Class for member parser. More...
#include <typeParsers.hxx>
| virtual void | buildAttr (const XML_Char **attr) |
| virtual void | name (const std::string &name) |
| virtual void | type (const std::string &name) |
| myprop | post () |
Public Member Functions inherited from YACS::parser | |
| parser () | |
| virtual | ~parser () |
| virtual void | SetUserDataAndPush (parser *pp) |
| virtual void | onStart (const XML_Char *el, const XML_Char **attr) |
| virtual void | onEnd (const XML_Char *el, parser *child) |
| virtual void | charData (const XML_Char *s, int len) |
| virtual void | endParser () |
| virtual void | init () |
| virtual void | incrCount (const XML_Char *elem) |
| virtual void | checkOrder (std::string &el) |
| virtual void | maxcount (std::string name, int max, std::string &el) |
| virtual void | mincount (std::string name, int min) |
| virtual void | maxchoice (std::string *names, int max, std::string &el) |
| virtual void | minchoice (std::string *names, int min) |
| virtual void | pre () |
| virtual void | required (const std::string &name, const XML_Char **attr) |
| std::stack< parser * > & | getStack () |
| template<class T > | |
| T | post () |
| void | logError (const std::string &reason) |
Public Attributes | |
| myprop | _prop |
Public Attributes inherited from YACS::parser | |
| std::string | _file |
| std::string | _content |
| std::map< std::string, int > * | _counts |
| std::map< std::string, int > | _orders |
| int | _orderState |
| int | _level |
| std::stack< std::map< std::string, int > * > | _stackCount |
| std::stack< int > | _stackOrder |
| std::map< std::string, parser * > * | _defaultParsersMap |
Static Public Attributes | |
| static membertypeParser | memberParser |
Static Public Attributes inherited from YACS::parser | |
| static parser | main_parser |
| static std::stack< parser * > | _stackParser |
Additional Inherited Members | |
Static Public Member Functions inherited from YACS::parser | |
| static void XMLCALL | start_document (void *data) |
| static void XMLCALL | end_document (void *data) |
| static void XMLCALL | start_element (void *data, const xmlChar *name, const xmlChar **p) |
| static void XMLCALL | end_element (void *data, const xmlChar *name) |
| static void XMLCALL | characters (void *data, const xmlChar *ch, int len) |
| static void XMLCALL | comment (void *data, const xmlChar *value) |
| static void XMLCALL | cdata_block (void *data, const xmlChar *value, int len) |
| static void XMLCALL | warning (void *data, const char *fmt,...) |
| static void XMLCALL | error (void *data, const char *fmt,...) |
| static void XMLCALL | fatal_error (void *data, const char *fmt,...) |
| static void | XML_SetUserData (_xmlParserCtxt *ctxt, parser *par) |
Class used to parse a struct member A struct member is a pair of name(string), type(string)
XML schema is
<xsd:complexType name="MemberType">
<xsd:attribute name="name" type="xsd:string" use="required"/>
<xsd:attribute name="type" type="xsd:string" use="required"/>
</xsd:complexType>
Definition at line 128 of file typeParsers.hxx.
Definition at line 211 of file typeParsers.cxx.
References yacsorb.CORBAEngineTest::i, name(), YACS::parser::required(), and type().
Definition at line 223 of file typeParsers.cxx.
References myprop::_name, _prop, and name().
Referenced by buildAttr(), name(), and type().
| myprop YACS::membertypeParser::post | ( | ) |
Definition at line 224 of file typeParsers.cxx.
References _prop, myprop::_value, and name().
Referenced by buildAttr().
| myprop YACS::membertypeParser::_prop |
Definition at line 135 of file typeParsers.hxx.
static |
Definition at line 130 of file typeParsers.hxx.
Referenced by YACS::structtypeParser::onStart().
