MEDLoader.hxx File Reference
Include dependency graph for MEDLoader.hxx:
namespace  MEDCoupling
void MEDCoupling::AssignStaticWritePropertiesTo (MEDCoupling::MEDFileWritable &obj)
void MEDCoupling::CheckFileForRead (const std::string &fileName)
std::vector< std::pair< std::pair< int, int >, double > > MEDCoupling::GetAllFieldIterations (const std::string &fileName, const std::string &fieldName)
std::vector< std::string > MEDCoupling::GetAllFieldNames (const std::string &fileName)
std::vector< std::string > MEDCoupling::GetAllFieldNamesOnMesh (const std::string &fileName, const std::string &meshName)
std::vector< std::pair< int, int > > MEDCoupling::GetCellFieldIterations (const std::string &fileName, const std::string &meshName, const std::string &fieldName)
std::vector< std::string > MEDCoupling::GetCellFieldNamesOnMesh (const std::string &fileName, const std::string &meshName)
std::vector< std::pair< std::string, std::string > > MEDCoupling::GetComponentsNamesOfField (const std::string &fileName, const std::string &fieldName)
void MEDCoupling::GetFamiliesGroupsInfo (const std::string &fileName, const std::string &meshName, std::map< std::string, mcIdType > &families, std::map< std::string, std::vector< std::string > > &groupsOnFam)
std::vector< std::pair< int, int > > MEDCoupling::GetFieldIterations (MEDCoupling::TypeOfField type, const std::string &fileName, const std::string &meshName, const std::string &fieldName)
std::vector< std::string > MEDCoupling::GetFieldNamesOnMesh (MEDCoupling::TypeOfField type, const std::string &fileName, const std::string &meshName)
std::vector< std::string > MEDCoupling::GetMeshFamiliesNames (const std::string &fileName, const std::string &meshName)
std::vector< std::string > MEDCoupling::GetMeshFamiliesNamesOnGroup (const std::string &fileName, const std::string &meshName, const std::string &grpName)
std::vector< std::string > MEDCoupling::GetMeshGroupsNames (const std::string &fileName, const std::string &meshName)
std::vector< std::string > MEDCoupling::GetMeshGroupsNamesOnFamily (const std::string &fileName, const std::string &meshName, const std::string &famName)
std::vector< std::string > MEDCoupling::GetMeshNames (const std::string &fileName)
std::vector< std::string > MEDCoupling::GetMeshNamesOnField (const std::string &fileName, const std::string &fieldName)
std::vector< std::pair< int, int > > MEDCoupling::GetNodeFieldIterations (const std::string &fileName, const std::string &meshName, const std::string &fieldName)
std::vector< std::string > MEDCoupling::GetNodeFieldNamesOnMesh (const std::string &fileName, const std::string &meshName)
double MEDCoupling::GetTimeAttachedOnFieldIteration (const std::string &fileName, const std::string &fieldName, int iteration, int order)
std::vector< MEDCoupling::TypeOfField > MEDCoupling::GetTypesOfField (const std::string &fileName, const std::string &meshName, const std::string &fieldName)
std::vector< std::vector< std::pair< INTERP_KERNEL::NormalizedCellType, int > > > MEDCoupling::GetUMeshGlobalInfo (const std::string &fileName, const std::string &meshName, int &meshDim, int &spaceDim, mcIdType &numberOfNodes)
bool MEDCoupling::HasXDR ()
void MEDCoupling::MEDFileVersion (int &major, int &minor, int &release)
std::string MEDCoupling::MEDFileVersionOfFileStr (const std::string &fileName)
std::string MEDCoupling::MEDFileVersionStr ()
MCAuto< MEDCoupling::MEDCouplingField > MEDCoupling::ReadField (const std::string &fileName)
MCAuto< MEDCoupling::MEDCouplingField > MEDCoupling::ReadField (const std::string &fileName, const std::string &fieldName)
MCAuto< MEDCoupling::MEDCouplingField > MEDCoupling::ReadField (const std::string &fileName, const std::string &fieldName, int iteration, int order)
MCAuto< MEDCoupling::MEDCouplingField > MEDCoupling::ReadField (MEDCoupling::TypeOfField type, const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
