YACS::seqtypeParser Struct Reference
Class for sequence parser. More...
#include <typeParsers.hxx>
Inheritance diagram for YACS::seqtypeParser:
Collaboration diagram for YACS::seqtypeParser:
void name (const std::string &name)
void content (const std::string &name)
YACS::ENGINE::TypeCode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
YACS::ENGINE::TypeCode * _contentType
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static seqtypeParser seqParser
static parser main_parser
Class used to parse a sequence (type) definition (class TypeCodeSeq in implementation)
XML schema is
    <xsd:complexType name="SequenceType">
      <xsd:attribute name="name" type="xsd:string" use="required"/>
      <xsd:attribute name="content" type="xsd:string" use="required"/>
    </xsd:complexType>
Definition at line 69 of file typeParsers.hxx.
◆ buildAttr()
void YACS::seqtypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 87 of file typeParsers.cxx.
88 {
89 if (!attr)
90 return;
91 required("name",attr);
92 required("content",attr);
93 for (int i = 0; attr[i]; i += 2)
94 {
95 if(std::string(attr[i]) == "name")name(attr[i+1]);
96 if(std::string(attr[i]) == "content")content(attr[i+1]);
97 }
98 }
void content(const std::string &name)
void name(const std::string &name)
Definition: typeParsers.cxx:99
References content(), yacsorb.CORBAEngineTest::i, name(), and YACS::parser::required().
◆ content()
void YACS::seqtypeParser::content ( const std::string &  name)
Definition at line 104 of file typeParsers.cxx.
105 {
106 DEBTRACE( "seqtype_content: " << name )
107 if(currentProc->typeMap.count(name)==0)
108 {
109 //Check if the typecode is defined in the runtime
111 if(t==0)
112 {
113 std::stringstream msg;
114 msg << "Type " << name << " does not exist" << " (" <<__FILE__ << ":" << __LINE__ << ")";
115 throw Exception(msg.str());
116 }
117 else
118 {
120 t->incrRef();
121 }
122 }
124
125 }
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
Definition: typeParsers.hxx:78
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
References _contentType, currentProc, DEBTRACE, YACS::ENGINE::Runtime::getTypeCode(), name(), gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
Referenced by buildAttr().
void YACS::seqtypeParser::name ( const std::string &  name)
Definition at line 99 of file typeParsers.cxx.
100 {
101 DEBTRACE( "seqtype_name: " << name )
102 _name=name;
103 }
References _name, DEBTRACE, and name().
Referenced by buildAttr(), content(), and name().
◆ onEnd()
void YACS::seqtypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 83 of file typeParsers.cxx.
84 {
85 DEBTRACE( "seqtypeParser::onEnd: " << el )
86 }
References DEBTRACE.
◆ onStart()
void YACS::seqtypeParser::onStart ( const XML_Char *  el,
Definition at line 74 of file typeParsers.cxx.
75 {
76 DEBTRACE( "seqtypeParser::onStart: " << el )
79 pp->init();
80 pp->pre();
81 pp->buildAttr(attr);
82 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
◆ post()
ENGINE::TypeCode * YACS::seqtypeParser::post ( )
Definition at line 126 of file typeParsers.cxx.
127 {
128 DEBTRACE( "seqtype_post" )
129 ENGINE::TypeCode *t = currentProc->createSequenceTc(_name,_name,_contentType);
130 return t;
131 }
References _contentType, _name, YACS::ENGINE::Proc::createSequenceTc(), currentProc, DEBTRACE, and gui.Appli::t.
◆ _contentType
YACS::ENGINE::TypeCode* YACS::seqtypeParser::_contentType
Definition at line 78 of file typeParsers.hxx.
Referenced by content(), and post().
◆ _name
std::string YACS::seqtypeParser::_name
Definition at line 79 of file typeParsers.hxx.
Referenced by name(), and post().
◆ seqParser
seqtypeParser YACS::seqtypeParser::seqParser
Definition at line 71 of file typeParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
