YACS::ENGINE::BagPoint Class Reference
#include <BagPoint.hxx>
Inheritance diagram for YACS::ENGINE::BagPoint:
Collaboration diagram for YACS::ENGINE::BagPoint:
 BagPoint ()=default
 BagPoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
AbstractPoint * deepCopy (AbstractPoint *father) const override
Node * getFirstNode () override
Node * getLastNode () override
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
std::string getRepr () const
void accept (PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
int size () const
void replaceInMe (BlocPoint *aSet)
void deal1 (bool &somethingDone)
void deal2 (bool &somethingDone)
void deal2Bis (bool &somethingDone)
void deal2Ter (bool &somethingDone)
void deal2Quatro (bool &somethingDone)
void dealNotSimpleCase (bool &somethingDone)
void expandNonSimpleCase ()
- Public Member Functions inherited from YACS::ENGINE::BlocPoint
 BlocPoint ()=default
 BlocPoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
void deepCopyFrom (const BlocPoint &other)
AbstractPoint * findPointWithNode (Node *node)
AbstractPoint * getNodeAfter (Node *node)
AbstractPoint * getNodeB4 (Node *node)
bool contains (Node *node) const override
bool anyOf (const std::set< Node * > &nodes) const override
int getNumberOfNodes () const
const std::list< AbstractPoint * > & getListOfPoints () const
virtual ~BlocPoint ()
bool internalContinueForSimplify () const
bool presenceOfNonSimpleCase () const
AbstractPoint * getUnique ()
const AbstractPoint * getUnique () const
AbstractPoint * getUniqueAndReleaseIt ()
- Public Member Functions inherited from YACS::ENGINE::AbstractPoint
 AbstractPoint ()=default
 AbstractPoint (AbstractPoint *father)
AbstractPoint * getFather () const
AbstractPoint * getGodFather ()
bool amIGod ()
void setFather (AbstractPoint *father)
bool isBegin ()
bool isLast ()
bool isSimplyLinkedBeforeAfter (BlocPoint *sop)
bool isSimplyLinkedAfterNullBefore (BlocPoint *sop)
bool isSimplyLinkedBeforeNullAfter (BlocPoint *sop)
bool isNullBeforeNullAfter (BlocPoint *sop)
LinkedBlocPoint * tryAsLink (BlocPoint *sop)
ForkBlocPoint * tryAsFork (BlocPoint *sop)
ForkBlocPoint * tryAsForkBis (BlocPoint *sop)
ForkBlocPoint * tryAsForkTer (BlocPoint *sop)
ForkBlocPoint * tryAsForkQuatro (BlocPoint *sop)
virtual AbstractPoint * deepCopy (AbstractPoint *father) const =0
virtual Node * getFirstNode ()=0
virtual Node * getLastNode ()=0
virtual AbstractPoint * findPointWithNode (Node *node)=0
virtual bool contains (Node *node) const =0
virtual bool anyOf (const std::set< Node * > &nodes) const =0
virtual int getNumberOfNodes () const =0
virtual void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
virtual std::string getRepr () const =0
virtual void accept (PointVisitor *pv)=0
virtual AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes)=0
virtual ~AbstractPoint ()
bool isSimplyLinkedAfter (BlocPoint *sop, Node *node)
bool isSimplyLinkedBefore (BlocPoint *sop, Node *node)
void expandNonSimpleCaseOn (AbstractPoint *pathologicalPt)
- Static Public Member Functions inherited from YACS::ENGINE::AbstractPoint
static void TryAsNotSimpleCase (AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
static bool IsGatherB4Ext (Node *node)
static bool IsSimplyLinkedAfterExt (Node *node)
static bool IsScatterAfterExt (Node *node)
static bool IsSimplyLinkedBeforeExt (Node *node)
static bool IsNoLinksBefore (Node *node)
static bool IsNoLinksAfter (Node *node)
static Node * GetNodeB4 (Node *node)
static Node * GetNodeAfter (Node *node)
static AbstractPoint * GetDirectSonOf (AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)
static void FeedData (AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void FeedData (const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void Rewire (const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void UnRewire (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)
static void Display (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
- Protected Member Functions inherited from YACS::ENGINE::BlocPoint
void getOutPoint (AbstractPoint *node)
- Protected Attributes inherited from YACS::ENGINE::BlocPoint
std::list< AbstractPoint * > _nodes
- Protected Attributes inherited from YACS::ENGINE::AbstractPoint
AbstractPoint * _father = nullptr
Definition at line 32 of file BagPoint.hxx.
