INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix > Class Template Reference
#include <PlanarIntersector.hxx>
Inheritance diagram for INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >:
Collaboration diagram for INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >:
typedef MyMeshType::MyConnType ConnType
typedef std::map< ConnType, std::set< ConnType > > DuplicateFacesType
- Public Types inherited from INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >
void createBoundingBoxes (const MyMeshType &mesh, std::vector< double > &bbox)
void getElemBB (double *bb, const MyMeshType &mesh, ConnType iP, ConnType nb_nodes)
virtual const DuplicateFacesType * getIntersectFaces () const
 PlanarIntersector (const MyMeshType &meshT, const MyMeshType &meshS, double dimCaracteristic, double precision, double md3DSurf, double minDot3DSurf, double medianPlane, bool doRotate, int orientation, int printLevel)
virtual ~PlanarIntersector ()
- Public Member Functions inherited from INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >
void adjustBoundingBoxes (double *bbox, std::size_t sz, double adjustmentEps, double adjustmentEpsAbs)
void adjustBoundingBoxes (std::vector< double > &bbox, double adjustmentEps, double adjustmentEpsAbs)
virtual ConnType getNumberOfColsOfResMatrix () const =0
virtual ConnType getNumberOfRowsOfResMatrix () const =0
virtual void intersectCells (ConnType targetCell, const std::vector< ConnType > &srcCells, MyMatrix &res)=0
virtual ~TargetIntersector ()
static int Projection (double *Coords_A, double *Coords_B, ConnType nb_NodesA, ConnType nb_NodesB, double epsilon, double md3DSurf, double minDot3DSurf, double median_plane, bool do_rotate)
Static Public Attributes
static const int MESHDIM = MyMeshType::MY_MESHDIM
static const NumberingPolicy numPol = MyMeshType::My_numPol
static const int SPACEDIM = MyMeshType::MY_SPACEDIM
- Static Public Attributes inherited from INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >
void getRealCoordinates (ConnType icellT, ConnType icellS, ConnType nbNodesT, ConnType nbNodesS, std::vector< double > &coordsT, std::vector< double > &coordsS, int &orientation)
void getRealSourceCoordinates (ConnType icellS, std::vector< double > &coordsS)
void getRealSourceCoordinatesPermute (ConnType icellS, ConnType offset, std::vector< double > &coordsS)
void getRealTargetCoordinates (ConnType icellT, std::vector< double > &coordsT)
void getRealTargetCoordinatesPermute (ConnType icellT, ConnType offset, std::vector< double > &coordsT)
double getValueRegardingOption (double val) const
int projectionThis (double *Coords_A, double *Coords_B, ConnType nb_NodesA, ConnType nb_NodesB)
static void Rotate3DTriangle (double *PP1, double *PP2, double *PP3, TranslationRotationMatrix &rotation_matrix)
const ConnType * _connectS
const ConnType * _connectT
const ConnType * _connIndexS
const ConnType * _connIndexT
const double * _coordsS
const double * _coordsT
double _dim_caracteristic
bool _do_rotate
double _max_distance_3Dsurf_intersect
double _median_plane
const MyMeshType & _meshS
const MyMeshType & _meshT
double _min_dot_btw_3Dsurf_intersect
int _orientation
double _precision
int _print_level
◆ ConnType
template<class MyMeshType , class MyMatrix >
typedef MyMeshType::MyConnType INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::ConnType
◆ DuplicateFacesType
typedef std::map<ConnType, std::set<ConnType> > INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::DuplicateFacesType
◆ PlanarIntersector()
INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::PlanarIntersector ( const MyMeshType &  meshT,
const MyMeshType &  meshS,
double  precision,
double  md3DSurf,
double  medianPlane,
bool  doRotate,
int  orientation,
int  printLevel
◆ ~PlanarIntersector()
INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::~PlanarIntersector
◆ createBoundingBoxes()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::createBoundingBoxes ( const MyMeshType &  mesh,
std::vector< double > &  bbox
creates the bounding boxes for all the cells of mesh mesh
The method accepts mixed meshes (containing triangles and quadrangles). The vector returned is of dimension 6*nb_elems with bounding boxes stored as xmin1, xmax1, ymin1, ymax1, zmin1, zmax1, xmin2, xmax2, ymin2,... The returned pointer must be deleted by the calling code.
meshstructure pointing to the mesh
bboxvector containing the bounding boxes
◆ getElemBB()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getElemBB ( double *  bb,
ConnType  iP,
ConnType  nb_nodes
Computes the bounding box of a given element. iP in numPol mode.