MEDCoupling::MEDCouplingField * MEDCoupling::ReadFieldCell (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
MEDCoupling::MEDCouplingField * MEDCoupling::ReadFieldGauss (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
MEDCoupling::MEDCouplingField * MEDCoupling::ReadFieldGaussNE (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
MEDCoupling::MEDCouplingField * MEDCoupling::ReadFieldNode (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, int iteration, int order)
std::vector< MEDCoupling::MEDCouplingFieldDouble * > MEDCoupling::ReadFieldsCellOnSameMesh (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, const std::vector< std::pair< int, int > > &its)
std::vector< MEDCoupling::MEDCouplingFieldDouble * > MEDCoupling::ReadFieldsGaussNEOnSameMesh (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, const std::vector< std::pair< int, int > > &its)
std::vector< MEDCoupling::MEDCouplingFieldDouble * > MEDCoupling::ReadFieldsGaussOnSameMesh (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, const std::vector< std::pair< int, int > > &its)
std::vector< MEDCoupling::MEDCouplingFieldDouble * > MEDCoupling::ReadFieldsNodeOnSameMesh (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, const std::vector< std::pair< int, int > > &its)
std::vector< MEDCoupling::MEDCouplingFieldDouble * > MEDCoupling::ReadFieldsOnSameMesh (MEDCoupling::TypeOfField type, const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::string &fieldName, const std::vector< std::pair< int, int > > &its)
MEDCoupling::MEDCouplingMesh * MEDCoupling::ReadMeshFromFile (const std::string &fileName, const std::string &meshName, int meshDimRelToMax=0)
MEDCoupling::MEDCouplingMesh * MEDCoupling::ReadMeshFromFile (const std::string &fileName, int meshDimRelToMax=0)
int MEDCoupling::ReadUMeshDimFromFile (const std::string &fileName, const std::string &meshName)
MEDCoupling::MEDCouplingUMesh * MEDCoupling::ReadUMeshFromFamilies (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::vector< std::string > &fams)
MEDCoupling::MEDCouplingUMesh * MEDCoupling::ReadUMeshFromFile (const std::string &fileName, const std::string &meshName, int meshDimRelToMax=0)
MEDCoupling::MEDCouplingUMesh * MEDCoupling::ReadUMeshFromFile (const std::string &fileName, int meshDimRelToMax=0)
MEDCoupling::MEDCouplingUMesh * MEDCoupling::ReadUMeshFromGroups (const std::string &fileName, const std::string &meshName, int meshDimRelToMax, const std::vector< std::string > &grps)
void MEDCoupling::SetCompPolicyForCell (int val)
void MEDCoupling::SetEpsilonForNodeComp (double val)
void MEDCoupling::SetTooLongStrPolicy (int val)
void MEDCoupling::WriteField (const std::string &fileName, const MEDCoupling::MEDCouplingField *f, bool writeFromScratch)
void MEDCoupling::WriteFieldDep (const std::string &fileName, const MEDCoupling::MEDCouplingField *f, bool writeFromScratch)
void MEDCoupling::WriteFieldUsingAlreadyWrittenMesh (const std::string &fileName, const MEDCoupling::MEDCouplingField *f)
void MEDCoupling::WriteMesh (const std::string &fileName, const MEDCoupling::MEDCouplingMesh *mesh, bool writeFromScratch)
void MEDCoupling::WriteUMesh (const std::string &fileName, const MEDCoupling::MEDCouplingUMesh *mesh, bool writeFromScratch)
void MEDCoupling::WriteUMeshDep (const std::string &fileName, const MEDCoupling::MEDCouplingUMesh *mesh, bool writeFromScratch)
void MEDCoupling::WriteUMeshes (const std::string &fileName, const std::vector< const MEDCoupling::MEDCouplingUMesh * > &meshes, bool writeFromScratch)
void MEDCoupling::WriteUMeshesPartition (const std::string &fileName, const std::string &meshName, const std::vector< const MEDCoupling::MEDCouplingUMesh * > &meshes, bool writeFromScratch)
void MEDCoupling::WriteUMeshesPartitionDep (const std::string &fileName, const std::string &meshName, const std::vector< const MEDCoupling::MEDCouplingUMesh * > &meshes, bool writeFromScratch)