◆ BagPoint() [1/2]
YACS::ENGINE::BagPoint::BagPoint ( )
default
◆ BagPoint() [2/2]
BagPoint::BagPoint ( const std::list< AbstractPoint * > &  nodes,
AbstractPoint *  father
Definition at line 34 of file BagPoint.cxx.
34 :BlocPoint(nodes,father)
35{
36}
◆ accept()
void BagPoint::accept ( PointVisitor *  pv)
overridevirtual
Implements YACS::ENGINE::AbstractPoint.
Definition at line 38 of file BagPoint.cxx.
39{
40 for(auto it : _nodes)
41 {
42 if(!it)
43 throw YACS::Exception("BagPoint::accept : Ooops !");
44 it->accept(pv);
45 }
46}
Definition: BlocPoint.hxx:35
References YACS::ENGINE::BlocPoint::_nodes.
Referenced by YACS::ENGINE::SetOfPoints::accept().
◆ deal1()
void BagPoint::deal1 ( bool &  somethingDone)
Definition at line 109 of file BagPoint.cxx.
110{
111 somethingDone=false;
112 for(std::list<AbstractPoint *>::iterator it=_nodes.begin();it!=_nodes.end();it++)
113 {
114 if(!(*it)->isSimplyLinkedBeforeAfter(this))
115 if(!(*it)->isSimplyLinkedAfterNullBefore(this) && !(*it)->isSimplyLinkedBeforeNullAfter(this))
116 continue;
117 LinkedBlocPoint *try0((*it)->tryAsLink(this));
118 if(try0)
119 {
120 replaceInMe(try0);
121 somethingDone=true;
122 break;
123 }
124 }
125}
void replaceInMe(BlocPoint *aSet)
Definition: BagPoint.cxx:96
References YACS::ENGINE::BlocPoint::_nodes, and replaceInMe().
Referenced by YACS::ENGINE::SetOfPoints::basicSimplify(), and YACS::ENGINE::SetOfPoints::simplify().
◆ deal2()
void BagPoint::deal2 ( bool &  somethingDone)
Definition at line 127 of file BagPoint.cxx.
128{
129 somethingDone=false;
130 for(std::list<AbstractPoint *>::iterator it=_nodes.begin();it!=_nodes.end();it++)
131 {
132 if(!(*it)->isSimplyLinkedBeforeAfter(this))
133 continue;
134 ForkBlocPoint *try1((*it)->tryAsFork(this));
135 if(try1)
136 {
137 replaceInMe(try1);
138 somethingDone=true;
139 break;
140 }
141 }
142}
◆ deal2Bis()
void BagPoint::deal2Bis ( bool &  somethingDone)
Definition at line 144 of file BagPoint.cxx.
145{
146 somethingDone=false;
147 for(std::list<AbstractPoint *>::iterator it=_nodes.begin();it!=_nodes.end();it++)
148 {
149 if(!(*it)->isSimplyLinkedAfterNullBefore(this))
150 continue;
151 ForkBlocPoint *try1((*it)->tryAsForkBis(this));
152 if(try1)
153 {
154 replaceInMe(try1);
155 somethingDone=true;
156 break;
157 }
158 }
159}
◆ deal2Quatro()
void BagPoint::deal2Quatro ( bool &  somethingDone)
Definition at line 178 of file BagPoint.cxx.
