gui.graph.grid Class Reference
def __init__ (self, graph)
def reset (self)
def get (self, coord)
def getPath (self, node)
def neighbours (self, node)
def findPath (self, fromLoc, toLoc)
Public Attributes
 graph
 xs
 ys
 cols
 open
Definition at line 297 of file graph.py.
◆ __init__()
def gui.graph.grid.__init__ (   self,
  graph
Definition at line 298 of file graph.py.
298 def __init__(self,graph):
299 self.graph=graph
300 xs=set()
301 ys=set()
302 xmargin=5
303 ymargin=5
304 for n in graph:
305 h=n.height()
306 w=n.width()
307 x=n.x()
308 y=n.y()
309 xs.add(x-xmargin)
310 xs.add(x+w+xmargin)
311 ys.add(y-ymargin)
312 ys.add(y+h+ymargin)
313
314 xs=list(xs)
315 xs.sort()
316 x0=xs[0]-36
317 xs.insert(0,x0)
318 x0=xs[-1]+36
319 xs.append(x0)
320
321 ys=list(ys)
322 ys.sort()
323 y0=ys[0]-36
324 ys.insert(0,y0)
325 y0=ys[-1]+36
326 ys.append(y0)
327
328 self.xs=xs
329 self.ys=ys
330 self.cols=[]
331 for w in range(len(xs)-1):
332 col=[]
333 x=(xs[w]+xs[w+1])/2
334 for h in range(len(ys)-1):
335 y=(ys[h]+ys[h+1])/2
336 col.append(node((x,y),(w,h)))
337 self.cols.append(col)
338
339 for n in graph:
340 h=n.height()
341 w=n.width()
342 x=n.x()
343 y=n.y()
344 l1,l2=bisect.bisect_left(ys,y-ymargin),bisect.bisect_left(ys,y+h+ymargin)
345 i1,i2=bisect.bisect_left(xs,x-xmargin),bisect.bisect_left(xs,x+w+xmargin)
346 for c in self.cols[i1:i2]:
347 for e in c[l1:l2]:
348 e.blocked=1
349
350 #for col in self.cols:
351 # print [e.coord +(e.blocked,) for e in col]
352
◆ findPath()
def gui.graph.grid.findPath (   self,
  fromLoc,
  toLoc
Find shortest path from fromLoc to toLoc
Definition at line 407 of file graph.py.
407 def findPath(self,fromLoc,toLoc):
408 """Find shortest path from fromLoc to toLoc"""
409 self.reset()
410 self.open=[]
411 fromNode=self.get(fromLoc)
412 self.open.append((fromNode.total,fromNode))
413 toNode=self.get(toLoc)
414 if toNode.blocked:
415 print("toNode is blocked")
416 return []
417 destx,desty=toNode.coord
418 while self.open:
419 #if open is not void, take the best node (the first one)
420 t,node=self.open.pop(0)
421 node.close=1
422 if node == toNode:
423 #got toLoc
424 return self.getPath(node)
425
426 for new_node in self.neighbours(node):
427 if new_node.close :
428 continue
429 x,y =new_node.coord
430 path_cost=node.path_cost+distance(node,new_node)
431 total=path_cost+h(x,y,destx,desty)
432 if new_node.open :
433 #the node is already in open
434 if total < new_node.total:
435 self.open.remove((new_node.total,new_node))
436 new_node.path_cost=path_cost
437 new_node.parent=node
438 new_node.total=total
439 bisect.insort(self.open,(new_node.total,new_node))
440 else:
441 #the node is not yet in open
442 new_node.path_cost=path_cost
443 new_node.parent=node
444 new_node.total=total
445 bisect.insort(self.open,(new_node.total,new_node))
446 new_node.open=1
447
448 return []
449
def distance(node, new_node)
Definition: graph.py:275
def h(x, y, destx, desty)
Definition: graph.py:272
References YACS::ENGINE::Logger.reset(), YACS::HMI::YACSGuiLoader.reset(), gui.graph.grid.reset(), and arguments.reset.
◆ get()
def gui.graph.grid.get (   self,
  coord
Definition at line 360 of file graph.py.
360 def get(self,coord):
361 x,y=coord
362 col= bisect.bisect_left(self.xs,x)-1
363 if col < 0 or col >= len(self.cols):
364 return None
365 col=self.cols[col]
366 row=bisect.bisect_left(self.ys,y)-1
367 if row < 0 or row >= len(col):
368 return None
369 return col[row]
370
References gui.graph.grid.cols, gui.graph.grid.xs, and gui.graph.grid.ys.
◆ getPath()
def gui.graph.grid.getPath (   self,
  node
Definition at line 371 of file graph.py.
371 def getPath(self,node):
372 path=[node.coord]
373 parent=node.parent
374 while parent:
375 prev=node
376 node=parent
377 parent=node.parent
378 if parent:
379 #if points are aligned don't keep the middle point
380 x,y=node.coord
381 x0,y0=prev.coord
382 x1,y1=parent.coord
383 if (x1-x)*(y0-y)-(y1-y)*(x0-x) == 0:
384 continue
385 path.append(node.coord)
386 path.reverse()
387 return path
388
◆ neighbours()
def gui.graph.grid.neighbours (   self,
  node
Definition at line 389 of file graph.py.
389 def neighbours(self,node):
390 col,row=node.index
391 l=[]
392 steps=((0, +1), (+1, 0), (0, -1), (-1, 0 ))
393 for step in steps:
394 c=col+step[0]
395 r=row+step[1]
396 if c < 0 or c >=len(self.cols):
397 continue
398 co=self.cols[c]
399 if r <0 or r >= len(co):
400 continue
401 n=co[r]
402 if n.blocked:
403 continue
404 l.append(n)
405 return l
406
References gui.graph.grid.cols.
◆ reset()
def gui.graph.grid.reset (   self)
Definition at line 353 of file graph.py.
353 def reset(self):
354 for c in self.cols:
355 for n in c:
356 n.open=n.close=0
357 n.total= n.path_cost=0
358 n.parent=None
359
Referenced by gui.graph.grid.findPath().
◆ cols
gui.graph.grid.cols
Definition at line 330 of file graph.py.
Referenced by gui.graph.grid.get(), gui.graph.grid.neighbours(), and gui.graph.grid.reset().
◆ graph
gui.graph.grid.graph
◆ open
gui.graph.grid.open
Definition at line 410 of file graph.py.
◆ xs
gui.graph.grid.xs
Definition at line 328 of file graph.py.
Referenced by gui.graph.grid.get().
◆ ys
gui.graph.grid.ys
Definition at line 329 of file graph.py.
