YACS::HMI::YACSGuiLoader Class Reference
#include <YACSGuiLoader.hxx>
Inheritance diagram for YACS::HMI::YACSGuiLoader:
Collaboration diagram for YACS::HMI::YACSGuiLoader:
 YACSGuiLoader ()
virtual ~YACSGuiLoader ()
virtual void reset ()
virtual YACS::ENGINE::Proc * load (const char *filename)
std::map< YACS::ENGINE::Node *, PrsData > getPrsData (YACS::ENGINE::Proc *proc)
void process (std::string element, bool newLink=false)
- Public Member Functions inherited from YACS::YACSLoader
 YACSLoader ()
virtual ~YACSLoader ()
void registerProcCataLoader ()
std::map< YACS::ENGINE::Node *, PrsData > _prsMap
std::map< std::string, PrsData > _inputMap
- Protected Attributes inherited from YACS::YACSLoader
std::map< std::string, parser * > _defaultParsersMap
Class that extends engine XML loader. It can process the presentation data not hanled by the base class.
Definition at line 87 of file YACSGuiLoader.hxx.
◆ YACSGuiLoader()
YACSGuiLoader::YACSGuiLoader ( )
Definition at line 33 of file YACSGuiLoader.cxx.
34 : YACSLoader()
35{
37 _defaultParsersMap.insert(make_pair("presentation", &presentation_parser));
38 _inputMap.clear();
39 _prsMap.clear();
40}
static presentationtype_parser presentation_parser
Definition: parsers.hxx:44
References YACS::YACSLoader::_defaultParsersMap, _inputMap, _prsMap, YACS::HMI::presentationtype_parser::collector_, and presentation_parser.
◆ ~YACSGuiLoader()
YACSGuiLoader::~YACSGuiLoader ( )
Definition at line 42 of file YACSGuiLoader.cxx.
43{
44}
◆ getPrsData()
std::map< YACS::ENGINE::Node *, PrsData > YACSGuiLoader::getPrsData ( YACS::ENGINE::Proc *  proc)
Definition at line 57 of file YACSGuiLoader.cxx.
58{
59 _prsMap.clear();
60
61 if (_defaultParsersMap.empty()) return _prsMap;
62
63 for (map<string, PrsData>::iterator it = _inputMap.begin(); it != _inputMap.end(); ++it)
64 {
65 Node* node = 0;
66 string name = (*it).first;
67
68 if (name == "__ROOT__")
69 node = proc;
70 else
71 {
72 try
73 {
74 node = proc->getChildByName(name);
75 }
76 catch(Exception& ex)
77 {
78 continue;
79 }
80 }
81 _prsMap[node] = (*it).second;
82 }
83 return _prsMap;
84}
Base class for all nodes.
Definition: Node.hxx:70
References YACS::YACSLoader::_defaultParsersMap, _inputMap, _prsMap, testCppPluginInvokation::ex, and YACS::ENGINE::ComposedNode::getChildByName().
Referenced by YACS::HMI::GenericGui::setLoadedPresentation().
◆ load()
YACS::ENGINE::Proc * YACSGuiLoader::load ( const char *  filename)
◆ process()
void YACSGuiLoader::process ( std::string  element,
bool  newLink = false
Definition at line 86 of file YACSGuiLoader.cxx.
87{
88 if(theElement == "presentation")
89 {
90 if ( _defaultParsersMap["presentation"] )
91 {
93 _inputMap[aP->name_] = PrsData(aP->x_, aP->y_, aP->width_, aP->height_, aP->expx_, aP->expy_,
94 aP->expWidth_, aP->expHeight_, aP->expanded_, aP->shownState_);
95 DEBTRACE(aP->name_ << " " << aP->x_ << " " << aP->y_ << " " << aP->width_ << " " << aP->height_ << " "
96 << aP->expx_ << " " << aP->expy_ << " " << aP->expWidth_ << " " << aP->expHeight_ << " " << aP->expanded_ << " " << aP->shownState_);
97 }
98 }
99}
References YACS::YACSLoader::_defaultParsersMap, _inputMap, DEBTRACE, YACS::HMI::presentationtype_parser::expanded_, YACS::HMI::presentationtype_parser::expHeight_, YACS::HMI::presentationtype_parser::expWidth_, YACS::HMI::presentationtype_parser::expx_, YACS::HMI::presentationtype_parser::expy_, YACS::HMI::presentationtype_parser::height_, YACS::HMI::presentationtype_parser::name_, YACS::HMI::presentationtype_parser::shownState_, YACS::HMI::presentationtype_parser::width_, YACS::HMI::presentationtype_parser::x_, and YACS::HMI::presentationtype_parser::y_.
Referenced by YACS::HMI::presentationtype_parser::buildAttr().
◆ reset()
void YACSGuiLoader::reset ( )
Definition at line 46 of file YACSGuiLoader.cxx.
47{
48 _inputMap.clear();
49}
References _inputMap.
Referenced by gui.graph.grid::findPath(), and YACS::HMI::GenericGui::onNewSchema().
◆ _inputMap
std::map<std::string, PrsData> YACS::HMI::YACSGuiLoader::_inputMap
Definition at line 101 of file YACSGuiLoader.hxx.
Referenced by getPrsData(), load(), process(), reset(), and YACSGuiLoader().
◆ _prsMap
std::map<YACS::ENGINE::Node*, PrsData> YACS::HMI::YACSGuiLoader::_prsMap
Definition at line 100 of file YACSGuiLoader.hxx.
Referenced by getPrsData(), and YACSGuiLoader().
