YACS::parametertypeParser Struct Reference
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::parametertypeParser:
Collaboration diagram for YACS::parametertypeParser:
virtual void pre ()
virtual void tonode (const std::string &name)
virtual void toport (const std::string &name)
virtual void value (const std::string &name)
virtual myparam & post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
myparam _param
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static parametertypeParser parameterParser
static parser main_parser
Definition at line 160 of file xmlrpcParsers.hxx.
◆ onEnd()
void YACS::parametertypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 271 of file xmlrpcParsers.cxx.
272 {
273 std::string element(el);
274 if(element == "tonode")tonode(((stringtypeParser*)child)->post());
275 else if(element == "toport")toport(((stringtypeParser*)child)->post());
276 else if(element == "value")value(((valuetypeParser*)child)->post());
277 }
virtual void value(const std::string &name)
virtual void toport(const std::string &name)
virtual void tonode(const std::string &name)
virtual myparam & post()
References post(), tonode(), toport(), and value().
◆ onStart()
void YACS::parametertypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 256 of file xmlrpcParsers.cxx.
257 {
258 std::string element(el);
259 this->maxcount("tonode",1,element);
260 this->maxcount("toport",1,element);
261 this->maxcount("value",1,element);
263 if(element == "tonode")pp=&stringtypeParser::stringParser;
264 else if(element == "toport")pp=&stringtypeParser::stringParser;
265 else if(element == "value")pp=&valuetypeParser::valueParser;
267 pp->init();
268 pp->pre();
269 pp->buildAttr(attr);
270 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
static valuetypeParser valueParser
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), YACS::stringtypeParser::stringParser, and YACS::valuetypeParser::valueParser.
◆ post()
myparam & YACS::parametertypeParser::post ( )
Definition at line 288 of file xmlrpcParsers.cxx.
288 {
289 mincount("tonode",1);
290 mincount("toport",1);
291 mincount("value",1);
292 return _param;
293 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
References _param, and YACS::parser::mincount().
Referenced by onEnd().
◆ pre()
void YACS::parametertypeParser::pre ( )
Definition at line 278 of file xmlrpcParsers.cxx.
278{}
◆ tonode()
void YACS::parametertypeParser::tonode ( const std::string &  name)
Definition at line 279 of file xmlrpcParsers.cxx.
279 {
280 _param._tonode=name;
281 }
std::string _tonode
Definition: factory.hxx:74
References _param, and myparam::_tonode.
◆ toport()
void YACS::parametertypeParser::toport ( const std::string &  name)
Definition at line 282 of file xmlrpcParsers.cxx.
282 {
283 _param._toport=name;
284 }
std::string _toport
Definition: factory.hxx:75
References _param, and myparam::_toport.
◆ value()
void YACS::parametertypeParser::value ( const std::string &  name)
◆ _param
myparam YACS::parametertypeParser::_param
Definition at line 171 of file xmlrpcParsers.hxx.
Referenced by post(), tonode(), toport(), and value().
◆ parameterParser
parametertypeParser YACS::parametertypeParser::parameterParser
