YACS::ENGINE::InputPort4DF2DS Class Reference
#include <Loop.hxx>
Inheritance diagram for YACS::ENGINE::InputPort4DF2DS:
Collaboration diagram for YACS::ENGINE::InputPort4DF2DS:
 InputPort4DF2DS (DFToDSForLoop *node, TypeCode *type)
void releaseData () override
void put (const void *data)
void * get () const
void exRestoreInit ()
void exSaveInit ()
void put (Any *data)
 ~InputPort4DF2DS ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Any * _data
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 41 of file Loop.hxx.
◆ InputPort4DF2DS()
InputPort4DF2DS::InputPort4DF2DS ( DFToDSForLoop *  node,
TypeCode *  type
Definition at line 37 of file Loop.cxx.
37 :
38 InputPort("", node, type),
39 DataPort("", node, type),
40 Port(node),_data(0)
41{
42}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
◆ ~InputPort4DF2DS()
InputPort4DF2DS::~InputPort4DF2DS ( )
Definition at line 102 of file Loop.cxx.
103{
104 if(_data)
105 _data->decrRef();
106}
References _data, and YACS::ENGINE::RefCounter::decrRef().
◆ clone()
InputPort * InputPort4DF2DS::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 83 of file Loop.cxx.
84{
85 throw Exception("InputPort4DF2DS::clone : internal error");
86}
◆ exRestoreInit()
void InputPort4DF2DS::exRestoreInit ( )
◆ exSaveInit()
void InputPort4DF2DS::exSaveInit ( )
◆ get()
void * InputPort4DF2DS::get ( ) const
Definition at line 50 of file Loop.cxx.
51{
52 if(!_data)
53 {
54 std::string what="InputPort4DF2DS::get : no value currently in input whith name \""; what+=_name; what+="\"";
55 throw Exception(what);
56 }
57 return (void *)_data;
58}
References _data, and YACS::ENGINE::DataPort::_name.
◆ getAllRepresentants()
void InputPort4DF2DS::getAllRepresentants ( std::set< InPort * > &  repr) const
Reimplemented from YACS::ENGINE::InPort.
Definition at line 44 of file Loop.cxx.
45{
46 set<InPort *> s=_node->getOutputDataStreamPort("")->edSetInPort();
47 repr.insert(s.begin(),s.end());
48}
virtual OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const =0
std::set< InPort * > edSetInPort() const
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, YACS::ENGINE::OutputDataStreamPort::edSetInPort(), and YACS::ENGINE::Node::getOutputDataStreamPort().
◆ put() [1/2]
void InputPort4DF2DS::put ( Any *  data)
Definition at line 95 of file Loop.cxx.
96{
98 _data=data;
99 _data->incrRef();
100}
void releaseData() override
Definition: Loop.cxx:88
References _data, YACS::ENGINE::RefCounter::incrRef(), and releaseData().
◆ put() [2/2]
void InputPort4DF2DS::put ( const void *  data)
Definition at line 78 of file Loop.cxx.
79{
80 put((Any *)data);
81}
Definition: Any.hxx:79
void put(const void *data)
Definition: Loop.cxx:78
References put().
Referenced by put().
◆ releaseData()
void InputPort4DF2DS::releaseData ( )
overridevirtual
Definition at line 88 of file Loop.cxx.
89{
90 if(_data)
91 _data->decrRef();
92 _data = nullptr;
93}
◆ _data
Any* YACS::ENGINE::InputPort4DF2DS::_data
Definition at line 55 of file Loop.hxx.
Referenced by exRestoreInit(), exSaveInit(), get(), put(), releaseData(), and ~InputPort4DF2DS().
