typeParsers.hxx
20#ifndef _TYPEPARSERS_HXX_
21#define _TYPEPARSERS_HXX_
23#include "parserBase.hxx"
24#include "TypeCode.hxx"
25#include "factory.hxx"
26
27namespace YACS
28{
44{
46 virtual void buildAttr(const XML_Char** attr);
47 virtual void pre ();
48 virtual void name(const std::string& name);
49 virtual void kind(const std::string& name);
50 virtual mytype post();
51 std::string _name;
52 std::string _kind;
53};
54
69struct seqtypeParser:public parser
70{
72 virtual void onStart(const XML_Char* el, const XML_Char** attr);
73 virtual void onEnd(const char *el,parser* child);
74 virtual void buildAttr(const XML_Char** attr);
75 void name(const std::string& name);
76 void content(const std::string& name);
79 std::string _name;
80};
81
99{
101 virtual void onStart(const XML_Char* el, const XML_Char** attr);
102 virtual void onEnd(const char *el,parser* child);
103 virtual void buildAttr(const XML_Char** attr);
104 virtual void pre ();
105 virtual void name(const std::string& name);
106 virtual void id(const std::string& name);
107 virtual void base(const std::string& name);
108 virtual YACS::ENGINE::TypeCode * post();
109 std::string _name;
110 std::string _id;
111 std::list<YACS::ENGINE::TypeCodeObjref *> _ltc;
112};
113
129{
131 virtual void buildAttr(const XML_Char** attr);
132 virtual void name(const std::string& name);
133 virtual void type(const std::string& name);
134 myprop post();
136};
137
155{
157
158 virtual void onStart(const XML_Char* el, const XML_Char** attr);
159 virtual void onEnd(const char *el,parser* child);
160 virtual void buildAttr(const XML_Char** attr);
161 virtual void pre ();
162 virtual void name(const std::string& name);
163 virtual void id(const std::string& name);
164 virtual void member (const myprop& prop);
165 virtual YACS::ENGINE::TypeCode * post();
166 std::string _name;
167 std::string _id;
168 std::vector<myprop> _members;
169};
170
171}
172
173#endif
Definition: TypeCode.hxx:68
char XML_Char
Definition: parserBase.hxx:37
Class for member parser.
virtual void type(const std::string &name)
static membertypeParser memberParser
Class for objref parser.
Definition: typeParsers.hxx:99
virtual void base(const std::string &name)
virtual void pre()
virtual void id(const std::string &name)
static objtypeParser objParser
std::list< YACS::ENGINE::TypeCodeObjref * > _ltc
Class for sequence parser.
Definition: typeParsers.hxx:70
YACS::ENGINE::TypeCode * _contentType
Definition: typeParsers.hxx:78
Definition: typeParsers.cxx:87
void content(const std::string &name)
void name(const std::string &name)
Definition: typeParsers.cxx:99
static seqtypeParser seqParser
Definition: typeParsers.hxx:71
Definition: typeParsers.cxx:74
Definition: typeParsers.cxx:83
Class for struct parser.
virtual void member(const myprop &prop)
static structtypeParser structParser
std::vector< myprop > _members
Class for type parser.
Definition: typeParsers.hxx:44
static typetypeParser typeParser
Definition: typeParsers.hxx:45
Definition: typeParsers.cxx:55
Definition: typeParsers.cxx:42
Definition: typeParsers.cxx:65
virtual void pre()
Definition: typeParsers.cxx:54
Definition: typeParsers.cxx:60
