gui.GraphViewer.GraphViewer Class Reference
Inheritance diagram for gui.GraphViewer.GraphViewer:
Collaboration diagram for gui.GraphViewer.GraphViewer:
def __init__ (self, c, parent, name, f)
def contentsMouseDoubleClickEvent (self, e)
def contentsMousePressEvent (self, e)
def selectItem (self, item)
def selectObj (self, obj)
def deselectObj (self, obj)
def popup (self)
def updateCanvas (self)
def addNode (self)
def zoomIn (self)
def zoomOut (self)
def clear (self)
def connecting (self, obj)
def contentsMouseMoveEvent (self, e)
Public Attributes
 selectPen
 selectBrush
 selectStyle
 selected
 tooltip
 __moving
 __connecting
 __moving_start
Definition at line 41 of file GraphViewer.py.
◆ __init__()
def gui.GraphViewer.GraphViewer.__init__ (   self,
  c,
  parent,
  name,
  f
Definition at line 42 of file GraphViewer.py.
42 def __init__(self,c,parent,name,f):
43 QCanvasView.__init__(self,c,parent,name,f)
44 self.__moving=0
45 self.__connecting=0
46 self.__moving_start= 0
47 # for highlighting selections
48 self.selectPen=QPen(QColor(255,255,0),2,Qt.DashLine)
49 self.selectBrush=QBrush(Qt.red)
50 self.selectStyle = Qt.Dense5Pattern
51 self.selected=None
52 self.tooltip = DynamicTip( self )
53
◆ addNode()
def gui.GraphViewer.GraphViewer.addNode (   self)
Definition at line 164 of file GraphViewer.py.
164 def addNode(self):
165 print("addNode")
166
Referenced by gui.GraphViewer.GraphViewer.popup().
◆ clear()
def gui.GraphViewer.GraphViewer.clear (   self)
Definition at line 177 of file GraphViewer.py.
177 def clear(self):
178 ilist = self.canvas().allItems()
179 for each_item in ilist:
180 if each_item:
181 each_item.setCanvas(None)
182 del each_item
183 self.canvas().update()
184
References gui.CItems.LinkItem.canvas, and gui.graph.Graph.canvas.
◆ connecting()
def gui.GraphViewer.GraphViewer.connecting (   self,
  obj
Method called by an item to notify canvasView a connection has begun
Definition at line 185 of file GraphViewer.py.
185 def connecting(self,obj):
186 """Method called by an item to notify canvasView a connection has begun"""
187 print("connecting",obj)
188 self.__connecting=obj
189
References gui.GraphViewer.GraphViewer.__connecting.
◆ contentsMouseDoubleClickEvent()
def gui.GraphViewer.GraphViewer.contentsMouseDoubleClickEvent (   self,
  e
Definition at line 54 of file GraphViewer.py.
54 def contentsMouseDoubleClickEvent(self,e): # QMouseEvent e
55 point = self.inverseWorldMatrix().map(e.pos())
56 ilist = self.canvas().collisions(point) #QCanvasItemList ilist
57 for each_item in ilist:
58 if each_item.rtti()==984376:
59 if not each_item.hit(point):
60 continue
61 if e.button()== Qt.LeftButton:
62 if hasattr(each_item,"handleDoubleClick"):
63 each_item.handleDoubleClick(point)
64 self.canvas().update()
65 return
66
67
◆ contentsMouseMoveEvent()
def gui.GraphViewer.GraphViewer.contentsMouseMoveEvent (   self,
  e
Definition at line 190 of file GraphViewer.py.
190 def contentsMouseMoveEvent(self,e):
191 if self.__moving :
192 point = self.inverseWorldMatrix().map(e.pos())
193 self.__moving.moveBy(point.x()-self.__moving_start.x(),point.y()-self.__moving_start.y())
194 self.__moving_start = point
195 self.canvas().update()
196 else:
197 #self.tooltip.maybeTip(point)
198 QCanvasView.contentsMouseMoveEvent(self,e)
199
References gui.GraphViewer.GraphViewer.__moving, gui.GraphViewer.GraphViewer.__moving_start, gui.CItems.LinkItem.canvas, and gui.graph.Graph.canvas.
◆ contentsMousePressEvent()
def gui.GraphViewer.GraphViewer.contentsMousePressEvent (   self,
  e
Definition at line 68 of file GraphViewer.py.
