YACS::ENGINE::SetOfPoints Class Reference
#include <SetOfPoints.hxx>
Collaboration diagram for YACS::ENGINE::SetOfPoints:
 SetOfPoints (const std::list< Node * > &nodes)
 SetOfPoints (BagPoint *bp)
 ~SetOfPoints ()
void basicSimplify ()
void simplify ()
std::string getRepr () const
AbstractPoint * findPointWithNode (Node *node)
const std::list< AbstractPoint * > & getListOfPoints () const
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
AbstractPoint * getUniqueAndReleaseIt () const
void accept (PointVisitor *pv)
BagPoint * _bp
Definition at line 41 of file SetOfPoints.hxx.
◆ SetOfPoints() [1/2]
SetOfPoints::SetOfPoints ( const std::list< Node * > &  nodes)
Definition at line 31 of file SetOfPoints.cxx.
31 :_bp(0)
32{
33 std::list<AbstractPoint *> nodes2;
34 for(std::list<Node *>::const_iterator it=nodes.begin();it!=nodes.end();it++)
35 {
36 nodes2.push_back(new ElementaryPoint(*it));
37 }
38 _bp=new BagPoint(nodes2,0);
39}
References _bp.
◆ SetOfPoints() [2/2]
YACS::ENGINE::SetOfPoints::SetOfPoints ( BagPoint *  bp)
Definition at line 45 of file SetOfPoints.hxx.
45:_bp(bp) { }
◆ ~SetOfPoints()
SetOfPoints::~SetOfPoints ( )
Definition at line 41 of file SetOfPoints.cxx.
42{
43 delete _bp;
44}
References _bp.
◆ accept()
void SetOfPoints::accept ( PointVisitor *  pv)
Definition at line 136 of file SetOfPoints.cxx.
137{
138 _bp->accept(pv);
139}
void accept(PointVisitor *pv) override
Definition: BagPoint.cxx:38
References _bp, and YACS::ENGINE::BagPoint::accept().
◆ basicSimplify()
void SetOfPoints::basicSimplify ( )
Definition at line 46 of file SetOfPoints.cxx.
47{
48 while(_bp->size()>1)
49 {
50 bool somethingDone(false);
51 _bp->deal1(somethingDone);
52 if(somethingDone)
53 continue;
54 _bp->deal2(somethingDone);
55 if(somethingDone)
56 continue;
57 _bp->deal2Bis(somethingDone);
58 if(somethingDone)
59 continue;
60 _bp->deal2Ter(somethingDone);
61 if(somethingDone)
62 continue;
63 _bp->deal2Quatro(somethingDone);
64 if(!somethingDone)
65 throw Exception("SetOfPoints::simplify : not implemented yet !\nPlease check if there are any recursively redundant links (can be removed by removeRecursivelyRedundantCL method).");
66 }
67}
void deal2Quatro(bool &somethingDone)
Definition: BagPoint.cxx:178
void deal2Bis(bool &somethingDone)
Definition: BagPoint.cxx:144
void deal1(bool &somethingDone)
Definition: BagPoint.cxx:109
void deal2(bool &somethingDone)
Definition: BagPoint.cxx:127
void deal2Ter(bool &somethingDone)
Definition: BagPoint.cxx:161
References _bp, YACS::ENGINE::BagPoint::deal1(), YACS::ENGINE::BagPoint::deal2(), YACS::ENGINE::BagPoint::deal2Bis(), YACS::ENGINE::BagPoint::deal2Quatro(), YACS::ENGINE::BagPoint::deal2Ter(), and YACS::ENGINE::BagPoint::size().
Referenced by YACS::ENGINE::AbstractPoint::TryAsNotSimpleCase().
◆ findPointWithNode()
AbstractPoint * SetOfPoints::findPointWithNode ( Node *  node)
Definition at line 104 of file SetOfPoints.cxx.