◆ Projection()
int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::Projection ( double *  Coords_A,
double *  Coords_B,
ConnType  nb_NodesA,
ConnType  nb_NodesB,
double  epsilon,
double  md3DSurf,
bool  do_rotate
◆ getIntersectFaces()
virtual const DuplicateFacesType * INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getIntersectFaces ( ) const
◆ projectionThis()
int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::projectionThis ( double *  Coords_A,
double *  Coords_B,
ConnType  nb_NodesA,
ConnType  nb_NodesB
◆ getRealTargetCoordinates()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getRealTargetCoordinates ( ConnType  icellT,
std::vector< double > &  coordsT
icellTid in target mesh in format of MyMeshType.
coordsToutput val that stores coordinates of the target cell automatically resized to the right length.
◆ getRealSourceCoordinates()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getRealSourceCoordinates ( ConnType  icellS,
std::vector< double > &  coordsS
icellSid in source mesh in format of MyMeshType.
coordsSoutput val that stores coordinates of the source cell automatically resized to the right length.
◆ getRealTargetCoordinatesPermute()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getRealTargetCoordinatesPermute ( ConnType  icellT,
ConnType  offset,
offsetis a value in C format that indicates the number of circular permutation.
◆ getRealSourceCoordinatesPermute()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getRealSourceCoordinatesPermute ( ConnType  icellS,
ConnType  offset,
◆ getRealCoordinates()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getRealCoordinates ( ConnType  icellT,
ConnType  icellS,
ConnType  nbNodesT,
ConnType  nbNodesS,
std::vector< double > &  coordsT,
std::vector< double > &  coordsS,
int &  orientation
nbNodesTnb of nodes of the target cell.
nbNodesSnb of nodes of the source cell.
orientationis an output value too, only set if SPACEDIM==3.
◆ getValueRegardingOption()
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::getValueRegardingOption ( double  val) const
Filtering out zero surfaces and badly oriented surfaces _orientation = -1,0,1,2 -1 : the intersection is taken into account if target and cells have different orientation 0 : the intersection is always taken into account 1 : the intersection is taken into account if target and cells have the same orientation 2 : the absolute value of intersection is always taken into account
◆ Rotate3DTriangle()
void INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::Rotate3DTriangle ( double *  PP1,
double *  PP2,
double *  PP3,
TranslationRotationMatrix &  rotation_matrix
staticprotected
◆ SPACEDIM
const int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::SPACEDIM = MyMeshType::MY_SPACEDIM
◆ MESHDIM
const int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::MESHDIM = MyMeshType::MY_MESHDIM
◆ numPol
const NumberingPolicy INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::numPol = MyMeshType::My_numPol
◆ _connectT
const ConnType* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_connectT
◆ _connectS
const ConnType* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_connectS
◆ _coordsT
const double* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_coordsT
◆ _coordsS
const double* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_coordsS
◆ _connIndexT
const ConnType* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_connIndexT
◆ _connIndexS
const ConnType* INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_connIndexS
◆ _meshT
const MyMeshType& INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_meshT
◆ _meshS
const MyMeshType& INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_meshS
◆ _dim_caracteristic
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_dim_caracteristic
◆ _max_distance_3Dsurf_intersect
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_max_distance_3Dsurf_intersect
◆ _min_dot_btw_3Dsurf_intersect
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_min_dot_btw_3Dsurf_intersect
◆ _precision
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_precision
◆ _median_plane
double INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_median_plane
◆ _do_rotate
bool INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_do_rotate
◆ _orientation
int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_orientation
◆ _print_level
int INTERP_KERNEL::PlanarIntersector< MyMeshType, MyMatrix >::_print_level