179{
180 somethingDone=false;
181 for(std::list<AbstractPoint *>::iterator it=_nodes.begin();it!=_nodes.end();it++)
182 {
183 if(!(*it)->isNullBeforeNullAfter(this))
184 continue;
185 ForkBlocPoint *try1((*it)->tryAsForkQuatro(this));
186 if(try1)
187 {
188 replaceInMe(try1);
189 somethingDone=true;
190 break;
191 }
192 }
193}
◆ deal2Ter()
void BagPoint::deal2Ter ( bool &  somethingDone)
Definition at line 161 of file BagPoint.cxx.
162{
163 somethingDone=false;
164 for(std::list<AbstractPoint *>::iterator it=_nodes.begin();it!=_nodes.end();it++)
165 {
166 if(!(*it)->isSimplyLinkedBeforeNullAfter(this))
167 continue;
168 ForkBlocPoint *try1((*it)->tryAsForkTer(this));
169 if(try1)
170 {
171 replaceInMe(try1);
172 somethingDone=true;
173 break;
174 }
175 }
176}
◆ dealNotSimpleCase()
void BagPoint::dealNotSimpleCase ( bool &  somethingDone)
This method remove 1, 2 or 3 points from this by flagging them as pathological nodes. By doing so, we hope to simplify enough to have a standart case.
Definition at line 199 of file BagPoint.cxx.
200{
201 somethingDone=false;
202 for(auto it=_nodes.begin();it!=_nodes.end();it++)
203 {
204 std::vector<AbstractPoint *> v{*it};
205 AbstractPoint::TryAsNotSimpleCase((*it)->getFather(),v,_nodes,somethingDone);
206 if(somethingDone)
207 break;
208 }
209 if(somethingDone)
210 return ;
211 //
212 for(auto it=_nodes.cbegin();it!=_nodes.cend();it++)
213 {
214 auto it2(it); it2++;
215 for(;it2!=_nodes.cend();it2++)
216 {
217 std::vector<AbstractPoint *> v{*it,*it2};
218 AbstractPoint::TryAsNotSimpleCase((*it)->getFather(),v,_nodes,somethingDone);
219 if(somethingDone)
220 return;
221 }
222 }
223 if(somethingDone)
224 return ;
225 //
226 for(auto it=_nodes.cbegin();it!=_nodes.cend();it++)
227 {
228 auto it2(it); it2++;
229 for(;it2!=_nodes.cend();it2++)
230 {
231 auto it3(it2); it3++;
232 for(;it3!=_nodes.cend();it3++)
233 {
234 std::vector<AbstractPoint *> v{*it,*it2,*it3};
235 AbstractPoint::TryAsNotSimpleCase((*it)->getFather(),v,_nodes,somethingDone);
236 if(somethingDone)
237 return;
238 }
239 }
240 }
241}
static void TryAsNotSimpleCase(AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
References YACS::ENGINE::BlocPoint::_nodes, and YACS::ENGINE::AbstractPoint::TryAsNotSimpleCase().
Referenced by YACS::ENGINE::SetOfPoints::simplify().
◆ deepCopy()
AbstractPoint * BagPoint::deepCopy ( AbstractPoint *  father) const
overridevirtual
Definition at line 53 of file BagPoint.cxx.
54{
55 BagPoint *ret(new BagPoint);
56 ret->deepCopyFrom(*this);
57 ret->setFather(father);
58 return ret;
59}
References YACS::ENGINE::BlocPoint::deepCopyFrom(), and YACS::ENGINE::AbstractPoint::setFather().
◆ expandNonSimpleCase()
void BagPoint::expandNonSimpleCase ( )
All NotSimpleCasePoint instances in this->_nodes are going to be scanned recursively accross this->_nodes. To do that NotSimpleCasePoint instance are added incrementaly.
Definition at line 297 of file BagPoint.cxx.
