YACS::typetypeParser Struct Reference
Class for type parser. More...
#include <typeParsers.hxx>
Inheritance diagram for YACS::typetypeParser:
Collaboration diagram for YACS::typetypeParser:
virtual void pre ()
virtual void kind (const std::string &name)
virtual mytype post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _kind
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static typetypeParser typeParser
static parser main_parser
Class used to parse a type definition (class TypeCode in implementation) with a name and a kind (reserved to atomic types)
XML schema is
  <xsd:complexType name="TypeType">
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="kind" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 43 of file typeParsers.hxx.
◆ buildAttr()
void YACS::typetypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 42 of file typeParsers.cxx.
43 {
44 if (!attr)
45 return;
46 required("name",attr);
47 required("kind",attr);
48 for (int i = 0; attr[i]; i += 2)
49 {
50 if(std::string(attr[i]) == "name")name(attr[i+1]);
51 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
52 }
53 }
Definition: typeParsers.cxx:55
Definition: typeParsers.cxx:60
References yacsorb.CORBAEngineTest::i, kind(), name(), and YACS::parser::required().
◆ kind()
void YACS::typetypeParser::kind ( const std::string &  name)
Definition at line 60 of file typeParsers.cxx.
61 {
62 DEBTRACE( "type_kind: " << name )
63 _kind=name;
64 }
References _kind, DEBTRACE, and name().
Referenced by buildAttr().
void YACS::typetypeParser::name ( const std::string &  name)
Definition at line 55 of file typeParsers.cxx.
56 {
57 DEBTRACE( "type_name: " << name )
58 _name=name;
59 }
References _name, DEBTRACE, and name().
Referenced by buildAttr(), kind(), and name().
◆ post()
mytype YACS::typetypeParser::post ( )
Definition at line 65 of file typeParsers.cxx.
66 {
67 DEBTRACE( "type_post" )
68 mytype t;
71 return t;
72 }
References _kind, _name, DEBTRACE, and gui.Appli::t.
◆ pre()
void YACS::typetypeParser::pre ( )
Definition at line 54 of file typeParsers.cxx.
54{}
◆ _kind
std::string YACS::typetypeParser::_kind
Definition at line 52 of file typeParsers.hxx.
Referenced by kind(), and post().
◆ _name
std::string YACS::typetypeParser::_name
Definition at line 51 of file typeParsers.hxx.
Referenced by name(), and post().
◆ typeParser
typetypeParser YACS::typetypeParser::typeParser
Definition at line 45 of file typeParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
