YACS::memberdatatypeParser Struct Reference
Class for XML-RPC member parser. More...
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::memberdatatypeParser:
Collaboration diagram for YACS::memberdatatypeParser:
virtual void pre ()
virtual void name (const std::string &v)
virtual void value (const std::string &v)
virtual std::string post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _data
std::vector< std::string > _datas
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static memberdatatypeParser memberdataParser
static parser main_parser
This class is used to parse XML data that describes a sequence in XML-RPC format
Its XML schema is:
  <xsd:complexType name="MemberDataType">
    <xsd:element name="name" type="StringType"/>
    <xsd:element name="value" type="ValueType"/>
  </xsd:complexType>
Definition at line 102 of file xmlrpcParsers.hxx.
void YACS::memberdatatypeParser::name ( const std::string &  v)
Definition at line 139 of file xmlrpcParsers.cxx.
140 {
141 _data=_data+"<name>"+v+"</name>";
142 }
References _data.
Referenced by onEnd().
◆ onEnd()
void YACS::memberdatatypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 126 of file xmlrpcParsers.cxx.
127 {
128 std::string element(el);
129 this->maxcount("name",1,element);
130 this->maxcount("value",1,element);
131 if(element == "name")name(((stringtypeParser*)child)->post());
132 else if(element == "value")value(((valuetypeParser*)child)->post());
133 }
virtual void name(const std::string &v)
virtual std::string post()
virtual void value(const std::string &v)
References YACS::parser::maxcount(), name(), post(), and value().
◆ onStart()
void YACS::memberdatatypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 115 of file xmlrpcParsers.cxx.
116 {
117 std::string element(el);
119 if(element == "name")pp=&stringtypeParser::stringParser;
120 else if(element == "value")pp=&valuetypeParser::valueParser;
122 pp->init();
123 pp->pre();
124 pp->buildAttr(attr);
125 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
static valuetypeParser valueParser
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), YACS::stringtypeParser::stringParser, and YACS::valuetypeParser::valueParser.
◆ post()
std::string YACS::memberdatatypeParser::post ( )
Definition at line 147 of file xmlrpcParsers.cxx.
148 {
149 mincount("value",1);
150 mincount("name",1);
151 std::string d="<member>\n"+_data+"</member>";
152 _data=_datas.back();
153 _datas.pop_back();
154 return d;
155 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
References _data, _datas, and YACS::parser::mincount().
◆ pre()
void YACS::memberdatatypeParser::pre ( )
Definition at line 134 of file xmlrpcParsers.cxx.
135 {
136 _datas.push_back(_data);
137 _data="";
138 }
References _data, and _datas.
◆ value()
void YACS::memberdatatypeParser::value ( const std::string &  v)
◆ _data
std::string YACS::memberdatatypeParser::_data
Definition at line 111 of file xmlrpcParsers.hxx.
Referenced by name(), post(), pre(), and value().
◆ _datas
std::vector<std::string> YACS::memberdatatypeParser::_datas
Definition at line 112 of file xmlrpcParsers.hxx.
Referenced by post(), and pre().
◆ memberdataParser
memberdatatypeParser YACS::memberdatatypeParser::memberdataParser
Definition at line 104 of file xmlrpcParsers.hxx.
Referenced by YACS::structdatatypeParser::onStart().
