YACS::structtypeParser Struct Reference
Class for struct parser. More...
#include <typeParsers.hxx>
Inheritance diagram for YACS::structtypeParser:
Collaboration diagram for YACS::structtypeParser:
virtual void pre ()
virtual void id (const std::string &name)
virtual void member (const myprop &prop)
virtual YACS::ENGINE::TypeCode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _id
std::vector< myprop > _members
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static structtypeParser structParser
static parser main_parser
Class used to parse a struct (type) definition (class TypeCodeStruct in implementation)
XML schema is
  <xsd:complexType name="StructType">
    <xsd:sequence>
      <xsd:element name="member" type="MemberType" minOccurs="0" maxOccurs="unbounded"/>
    </xsd:sequence>
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="id" type="xsd:string" />
  </xsd:complexType>
Definition at line 154 of file typeParsers.hxx.
◆ buildAttr()
void YACS::structtypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 244 of file typeParsers.cxx.
245 {
246 if (!attr)
247 return;
248 required("name",attr);
249 for (int i = 0; attr[i]; i += 2)
250 {
251 if(std::string(attr[i]) == "name")name(attr[i+1]);
252 if(std::string(attr[i]) == "id")id(attr[i+1]);
253 }
254 }
virtual void id(const std::string &name)
References yacsorb.CORBAEngineTest::i, id(), name(), and YACS::parser::required().
◆ id()
void YACS::structtypeParser::id ( const std::string &  name)
Definition at line 265 of file typeParsers.cxx.
266 {
267 DEBTRACE( "structtype_id: " << name );
268 _id=name;
269 }
References _id, DEBTRACE, and name().
Referenced by buildAttr().
◆ member()
void YACS::structtypeParser::member ( const myprop &  prop)
Definition at line 270 of file typeParsers.cxx.
271 {
272 DEBTRACE( "structtype_member: " << prop._name << prop._value );
273 if(currentProc->typeMap.count(prop._value)==0)
274 {
275 //Check if the typecode is defined in the runtime
277 if(t==0)
278 {
279 std::string msg="Unknown type " + prop._value + " for member " + prop._name + " in struct " + _name;
280 throw Exception(msg);
281 }
282 else
283 {
285 t->incrRef();
286 }
287 }
288
289 _members.push_back(prop);
290 }
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
References _members, myprop::_name, _name, myprop::_value, currentProc, DEBTRACE, YACS::ENGINE::Runtime::getTypeCode(), gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
Referenced by onEnd().
void YACS::structtypeParser::name ( const std::string &  name)
Definition at line 260 of file typeParsers.cxx.
261 {
262 DEBTRACE( "structtype_name: " << name );
263 _name=name;
264 }
References _name, DEBTRACE, and name().
Referenced by buildAttr(), id(), and name().
◆ onEnd()
void YACS::structtypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 238 of file typeParsers.cxx.
239 {
240 DEBTRACE( "structtypeParser::onEnd: " << el )
241 std::string element(el);
242 if(element == "member")member(((membertypeParser*)child)->post());
243 }
virtual void member(const myprop &prop)
virtual YACS::ENGINE::TypeCode * post()
References DEBTRACE, member(), and post().
◆ onStart()
void YACS::structtypeParser::onStart ( const XML_Char *  el,
Definition at line 227 of file typeParsers.cxx.
228 {
229 DEBTRACE( "structtypeParser::onStart: " << el )
230 std::string element(el);
232 if(element == "member")pp=&membertypeParser::memberParser;
234 pp->init();
235 pp->pre();
236 pp->buildAttr(attr);
237 }
static membertypeParser memberParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::membertypeParser::memberParser, YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
◆ post()
ENGINE::TypeCode * YACS::structtypeParser::post ( )
Definition at line 291 of file typeParsers.cxx.
292 {
293 DEBTRACE( "structtype_post" );
294 ENGINE::TypeCodeStruct *t;
295 if(currentProc->typeMap.count(_name)!=0)
296 {
297 //reuse a forward declaration
298 ENGINE::TypeCode* tt=currentProc->typeMap[_name];
299 if(tt->kind()==YACS::ENGINE::Struct)
300 {
301 t=(ENGINE::TypeCodeStruct*)tt;
302 }
303 else
304 {
305 std::string msg="Forward declaration must be a struct type but " + std::string(tt->name()) + " is not one" ;
306 throw Exception(msg);
307 }
308 }
309 else
310 {
311 t = (ENGINE::TypeCodeStruct*)currentProc->createStructTc(_id,_name);
312 }
313 std::vector<myprop>::const_iterator iter;
314 for(iter=_members.begin();iter!=_members.end();iter++)
315 {
316 DEBTRACE("member: " << iter->_name << " " <<iter->_value);
317 t->addMember(iter->_name,currentProc->typeMap[iter->_value]);
318 }
319 return t;
320 }
virtual TypeCode * createStructTc(const std::string &id, const std::string &name)
Definition: Proc.cxx:161
References _id, _members, _name, YACS::ENGINE::Proc::createStructTc(), currentProc, DEBTRACE, YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::TypeCode::name(), YACS::ENGINE::Struct, gui.Appli::t, and YACS::ENGINE::Proc::typeMap.
◆ pre()
void YACS::structtypeParser::pre ( )
Definition at line 255 of file typeParsers.cxx.
256 {
257 _id="";
258 _members.clear();
259 }
References _id, and _members.
◆ _id
std::string YACS::structtypeParser::_id
Definition at line 167 of file typeParsers.hxx.
Referenced by id(), post(), and pre().
◆ _members
std::vector<myprop> YACS::structtypeParser::_members
Definition at line 168 of file typeParsers.hxx.
Referenced by member(), post(), and pre().
◆ _name
std::string YACS::structtypeParser::_name
Definition at line 166 of file typeParsers.hxx.
Referenced by member(), name(), and post().
◆ structParser
structtypeParser YACS::structtypeParser::structParser
Definition at line 156 of file typeParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