298{
299 std::vector<AbstractPoint *> pathologicalPt;
300 std::for_each(_nodes.begin(),_nodes.end(),[&pathologicalPt](AbstractPoint *elt) { if(dynamic_cast<NotSimpleCasePoint *>(elt)) pathologicalPt.push_back(elt); });
301 if(pathologicalPt.empty())
302 throw YACS::Exception("BagPoint::expandNonSimpleCase : Not found any pathological case !");
303 for(auto it : pathologicalPt)
304 this->expandNonSimpleCaseOn(it);
305
306}
AbstractPoint * expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
Definition: BagPoint.cxx:48
References YACS::ENGINE::BlocPoint::_nodes, and expandNonSimpleCaseOn().
◆ expandNonSimpleCaseOn() [1/2]
void BagPoint::expandNonSimpleCaseOn ( AbstractPoint *  pathologicalPt)
Append a single pathologicalPt point instance to AbstractPoint instances contained in this. To do that we start to locate in graph dependancy in this with ENGINE::Node cannot run in parallel with pathologicalPt. These nodes stored in nodesBeforeAfter.
By walking across Points in this if a Point has no intersection with nodesBeforeAfter this Point is converted to a ForkBlocPoint.
Definition at line 249 of file BagPoint.cxx.
250{
251 NotSimpleCasePoint *pathologicalPt2(dynamic_cast<NotSimpleCasePoint *>(pathologicalPt));
252 if(!pathologicalPt2)
253 throw YACS::Exception("BagPoint::expandNonSimpleCaseOn : pathologicalPt is expected to be a NotSimpleCasePoint !");
254 std::list<AbstractPoint *> nodes2;
255 std::for_each(_nodes.begin(),_nodes.end(),[&nodes2](AbstractPoint *elt) { if(!dynamic_cast<NotSimpleCasePoint *>(elt)) nodes2.push_back(elt); });
256 if(nodes2.size()!=1)
257 throw YACS::Exception("BagPoint::expandNonSimpleCaseOn : Internal error only one AbstractPoint is expected !");
258
259 Node *firstNode(pathologicalPt->getFirstNode()),*lastNode(pathologicalPt->getLastNode());
260 //
261 ComposedNode *parent(firstNode->getFather());
262 Bloc *parentc(dynamic_cast<Bloc *>(parent));
263 if(!parentc)
264 throw YACS::Exception("BagPoint::expandNonSimpleCaseOn : internal error, Bloc expected");
265 //
266 std::set<Node *> nodesBefore, nodesAfter;
267 {
268 std::map<Node *, std::set<Node *> > accelStr;
269 LinkInfo info(E_ALL);
270 parentc->findAllNodesStartingFrom<false>(firstNode,nodesBefore,accelStr,info);
271 }
272 {
273 std::map<Node *, std::set<Node *> > accelStr;
274 LinkInfo info(E_ALL);
275 parentc->findAllNodesStartingFrom<true>(lastNode,nodesAfter,accelStr,info);
276 }
277 //
278 std::set<Node *> nodesBeforeAfter(nodesBefore.begin(),nodesBefore.end());
279 nodesBeforeAfter.insert(nodesAfter.begin(),nodesAfter.end());
280 //std::for_each(nodesBeforeAfter.begin(),nodesBeforeAfter.end(),[](Node *elt) { std::cerr << elt->getName() << " "; }); std::cerr << std::endl;
281 //
282 AbstractPoint *onlyOne(*nodes2.begin());
283 AbstractPoint *res(onlyOne->expandNonSimpleCaseOn(pathologicalPt2,nodesBeforeAfter));
284 if(res!=onlyOne)
285 throw YACS::Exception("BagPoint::expandNonSimpleCaseOn : unexpected situation !");// impossible because by construction pathologicalPt cannot be merged to this. If it were possible, algo in simplify would be simply it !