68 def contentsMousePressEvent(self,e): # QMouseEvent e
69 p=e.globalPos()
70 point = self.inverseWorldMatrix().map(e.pos())
71 ilist = self.canvas().collisions(point) #QCanvasItemList ilist
72 for each_item in ilist:
73 if each_item.rtti()==984376:
74 if not each_item.hit(point):
75 continue
76 if e.button()== Qt.RightButton:
77 #Right button click
78 self.__moving=0
79 self.__connecting=0
80 if hasattr(each_item,"popup"):
81 menu=each_item.popup(self)
82 if menu:
83 menu.exec_loop( QCursor.pos() )
84 self.canvas().update()
85 elif hasattr(each_item,"getObj"):
86 menu=each_item.getObj().popup(self)
87 if menu:
88 menu.exec_loop( QCursor.pos() )
89 self.canvas().update()
90
91 elif e.button()== Qt.LeftButton:
92 #Left button click
93 if self.__connecting:
94 #We are linking objects
95 if hasattr(each_item,"getObj"):
96 #a connection is ending
97 self.__connecting.link(each_item.getObj().item)
98 #self.__connecting.link(each_item.getObj())
99 self.canvas().update()
100 self.__connecting=0
101 else:
102 #We are moving or selecting a composite object
103 each_item.selected()
104 self.__moving=each_item
105 self.__moving_start=point
106 self.canvas().update()
107 return
108 if e.button()== Qt.RightButton:
109 menu=self.popup()
110 if menu:
111 menu.exec_loop( QCursor.pos() )
112 self.canvas().update()
113 self.__moving=0
114 self.__connecting=0
115 QCanvasView.contentsMousePressEvent(self,e)
116
References gui.GraphViewer.GraphViewer.__connecting, gui.GraphViewer.GraphViewer.__moving, gui.GraphViewer.GraphViewer.__moving_start, gui.CItems.LinkItem.canvas, gui.graph.Graph.canvas, gui.GraphViewer.GraphViewer.popup(), gui.CItems.LinkItem.popup(), gui.CItems.ControlItem.popup(), gui.CItems.PortItem.popup(), gui.CItems.Cell.popup(), gui.GraphViewer.LinkItem.popup(), gui.GraphViewer.PortItem.popup(), and gui.GraphViewer.Cell.popup().
◆ deselectObj()
def gui.GraphViewer.GraphViewer.deselectObj (   self,
  obj
Definition at line 141 of file GraphViewer.py.
141 def deselectObj(self,obj):
142 if obj:
143 obj.setPen(obj._origPen)
144 #obj.setBrush(obj._origBrush)
145
Referenced by gui.GraphViewer.GraphViewer.selectItem().
◆ popup()
def gui.GraphViewer.GraphViewer.popup (   self)
◆ selectItem()
◆ selectObj()
def gui.GraphViewer.GraphViewer.selectObj (   self,
  obj
Definition at line 133 of file GraphViewer.py.
133 def selectObj(self,obj):
134 if obj:
135 obj._origPen = obj.pen()
136 obj._origBrush = obj.brush()
137 obj._origStyle = obj.brush().style()
138 obj.setPen(self.selectPen)
139 #obj.setBrush(self.selectBrush)
140
References gui.GraphViewer.GraphViewer.selectPen.
◆ updateCanvas()
def gui.GraphViewer.GraphViewer.updateCanvas (   self)
Definition at line 157 of file GraphViewer.py.
157 def updateCanvas(self):
158 #Par defaut, Qt n'efface pas le background. Seul repaintContents
159 #semble le faire. Utile apres un popup ou un resize avec scrollbars
160 #Peut-on l'utiliser partout ? Pb de performance ?
161 self.repaintContents(True)
162 #self.canvas().update()
163
◆ zoomIn()
def gui.GraphViewer.GraphViewer.zoomIn (   self)
Definition at line 167 of file GraphViewer.py.
167 def zoomIn(self):
168 m = self.worldMatrix()
169 m.scale( 2.0, 2.0 )
170 self.setWorldMatrix( m )
171
◆ zoomOut()
def gui.GraphViewer.GraphViewer.zoomOut (   self)
Definition at line 172 of file GraphViewer.py.
172 def zoomOut(self):
173 m = self.worldMatrix()
174 m.scale( 0.5, 0.5 )
175 self.setWorldMatrix( m )
176
◆ __connecting
◆ __moving
◆ __moving_start
◆ selectBrush
gui.GraphViewer.GraphViewer.selectBrush
Definition at line 49 of file GraphViewer.py.
◆ selected
gui.GraphViewer.GraphViewer.selected
◆ selectPen
Definition at line 48 of file GraphViewer.py.
Referenced by gui.GraphViewer.GraphViewer.selectObj().
◆ selectStyle
gui.GraphViewer.GraphViewer.selectStyle
Definition at line 50 of file GraphViewer.py.
◆ tooltip
gui.GraphViewer.GraphViewer.tooltip
Definition at line 52 of file GraphViewer.py.
