypeParser YACS::structdatatypeParser::structdataParser
Definition at line 128 of file xmlrpcParsers.hxx.
Referenced by YACS::valuetypeParser::onStart().
