YACS::controltypeParser< T > Struct Template Reference
#include <linkParsers.hxx>
Inheritance diagram for YACS::controltypeParser< T >:
Collaboration diagram for YACS::controltypeParser< T >:
virtual void pre ()
virtual void fromnode (const std::string &name)
virtual void tonode (const std::string &name)
virtual T & post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
T _link
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static controltypeParser< T > controlParser
static parser main_parser
template<class T = mycontrol>
struct YACS::controltypeParser< T >
Definition at line 32 of file linkParsers.hxx.
◆ fromnode()
virtual void YACS::controltypeParser< T >::fromnode ( const std::string &  name)
Definition at line 59 of file linkParsers.hxx.
60 {
61 _link.fromnode(name);
62 }
References YACS::controltypeParser< T >::_link.
Referenced by YACS::controltypeParser< T >::onEnd().
◆ onEnd()
virtual void YACS::controltypeParser< T >::onEnd ( const char *  el,
parser *  child
Reimplemented in YACS::linktypeParser< T >, and YACS::linktypeParser< mystream >.
Definition at line 49 of file linkParsers.hxx.
50 {
51 std::string element(el);
52 if(element == "fromnode")fromnode(((stringtypeParser*)child)->post());
53 else if(element == "tonode")tonode(((stringtypeParser*)child)->post());
54 }
virtual void tonode(const std::string &name)
Definition: linkParsers.hxx:63
virtual void fromnode(const std::string &name)
Definition: linkParsers.hxx:59
References YACS::controltypeParser< T >::fromnode(), YACS::controltypeParser< T >::post(), and YACS::controltypeParser< T >::tonode().
◆ onStart()
virtual void YACS::controltypeParser< T >::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 36 of file linkParsers.hxx.
37 {
38 std::string element(el);
40 this->maxcount("fromnode",1,element);
41 this->maxcount("tonode",1,element);
42 if(element == "fromnode")pp=&stringtypeParser::stringParser;
43 else if(element == "tonode")pp=&stringtypeParser::stringParser;
44 this->SetUserDataAndPush(pp);
45 pp->init();
46 pp->pre();
47 pp->buildAttr(attr);
48 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), and YACS::stringtypeParser::stringParser.
◆ post()
virtual T & YACS::controltypeParser< T >::post ( )
Definition at line 72 of file linkParsers.hxx.
73 {
74 mincount("fromnode",1);
75 mincount("tonode",1);
76 return _link;
77 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
References YACS::controltypeParser< T >::_link, and YACS::parser::mincount().
◆ pre()
virtual void YACS::controltypeParser< T >::pre ( )
Definition at line 55 of file linkParsers.hxx.
56 {
57 _link.clear();
58 }
◆ property()
virtual void YACS::controltypeParser< T >::property ( const myprop &  prop)
Definition at line 67 of file linkParsers.hxx.
68 {
69 DEBTRACE( "property_set: " << prop._name << prop._value )
70 _link.setProperty(prop._name,prop._value);
71 }
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References YACS::controltypeParser< T >::_link, myprop::_name, myprop::_value, and DEBTRACE.
◆ tonode()
virtual void YACS::controltypeParser< T >::tonode ( const std::string &  name)
Definition at line 63 of file linkParsers.hxx.
64 {
65 _link.tonode(name);
66 }
◆ _link
◆ controlParser
template<class T >
controltypeParser< T > YACS::controltypeParser< T >::controlParser
Definition at line 34 of file linkParsers.hxx.
