typeParsers.cxx
20#include "typeParsers.hxx"
21#include "dataParsers.hxx"
22#include "Exception.hxx"
23#include "Proc.hxx"
24#include "Runtime.hxx"
26#include <sstream>
27
28//#define _DEVDEBUG_
29#include "YacsTrace.hxx"
30
33
34namespace YACS
35{
36 typetypeParser typetypeParser::typeParser;
37 seqtypeParser seqtypeParser::seqParser;
38 objtypeParser objtypeParser::objParser;
39 structtypeParser structtypeParser::structParser;
40 membertypeParser membertypeParser::memberParser;
41
43 {
44 if (!attr)
45 return;
46 required("name",attr);
47 required("kind",attr);
48 for (int i = 0; attr[i]; i += 2)
49 {
50 if(std::string(attr[i]) == "name")name(attr[i+1]);
51 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
52 }
53 }
55 void typetypeParser::name(const std::string& name)
56 {
57 DEBTRACE( "type_name: " << name )
58 _name=name;
59 }
60 void typetypeParser::kind(const std::string& name)
61 {
62 DEBTRACE( "type_kind: " << name )
63 _kind=name;
64 }
66 {
67 DEBTRACE( "type_post" )
68 mytype t;
69 t._kind=_kind;
70 t._name=_name;
71 return t;
72 }
73
74 void seqtypeParser::onStart(const XML_Char* el, const XML_Char** attr)
75 {
76 DEBTRACE( "seqtypeParser::onStart: " << el )
79 pp->init();
80 pp->pre();
81 pp->buildAttr(attr);
82 }
83 void seqtypeParser::onEnd(const char *el,parser* child)
84 {
85 DEBTRACE( "seqtypeParser::onEnd: " << el )
86 }
88 {
89 if (!attr)
90 return;
91 required("name",attr);
92 required("content",attr);
93 for (int i = 0; attr[i]; i += 2)
94 {
95 if(std::string(attr[i]) == "name")name(attr[i+1]);
96 if(std::string(attr[i]) == "content")content(attr[i+1]);
97 }
98 }
99 void seqtypeParser::name(const std::string& name)
100 {
101 DEBTRACE( "seqtype_name: " << name )
102 _name=name;
103 }
104 void seqtypeParser::content(const std::string& name)
105 {
106 DEBTRACE( "seqtype_content: " << name )
107 if(currentProc->typeMap.count(name)==0)
108 {
109 //Check if the typecode is defined in the runtime
111 if(t==0)
112 {
113 std::stringstream msg;
114 msg << "Type " << name << " does not exist" << " (" <<__FILE__ << ":" << __LINE__ << ")";
115 throw Exception(msg.str());
116 }
117 else
118 {
120 t->incrRef();
121 }
122 }
124
125 }
127 {
128 DEBTRACE( "seqtype_post" )
130 return t;
131 }
132
133 void objtypeParser::onStart(const XML_Char* el, const XML_Char** attr)
134 {
135 DEBTRACE( "objtypeParser::onStart: " << el )
136 std::string element(el);
138 if(element == "base")pp=&stringtypeParser::stringParser;
140 pp->init();
141 pp->pre();
142 pp->buildAttr(attr);
143 }
144 void objtypeParser::onEnd(const char *el,parser* child)
145 {
146 DEBTRACE( "objtypeParser::onEnd: " << el )
147 std::string element(el);
148 if(element == "base")base(((stringtypeParser*)child)->post());
149 }
151 {
152 if (!attr)
153 return;
154 required("name",attr);
155 for (int i = 0; attr[i]; i += 2)
156 {
157 if(std::string(attr[i]) == "name")name(attr[i+1]);
158 if(std::string(attr[i]) == "id")id(attr[i+1]);
159 }
160 }
162 {
163 _id="";
164 _ltc.clear();
165 }
166 void objtypeParser::name(const std::string& name)
167 {
168 DEBTRACE( "objtype_name: " << name )
169 _name=name;
170 }
171 void objtypeParser::id(const std::string& name)
172 {
173 DEBTRACE( "objtype_id: " << name )
174 _id=name;
175 }
176 void objtypeParser::base(const std::string& name)
177 {
178 DEBTRACE( "base_name: " << name )
179 if(currentProc->typeMap.count(name)==0)
180 {
181 //Check if the typecode is defined in the runtime
183 if(t==0)
184 {
185 std::stringstream msg;
186 msg << "Type " << name << " does not exist" << " (" <<__FILE__ << ":" << __LINE__ << ")";
187 throw Exception(msg.str());
188 }
189 else
190 {
192 t->incrRef();
193 }
194 }
195 if(currentProc->typeMap[name]->kind() != ENGINE::Objref)
196 {
197 std::stringstream msg;
198 msg << "Type " << name << " is not an objref" ;
199 msg << " (" <<__FILE__ << ":" << __LINE__ << ")";
200 throw Exception(msg.str());
201 }
203 }
205 {
206 DEBTRACE( "objtype_post" )
208 return t;
209 }
210
212 {
213 if (!attr)
214 return;
215 required("name",attr);
216 required("type",attr);
217 for (int i = 0; attr[i]; i += 2)
218 {
219 if(std::string(attr[i]) == "name")name(attr[i+1]);
220 if(std::string(attr[i]) == "type")type(attr[i+1]);
221 }
222 }
223 void membertypeParser::name(const std::string& name){ _prop._name=name; }
