YACS::ENGINE::InputDataStreamPort4DS2DF Class Reference
#include <Loop.hxx>
Inheritance diagram for YACS::ENGINE::InputDataStreamPort4DS2DF:
Collaboration diagram for YACS::ENGINE::InputDataStreamPort4DS2DF:
 InputDataStreamPort4DS2DF (DSToDFForLoop *node, TypeCode *type)
- Public Member Functions inherited from YACS::ENGINE::InputDataStreamPort
 InputDataStreamPort (const InputDataStreamPort &other, Node *newHelder)
 InputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~InputDataStreamPort ()
virtual InputDataStreamPort * clone (Node *newHelder) const
virtual void edAddOutputDataStreamPort (OutputDataStreamPort *port)
std::set< OutputDataStreamPort * > getConnectedOutputDataStreamPort ()
- Public Member Functions inherited from YACS::ENGINE::DataStreamPort
 Set a new value for a property of the port. More...
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
- Static Public Attributes inherited from YACS::ENGINE::InputDataStreamPort
static const char NAME [] ="InputDataStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::DataStreamPort
static const char NAME [] ="DataStreamPort"
- Protected Member Functions inherited from YACS::ENGINE::DataStreamPort
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
virtual ~DataPort ()
 Port (Node *node)
- Protected Attributes inherited from YACS::ENGINE::InputDataStreamPort
std::set< OutputDataStreamPort * > _setOfOutputDataStreamPort
- Protected Attributes inherited from YACS::ENGINE::DataStreamPort
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 92 of file Loop.hxx.
◆ InputDataStreamPort4DS2DF()
InputDataStreamPort4DS2DF::InputDataStreamPort4DS2DF ( DSToDFForLoop *  node,
TypeCode *  type
Definition at line 195 of file Loop.cxx.
195 :
196 InputDataStreamPort("", node, type),
197 DataPort("", node, type),
198 Port(node)
199{
200}
Definition: DataPort.cxx:41
InputDataStreamPort(const InputDataStreamPort &other, Node *newHelder)
Port(Node *node)
Definition: Port.cxx:34
◆ getAllRepresentants()
void InputDataStreamPort4DS2DF::getAllRepresentants ( std::set< InPort * > &  repr) const
Reimplemented from YACS::ENGINE::InPort.
Definition at line 202 of file Loop.cxx.
203{
204 set<InPort *> s=_node->getOutputPort("")->edSetInPort();
205 repr.insert(s.begin(),s.end());
206}
virtual OutputPort * getOutputPort(const std::string &name) const =0
std::set< InPort * > edSetInPort() const
Definition: OutputPort.cxx:239
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, YACS::ENGINE::OutputPort::edSetInPort(), and YACS::ENGINE::Node::getOutputPort().