105{
106 if(node==0)
107 return 0;
108 return _bp->findPointWithNode(node);
109}
AbstractPoint * findPointWithNode(Node *node)
Definition: BlocPoint.cxx:52
References _bp, and YACS::ENGINE::BlocPoint::findPointWithNode().
◆ getListOfPoints()
const std::list< AbstractPoint * > & SetOfPoints::getListOfPoints ( ) const
Definition at line 111 of file SetOfPoints.cxx.
112{
113 return _bp->getListOfPoints();
114}
const std::list< AbstractPoint * > & getListOfPoints() const
Definition: BlocPoint.hxx:46
References _bp, and YACS::ENGINE::BlocPoint::getListOfPoints().
◆ getMaxLevelOfParallelism()
int SetOfPoints::getMaxLevelOfParallelism ( ) const
Definition at line 116 of file SetOfPoints.cxx.
117{
119}
int getMaxLevelOfParallelism() const
Definition: BagPoint.cxx:71
References _bp, and YACS::ENGINE::BagPoint::getMaxLevelOfParallelism().
◆ getRepr()
std::string SetOfPoints::getRepr ( ) const
Definition at line 99 of file SetOfPoints.cxx.
100{
101 return _bp->getRepr();
102}
std::string getRepr() const
Definition: BagPoint.cxx:86
References _bp, and YACS::ENGINE::BagPoint::getRepr().
◆ getUniqueAndReleaseIt()
AbstractPoint * SetOfPoints::getUniqueAndReleaseIt ( ) const
◆ getWeightRegardingDPL()
void SetOfPoints::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 121 of file SetOfPoints.cxx.
122{
123 _bp->getWeightRegardingDPL(weight);
124}
void getWeightRegardingDPL(ComplexWeight *weight)
Definition: BagPoint.cxx:76
References _bp, and YACS::ENGINE::BagPoint::getWeightRegardingDPL().
◆ partitionRegardingDPL()
void SetOfPoints::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 126 of file SetOfPoints.cxx.
127{
128 _bp->partitionRegardingDPL(pd,zeMap);
129}
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
Definition: BagPoint.cxx:81
References _bp, and YACS::ENGINE::BagPoint::partitionRegardingDPL().
◆ simplify()
void SetOfPoints::simplify ( )
Definition at line 69 of file SetOfPoints.cxx.
70{
72 {
73 bool somethingDone(false);
74 _bp->deal1(somethingDone);
75 if(somethingDone)
76 continue;
77 _bp->deal2(somethingDone);
78 if(somethingDone)
79 continue;
80 _bp->deal2Bis(somethingDone);
81 if(somethingDone)
82 continue;
83 _bp->deal2Ter(somethingDone);
84 if(somethingDone)
85 continue;
86 _bp->deal2Quatro(somethingDone);
87 if(somethingDone)
88 continue;
89 _bp->dealNotSimpleCase(somethingDone);
90 if(!somethingDone)
91 throw Exception("SetOfPoints::simplify : not implemented yet !\nPlease check if there are any recursively redundant links (can be removed by removeRecursivelyRedundantCL method).");
92 }
94 {
96 }
97}
void dealNotSimpleCase(bool &somethingDone)
Definition: BagPoint.cxx:199
bool presenceOfNonSimpleCase() const
Definition: BlocPoint.cxx:165
bool internalContinueForSimplify() const
Definition: BlocPoint.cxx:158
References _bp, YACS::ENGINE::BagPoint::deal1(), YACS::ENGINE::BagPoint::deal2(), YACS::ENGINE::BagPoint::deal2Bis(), YACS::ENGINE::BagPoint::deal2Quatro(), YACS::ENGINE::BagPoint::deal2Ter(), YACS::ENGINE::BagPoint::dealNotSimpleCase(), YACS::ENGINE::BagPoint::expandNonSimpleCase(), YACS::ENGINE::BlocPoint::internalContinueForSimplify(), and YACS::ENGINE::BlocPoint::presenceOfNonSimpleCase().
Referenced by YACS::ENGINE::Bloc::analyzeParallelism().
◆ _bp