224 void membertypeParser::type(const std::string& name){ _prop._value=name; }
226
227 void structtypeParser::onStart(const XML_Char* el, const XML_Char** attr)
228 {
229 DEBTRACE( "structtypeParser::onStart: " << el )
230 std::string element(el);
232 if(element == "member")pp=&membertypeParser::memberParser;
234 pp->init();
235 pp->pre();
236 pp->buildAttr(attr);
237 }
238 void structtypeParser::onEnd(const char *el,parser* child)
239 {
240 DEBTRACE( "structtypeParser::onEnd: " << el )
241 std::string element(el);
242 if(element == "member")member(((membertypeParser*)child)->post());
243 }
245 {
246 if (!attr)
247 return;
248 required("name",attr);
249 for (int i = 0; attr[i]; i += 2)
250 {
251 if(std::string(attr[i]) == "name")name(attr[i+1]);
252 if(std::string(attr[i]) == "id")id(attr[i+1]);
253 }
254 }
256 {
257 _id="";
258 _members.clear();
259 }
260 void structtypeParser::name(const std::string& name)
261 {
262 DEBTRACE( "structtype_name: " << name );
263 _name=name;
264 }
265 void structtypeParser::id(const std::string& name)
266 {
267 DEBTRACE( "structtype_id: " << name );
268 _id=name;
269 }
271 {
272 DEBTRACE( "structtype_member: " << prop._name << prop._value );
273 if(currentProc->typeMap.count(prop._value)==0)
274 {
275 //Check if the typecode is defined in the runtime
277 if(t==0)
278 {
279 std::string msg="Unknown type " + prop._value + " for member " + prop._name + " in struct " + _name;
280 throw Exception(msg);
281 }
282 else
283 {
285 t->incrRef();
286 }
287 }
288
289 _members.push_back(prop);
290 }
292 {
293 DEBTRACE( "structtype_post" );
295 if(currentProc->typeMap.count(_name)!=0)
296 {
297 //reuse a forward declaration
299 if(tt->kind()==YACS::ENGINE::Struct)
300 {
302 }
303 else
304 {
305 std::string msg="Forward declaration must be a struct type but " + std::string(tt->name()) + " is not one" ;
306 throw Exception(msg);
307 }
308 }
309 else
310 {
312 }
313 std::vector<myprop>::const_iterator iter;
314 for(iter=_members.begin();iter!=_members.end();iter++)
315 {
316 DEBTRACE("member: " << iter->_name << " " <<iter->_value);
317 t->addMember(iter->_name,currentProc->typeMap[iter->_value]);
318 }
319 return t;
320 }
321}
322
Definition: Proc.hxx:44
virtual TypeCode * createSequenceTc(const std::string &id, const std::string &name, TypeCode *content)
Create a sequence TypeCode.
Definition: Proc.cxx:150
Definition: Proc.hxx:90
virtual TypeCode * createStructTc(const std::string &id, const std::string &name)
Definition: Proc.cxx:161
virtual TypeCode * createInterfaceTc(const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
Create an object reference TypeCode.
Definition: Proc.cxx:132
Definition: Runtime.cxx:333
Class for reference objects.
Definition: TypeCode.hxx:126
Class for struct type.
Definition: TypeCode.hxx:228
Definition: TypeCode.hxx:68
Definition: TypeCode.cxx:72
DynType kind() const
Definition: TypeCode.cxx:47
char XML_Char
Definition: parserBase.hxx:37
Class for member parser.
virtual void type(const std::string &name)
static membertypeParser memberParser
virtual void base(const std::string &name)
virtual void pre()
virtual void id(const std::string &name)
virtual YACS::ENGINE::TypeCode * post()
static objtypeParser objParser
std::list< YACS::ENGINE::TypeCodeObjref * > _ltc
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
Definition: parserBase.cxx:55
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
YACS::ENGINE::TypeCode * _contentType
Definition: typeParsers.hxx:78
Definition: typeParsers.cxx:87
void content(const std::string &name)
void name(const std::string &name)
Definition: typeParsers.cxx:99
static seqtypeParser seqParser
Definition: typeParsers.hxx:71
Definition: typeParsers.cxx:74
Definition: typeParsers.cxx:83
Class for string parser.
Definition: dataParsers.hxx:32
Definition: dataParsers.hxx:33
virtual void member(const myprop &prop)
static structtypeParser structParser
std::vector< myprop > _members
static typetypeParser typeParser
Definition: typeParsers.hxx:45
Definition: typeParsers.cxx:55
Definition: typeParsers.cxx:42
virtual mytype post()
Definition: typeParsers.cxx:65
virtual void pre()
Definition: typeParsers.cxx:54
Definition: typeParsers.cxx:60
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