286 {// remove delete pathologicalPt and remove it from this->_nodes
287 std::list<AbstractPoint *> nodes3;
288 std::for_each(_nodes.begin(),_nodes.end(),[&nodes3,pathologicalPt](AbstractPoint *elt) { if(elt!=pathologicalPt) nodes3.push_back(elt); else delete elt; });
289 _nodes = nodes3;
290 }
291}
virtual Node * getFirstNode()=0
virtual Node * getLastNode()=0
Definition: Bloc.hxx:36
Class that deal with list of semantics links for high level analysis.
Definition: LinkInfo.hxx:83
Base class for all nodes.
Definition: Node.hxx:70
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::E_ALL, YACS::ENGINE::AbstractPoint::expandNonSimpleCaseOn(), YACS::ENGINE::Bloc::findAllNodesStartingFrom(), YACS::ENGINE::AbstractPoint::getFirstNode(), and YACS::ENGINE::AbstractPoint::getLastNode().
◆ expandNonSimpleCaseOn() [2/2]
AbstractPoint * BagPoint::expandNonSimpleCaseOn ( NotSimpleCasePoint *  pathologicalPt,
const std::set< Node * > &  uncatchedNodes
overridevirtual
Definition at line 48 of file BagPoint.cxx.
49{
50 throw YACS::Exception("BagPoint::expandNonSimpleCaseOn : Ooops !");
51}
Referenced by expandNonSimpleCase().
◆ getFirstNode()
Node * BagPoint::getFirstNode ( )
overridevirtual
Definition at line 61 of file BagPoint.cxx.
62{
63 return getUnique()->getFirstNode();
64}
AbstractPoint * getUnique()
Definition: BlocPoint.cxx:111
References YACS::ENGINE::AbstractPoint::getFirstNode(), and YACS::ENGINE::BlocPoint::getUnique().
◆ getLastNode()
Node * BagPoint::getLastNode ( )
overridevirtual
◆ getMaxLevelOfParallelism()
int BagPoint::getMaxLevelOfParallelism ( ) const
◆ getRepr()
std::string BagPoint::getRepr ( ) const
Definition at line 86 of file BagPoint.cxx.
87{
88 std::ostringstream oss;
89 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
90 oss << (*it)->getRepr() << " - ";
91 return oss.str();
92}
Referenced by YACS::ENGINE::SetOfPoints::getRepr().
◆ getWeightRegardingDPL()
void BagPoint::getWeightRegardingDPL ( ComplexWeight *  weight)
◆ partitionRegardingDPL()
void BagPoint::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 81 of file BagPoint.cxx.
82{
84}
virtual void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
References YACS::ENGINE::BlocPoint::getUnique(), and YACS::ENGINE::AbstractPoint::partitionRegardingDPL().
Referenced by YACS::ENGINE::SetOfPoints::partitionRegardingDPL().
◆ replaceInMe()
void BagPoint::replaceInMe ( BlocPoint *  aSet)
Definition at line 96 of file BagPoint.cxx.
97{
98 const std::list<AbstractPoint *>& pts(aSet->getListOfPoints());
99 for(std::list<AbstractPoint *>::const_iterator it0=pts.begin();it0!=pts.end();it0++)
100 {
101 std::list<AbstractPoint *>::iterator it1(std::find(_nodes.begin(),_nodes.end(),*it0));
102 if(it1==_nodes.end())
103 throw Exception("SetOfPoints::replaceInMe : internal error !");
104 _nodes.erase(it1);
105 }
106 _nodes.push_back(aSet);
107}
const std::list< AbstractPoint * > & getListOfPoints() const
Definition: BlocPoint.hxx:46
References YACS::ENGINE::BlocPoint::_nodes, and YACS::ENGINE::BlocPoint::getListOfPoints().
Referenced by deal1(), deal2(), deal2Bis(), deal2Quatro(), and deal2Ter().
◆ size()
int YACS::ENGINE::BagPoint::size ( ) const
Definition at line 48 of file BagPoint.hxx.
48{ return (int)_nodes.size(); }
Referenced by YACS::ENGINE::SetOfPoints::basicSimplify().
