YACS::objtypeParser Struct Reference
Class for objref parser. More...
#include <typeParsers.hxx>
Inheritance diagram for YACS::objtypeParser:
Collaboration diagram for YACS::objtypeParser:
virtual void pre ()
virtual void id (const std::string &name)
virtual void base (const std::string &name)
virtual YACS::ENGINE::TypeCode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _id
std::list< YACS::ENGINE::TypeCodeObjref * > _ltc
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static objtypeParser objParser
static parser main_parser
Class used to parse a objref (type) definition (class TypeCodeObjref in implementation)
XML schema is
  <xsd:complexType name="ObjrefType">
    <xsd:sequence>
      <xsd:element name="base" type="xsd:string" minOccurs="0" maxOccurs="unbounded"/>
    </xsd:sequence>
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="id" type="xsd:string" />
  </xsd:complexType>
Definition at line 98 of file typeParsers.hxx.
◆ base()
void YACS::objtypeParser::base ( const std::string &  name)
Definition at line 176 of file typeParsers.cxx.
177 {
178 DEBTRACE( "base_name: " << name )
179 if(currentProc->typeMap.count(name)==0)
180 {
181 //Check if the typecode is defined in the runtime
183 if(t==0)
184 {
185 std::stringstream msg;
186 msg << "Type " << name << " does not exist" << " (" <<__FILE__ << ":" << __LINE__ << ")";
187 throw Exception(msg.str());
188 }
189 else
190 {
192 t->incrRef();
193 }
194 }
195 if(currentProc->typeMap[name]->kind() != ENGINE::Objref)
196 {
197 std::stringstream msg;
198 msg << "Type " << name << " is not an objref" ;
199 msg << " (" <<__FILE__ << ":" << __LINE__ << ")";
200 throw Exception(msg.str());
201 }
202 _ltc.push_back((ENGINE::TypeCodeObjref *)currentProc->typeMap[name]);
203 }
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
References _ltc, currentProc, DEBTRACE, YACS::ENGINE::Runtime::getTypeCode(), name(), YACS::ENGINE::Objref, gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
Referenced by onEnd().
◆ buildAttr()
void YACS::objtypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 150 of file typeParsers.cxx.
151 {
152 if (!attr)
153 return;
154 required("name",attr);
155 for (int i = 0; attr[i]; i += 2)
156 {
157 if(std::string(attr[i]) == "name")name(attr[i+1]);
158 if(std::string(attr[i]) == "id")id(attr[i+1]);
159 }
160 }
virtual void id(const std::string &name)
References yacsorb.CORBAEngineTest::i, id(), name(), and YACS::parser::required().
◆ id()
void YACS::objtypeParser::id ( const std::string &  name)
Definition at line 171 of file typeParsers.cxx.
172 {
173 DEBTRACE( "objtype_id: " << name )
174 _id=name;
175 }
References _id, DEBTRACE, and name().
Referenced by buildAttr().
void YACS::objtypeParser::name ( const std::string &  name)
Definition at line 166 of file typeParsers.cxx.
167 {
168 DEBTRACE( "objtype_name: " << name )
169 _name=name;
170 }
References _name, DEBTRACE, and name().
Referenced by base(), buildAttr(), id(), and name().
◆ onEnd()
void YACS::objtypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 144 of file typeParsers.cxx.
145 {
146 DEBTRACE( "objtypeParser::onEnd: " << el )
147 std::string element(el);
148 if(element == "base")base(((stringtypeParser*)child)->post());
149 }
virtual void base(const std::string &name)
virtual YACS::ENGINE::TypeCode * post()
References base(), DEBTRACE, and post().
◆ onStart()
void YACS::objtypeParser::onStart ( const XML_Char *  el,
Definition at line 133 of file typeParsers.cxx.
134 {
135 DEBTRACE( "objtypeParser::onStart: " << el )
136 std::string element(el);
138 if(element == "base")pp=&stringtypeParser::stringParser;
140 pp->init();
141 pp->pre();
142 pp->buildAttr(attr);
143 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), and YACS::stringtypeParser::stringParser.
◆ post()
ENGINE::TypeCode * YACS::objtypeParser::post ( )
Definition at line 204 of file typeParsers.cxx.
205 {
206 DEBTRACE( "objtype_post" )
207 ENGINE::TypeCode *t = currentProc->createInterfaceTc(_id,_name,_ltc);
208 return t;
209 }
References _id, _ltc, _name, YACS::ENGINE::Proc::createInterfaceTc(), currentProc, DEBTRACE, and gui.Appli::t.
◆ pre()
void YACS::objtypeParser::pre ( )
Definition at line 161 of file typeParsers.cxx.
162 {
163 _id="";
164 _ltc.clear();
165 }
References _id, and _ltc.
◆ _id
std::string YACS::objtypeParser::_id
Definition at line 110 of file typeParsers.hxx.
Referenced by id(), post(), and pre().
◆ _ltc
std::list<YACS::ENGINE::TypeCodeObjref *> YACS::objtypeParser::_ltc
Definition at line 111 of file typeParsers.hxx.
Referenced by base(), post(), and pre().
◆ _name
std::string YACS::objtypeParser::_name
Definition at line 109 of file typeParsers.hxx.
Referenced by name(), and post().
◆ objParser
objtypeParser YACS::objtypeParser::objParser
Definition at line 100 of file typeParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
