YACS::ENGINE::ProcCataLoader Class Reference
#include <ProcCataLoader.hxx>
Inheritance diagram for YACS::ENGINE::ProcCataLoader:
Collaboration diagram for YACS::ENGINE::ProcCataLoader:
 ProcCataLoader (YACS::YACSLoader *xmlLoader)
 ProcCataLoader (YACS::YACSLoader *xmlLoader, const std::string &path)
virtual ~ProcCataLoader ()
virtual void loadCata (Catalog *cata)
virtual CatalogLoader * newLoader (const std::string &path)
- Public Member Functions inherited from YACS::ENGINE::CatalogLoader
 CatalogLoader ()
 CatalogLoader (const std::string &path)
virtual ~CatalogLoader ()
virtual CatalogLoader * newLoader (const std::string &path)=0
virtual void loadCata (Catalog *cata)=0
virtual void load (Catalog *cata, const std::string &path)
YACS::YACSLoader * _xmlLoader
- Protected Attributes inherited from YACS::ENGINE::CatalogLoader
std::string _path
Definition at line 35 of file ProcCataLoader.hxx.
◆ ProcCataLoader() [1/2]
YACS::ENGINE::ProcCataLoader::ProcCataLoader ( YACS::YACSLoader *  xmlLoader)
Definition at line 38 of file ProcCataLoader.hxx.
Referenced by newLoader().
◆ ProcCataLoader() [2/2]
ProcCataLoader::ProcCataLoader ( YACS::YACSLoader *  xmlLoader,
const std::string &  path
Definition at line 37 of file ProcCataLoader.cxx.
37 :CatalogLoader(path),_xmlLoader(xmlLoader)
38{
39 //path should be a file path
40}
◆ ~ProcCataLoader()
ProcCataLoader::~ProcCataLoader ( )
Definition at line 42 of file ProcCataLoader.cxx.
43{
44 DEBTRACE ("ProcCataLoader::~ProcCataLoader");
45}
References DEBTRACE.
◆ loadCata()
void ProcCataLoader::loadCata ( Catalog *  cata)
Implements YACS::ENGINE::CatalogLoader.
Definition at line 47 of file ProcCataLoader.cxx.
48{
49 DEBTRACE("ProcCataLoader::load");
50 Proc* p;
51 try
52 {
53 p=_xmlLoader->load(_path.c_str());
54 if(p==0)
55 {
56 std::string msg="the file is probably not a YACS schema file";
57 cata->setErrors(msg);
58 std::cerr << msg << std::endl;
59 return;
60 }
61 }
62 catch (YACS::Exception& e)
63 {
64 std::string msg="Caught a YACS exception";
65 msg=msg + e.what();
66 std::cerr << msg << std::endl;
67 cata->setErrors(msg);
68 return ;
69 }
70 catch (const std::invalid_argument& e)
71 {
72 cata->setErrors(e.what());
73 return ;
74 }
75 catch (const std::ios_base::failure&)
76 {
77 std::string msg="Caught an io failure exception";
78 std::cerr << msg << std::endl;
79 cata->setErrors(msg);
80 return ;
81 }
82
83 //Get the parser logger
84 Logger* logger=p->getLogger("parser");
85 //Print errors logged if any
86 if(!logger->isEmpty())
87 {
88 std::string msg=logger->getStr();
89 std::cerr << msg << std::endl;
90 cata->setErrors(msg);
91 }
92
93 std::map<std::string,TypeCode*>& typeMap=cata->_typeMap;
94 std::map<std::string,Node*>& nodeMap=cata->_nodeMap;
95 std::map<std::string,ComposedNode*>& composednodeMap=cata->_composednodeMap;
96 std::map<std::string,ComponentDefinition*>& componentMap=cata->_componentMap;
97
98 std::map<std::string,TypeCode*>::iterator it=p->typeMap.begin();
99 while(it != p->typeMap.end())
100 {
101 typeMap[it->first]=it->second;
102 it->second->incrRef();
103 it++;
104 }
105
106 std::list<Node *> s=p->getChildren();
107 for(std::list<Node *>::iterator iter=s.begin();iter!=s.end();iter++)
108 {
109 YACS::ENGINE::ComposedNode * cnode= dynamic_cast<YACS::ENGINE::ComposedNode *>(*iter);
110 if(cnode)
111 composednodeMap[cnode->getName()]=(YACS::ENGINE::ComposedNode *) cnode->clone(0);
112 else
113 nodeMap[(*iter)->getName()]=(*iter)->clone(0);
114 }
115 delete p;
116}
std::list< Node * > getChildren() const
Definition: Bloc.hxx:57
void setErrors(const std::string &errors)
Definition: Catalog.hxx:48
std::map< std::string, ComposedNode * > _composednodeMap
Definition: Catalog.hxx:52
std::map< std::string, ComponentDefinition * > _componentMap
Definition: Catalog.hxx:50
std::map< std::string, Node * > _nodeMap
Definition: Catalog.hxx:51
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
std::string getName() const
Class for logging error messages.
Definition: Logger.hxx:38
virtual bool isEmpty()
Definition: Logger.cxx:96
virtual std::string getStr()
Definition: Logger.cxx:85
Node * clone(ComposedNode *father, bool editionOnly=true) const
This method MUST NEVER BE VIRTUAL
Definition: Node.cxx:131
Definition: Proc.hxx:44
virtual Logger * getLogger(const std::string &name)
Definition: Proc.cxx:431
Definition: Proc.hxx:90
const char * what(void) const noexcept
Definition: Exception.cxx:50
virtual YACS::ENGINE::Proc * load(const char *filename)
Definition: parsers.cxx:63
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::Catalog::_componentMap, YACS::ENGINE::Catalog::_composednodeMap, YACS::ENGINE::Catalog::_nodeMap, YACS::ENGINE::CatalogLoader::_path, YACS::ENGINE::Catalog::_typeMap, _xmlLoader, YACS::ENGINE::Node::clone(), DEBTRACE, YACS::ENGINE::Bloc::getChildren(), YACS::ENGINE::Proc::getLogger(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Logger::getStr(), YACS::ENGINE::Logger::isEmpty(), YACS::YACSLoader::load(), p, YACS::ENGINE::Catalog::setErrors(), YACS::ENGINE::Proc::typeMap, and YACS::Exception::what().
◆ newLoader()
virtual CatalogLoader * YACS::ENGINE::ProcCataLoader::newLoader ( const std::string &  path)
Definition at line 42 of file ProcCataLoader.hxx.
42{return new ProcCataLoader(_xmlLoader,path);}
ProcCataLoader(YACS::YACSLoader *xmlLoader)
References _xmlLoader, and ProcCataLoader().
◆ _xmlLoader
YACS::YACSLoader* YACS::ENGINE::ProcCataLoader::_xmlLoader
Definition at line 44 of file ProcCataLoader.hxx.
Referenced by loadCata(), and newLoader().
