YACS::ENGINE::SeqAlloc Class Reference
#include <Any.hxx>
Collaboration diagram for YACS::ENGINE::SeqAlloc:
Static Public Attributes
static const char DFT_CHAR_VAR =-17
 SeqAlloc (const SeqAlloc &other)
 SeqAlloc (unsigned int sizeOf1Elm)
 ~SeqAlloc ()
void clear ()
void initCoarseMemory (char *mem, unsigned int size, Deallocator dealloc)
void construct (char *pt, const Any *val)
void construct (char *pt, const char *val, const TypeCode *tc, bool deepCpy)
char * allocate (unsigned int nbOfByte)
void destroy (char *pt, const TypeCode *tc)
void deallocate (char *pt)
unsigned int size () const
std::vector< unsigned int > getSetItems () const
char * _start
char * _finish
char * _endOfStorage
Deallocator _notStdDeAlloc
const unsigned int _sizeOf1Elm
Friends
class SequenceAny
Definition at line 158 of file Any.hxx.
◆ SeqAlloc() [1/2]
SeqAlloc::SeqAlloc ( const SeqAlloc &  other)
Definition at line 541 of file Any.cxx.
543{
544 _start=allocate(other._finish-other._start);
545 _finish=_start+(other._finish-other._start);
547}
Definition: Any.hxx:164
Definition: Any.hxx:166
char * allocate(unsigned int nbOfByte)
Definition: Any.cxx:610
Definition: Any.hxx:165
References _endOfStorage, _finish, _start, and allocate().
◆ SeqAlloc() [2/2]
SeqAlloc::SeqAlloc ( unsigned int  sizeOf1Elm)
Definition at line 549 of file Any.cxx.
549 :_sizeOf1Elm(sizeOf1Elm),_notStdDeAlloc(0),
551{
552}
◆ ~SeqAlloc()
SeqAlloc::~SeqAlloc ( )
Definition at line 554 of file Any.cxx.
555{
557}
void deallocate(char *pt)
Definition: Any.cxx:619
References _start, and deallocate().
◆ allocate()
char * SeqAlloc::allocate ( unsigned int  nbOfByte)
Definition at line 610 of file Any.cxx.
611{
612 if(nbOfByte>0)
613 return (char *)::operator new(nbOfByte);
614 else
615 return 0;
616}
Referenced by initCoarseMemory(), YACS::ENGINE::SequenceAny::realloc(), and SeqAlloc().
◆ clear()
void SeqAlloc::clear ( )
Definition at line 559 of file Any.cxx.
560{
562 _start=0;
563 _finish=0;
565}
References _endOfStorage, _finish, _start, and deallocate().
Referenced by YACS::ENGINE::SequenceAny::clear().
◆ construct() [1/2]
void SeqAlloc::construct ( char *  pt,
const Any *  val
◆ construct() [2/2]
const char *  val,
const TypeCode *  tc,
bool  deepCpy
: This performs the placement new or zip info into pt.
pt:
val: the source from which the construction will be performed.
tc:
deepCpy: If true in pt place a deep copy pointed by val will be put.
Definition at line 605 of file Any.cxx.
606{
607 tc->putReprAtPlace(pt,val,deepCpy);
608}
virtual void putReprAtPlace(char *pt, const char *val, bool deepCpy) const
Definition: TypeCode.cxx:57
References YACS::ENGINE::TypeCode::putReprAtPlace().
◆ deallocate()
void SeqAlloc::deallocate ( char *  pt)
Definition at line 619 of file Any.cxx.
620{
621 if(pt)
622 {
623 if(!_notStdDeAlloc)
624 ::operator delete(pt);
625 else
626 {
627 _notStdDeAlloc(pt);
629 }
630 }
631}
References _notStdDeAlloc.
Referenced by clear(), YACS::ENGINE::SequenceAny::realloc(), and ~SeqAlloc().
◆ destroy()
void SeqAlloc::destroy ( char *  pt,
const TypeCode *  tc
◆ getSetItems()
std::vector< unsigned int > SeqAlloc::getSetItems ( ) const
Definition at line 643 of file Any.cxx.
644{
645 std::vector<unsigned int> ret;
646 unsigned int sz(size());
647 for(unsigned int i=0;i<sz;i++)
648 {
649 const char *pt(_start+i*_sizeOf1Elm);
650 for(unsigned j=0;j<_sizeOf1Elm && *pt==DFT_CHAR_VAR;j++,pt++); //see initCoarseMemory
651 if(pt!=_start+(i+1)*_sizeOf1Elm)
652 ret.push_back(i);
653 }
654 return ret;
655}
Definition: Any.hxx:181
unsigned int size() const
Definition: Any.cxx:638
References _sizeOf1Elm, _start, DFT_CHAR_VAR, yacsorb.CORBAEngineTest::i, and size().
◆ initCoarseMemory()
void SeqAlloc::initCoarseMemory ( char *  mem,
unsigned int  size,
Deallocator  dealloc
: This method is exclusively reserved for arrays of C++ built-in types because no constructor is applied atomically.
Definition at line 571 of file Any.cxx.
572{
573 unsigned sizeInByte=size*_sizeOf1Elm;
574 if(dealloc)
575 {
576 _notStdDeAlloc=dealloc;
577 _start=mem;
578 }
579 else
580 {
581 _start=allocate(sizeInByte);
582 if(mem)
583 memcpy(_start,mem,sizeInByte);
584 else
585 {
586 for(unsigned int i=0;i<sizeInByte;i++) _start[i]=DFT_CHAR_VAR;// see getSetItems
587 }
588 }
589 _finish=_start+sizeInByte;
591}
References _endOfStorage, _finish, _notStdDeAlloc, _sizeOf1Elm, _start, allocate(), DFT_CHAR_VAR, yacsorb.CORBAEngineTest::i, and size().
Referenced by YACS::ENGINE::SequenceAny::SequenceAny().
◆ size()
unsigned int SeqAlloc::size ( ) const
Definition at line 638 of file Any.cxx.
639{
640 return (_finish-_start)/_sizeOf1Elm;
641}
References _finish, _sizeOf1Elm, and _start.
Referenced by getSetItems(), and initCoarseMemory().
◆ SequenceAny
friend class SequenceAny
friend
Definition at line 160 of file Any.hxx.
◆ _endOfStorage
char* YACS::ENGINE::SeqAlloc::_endOfStorage
◆ _finish
◆ _notStdDeAlloc
Deallocator YACS::ENGINE::SeqAlloc::_notStdDeAlloc
Definition at line 165 of file Any.hxx.
Referenced by deallocate(), and initCoarseMemory().
◆ _sizeOf1Elm
◆ _start
◆ DFT_CHAR_VAR
const char SeqAlloc::DFT_CHAR_VAR =-17
