MEDCoupling::MEDCouplingRemapper Member List
This is the complete list of members for MEDCoupling::MEDCouplingRemapper, including all inherited members.
BARYCENTRIC_INTERSECT_STRINTERP_KERNEL::InterpolationOptionsstatic
BARYCENTRICGEO2D_INTERSECT_STRINTERP_KERNEL::InterpolationOptionsstatic
BOUNDING_BOX_ADJ_ABS_STRINTERP_KERNEL::InterpolationOptionsstatic
BOUNDING_BOX_ADJ_STRINTERP_KERNEL::InterpolationOptionsstatic
BuildFieldTemplatesFrom(const MEDCouplingMesh *srcMesh, const MEDCouplingMesh *targetMesh, const std::string &method, MCAuto< MEDCouplingFieldTemplate > &src, MCAuto< MEDCouplingFieldTemplate > &target)MEDCoupling::MEDCouplingRemapper
BuildMethodFrom(const std::string &meth1, const std::string &meth2)MEDCoupling::MEDCouplingRemapperstatic
CheckAndSplitInterpolationMethod(const std::string &method, std::string &srcMeth, std::string &trgMeth)INTERP_KERNEL::InterpolationOptionsstatic
CONVEX_INTERSECT2D_STRINTERP_KERNEL::InterpolationOptionsstatic
copyOptions(const InterpolationOptions &other)INTERP_KERNEL::InterpolationOptions
declareAsNew() constMEDCoupling::TimeLabel
DO_ROTATE_STRINTERP_KERNEL::InterpolationOptionsstatic
filterInterpolationMethod(const std::string &meth) constINTERP_KERNEL::InterpolationOptions
forceTimeOfThis(const TimeLabel &other) constMEDCoupling::TimeLabelprotected
GENERAL_SPLIT_24_STRINTERP_KERNEL::InterpolationOptionsstatic
GENERAL_SPLIT_48_STRINTERP_KERNEL::InterpolationOptionsstatic
GEOMETRIC_INTERSECT2D_STRINTERP_KERNEL::InterpolationOptionsstatic
getBoundingBoxAdjustment() constINTERP_KERNEL::InterpolationOptions
getBoundingBoxAdjustmentAbs() constINTERP_KERNEL::InterpolationOptions
getCrudeMatrix() constMEDCoupling::MEDCouplingRemapper
getDoRotate() constINTERP_KERNEL::InterpolationOptions
getFEOptions() constINTERP_KERNEL::InterpolationOptions
getInterpolationMatrixPolicy() constMEDCoupling::MEDCouplingRemapper
getIntersectionType() constINTERP_KERNEL::InterpolationOptions
getIntersectionTypeRepr() constINTERP_KERNEL::InterpolationOptions
getMaxDistance3DSurfIntersect() constINTERP_KERNEL::InterpolationOptions
getMaxDistanceStatus() const overrideINTERP_KERNEL::InterpolationOptionsvirtual
getMaxValueInCrudeMatrix() constMEDCoupling::MEDCouplingRemapper
getMeasureAbsStatus() constINTERP_KERNEL::InterpolationOptions
getMedianPlane() constINTERP_KERNEL::InterpolationOptions
getMinDotBtwPlane3DSurfIntersect() constINTERP_KERNEL::InterpolationOptions
getNumberOfColsOfMatrix() constMEDCoupling::MEDCouplingRemapper
getOrientation() constINTERP_KERNEL::InterpolationOptions
getPrecision() constINTERP_KERNEL::InterpolationOptions
getPrintLevel() constINTERP_KERNEL::InterpolationOptions
getProjectionMaxDistance() const overrideINTERP_KERNEL::InterpolationOptionsvirtual
getProjectionOnSurfStatus() const overrideINTERP_KERNEL::InterpolationOptionsvirtual
getSplittingPolicy() constINTERP_KERNEL::InterpolationOptions
getSplittingPolicyRepr() constINTERP_KERNEL::InterpolationOptions
getTimeOfThis() constMEDCoupling::TimeLabel
init()INTERP_KERNEL::InterpolationOptions
InterpolationOptions()INTERP_KERNEL::InterpolationOptions
InterpolationOptions(const InterpolationOptions &other)=defaultINTERP_KERNEL::InterpolationOptions
INTERSEC_TYPE_STRINTERP_KERNEL::InterpolationOptionsstatic
MAX_DISTANCE_3DSURF_INSECT_STRINTERP_KERNEL::InterpolationOptionsstatic
MEASURE_ABS_STRINTERP_KERNEL::InterpolationOptionsstatic
MEDCouplingRemapper()MEDCoupling::MEDCouplingRemapper
MEDIANE_PLANE_STRINTERP_KERNEL::InterpolationOptionsstatic
MIN_DOT_BTW_3DSURF_INSECT_STRINTERP_KERNEL::InterpolationOptionsstatic
nullifiedTinyCoeffInCrudeMatrix(double scaleFactor)MEDCoupling::MEDCouplingRemapper
nullifiedTinyCoeffInCrudeMatrixAbs(double maxValAbs)MEDCoupling::MEDCouplingRemapper
MEDCoupling::operator=(const TimeLabel &other)MEDCoupling::TimeLabel
INTERP_KERNEL::InterpolationOptions::operator=(const InterpolationOptions &other)=defaultINTERP_KERNEL::InterpolationOptions
ORIENTATION_STRINTERP_KERNEL::InterpolationOptionsstatic
partialTransfer(const MEDCouplingFieldDouble *srcField, MEDCouplingFieldDouble *targetField)MEDCoupling::MEDCouplingRemapper
PLANAR_SPLIT_FACE_5_STRINTERP_KERNEL::InterpolationOptionsstatic
PLANAR_SPLIT_FACE_6_STRINTERP_KERNEL::InterpolationOptionsstatic
POINTLOCATOR_INTERSECT_STRINTERP_KERNEL::InterpolationOptionsstatic
PRECISION_STRINTERP_KERNEL::InterpolationOptionsstatic
prepare(const MEDCouplingMesh *srcMesh, const MEDCouplingMesh *targetMesh, const std::string &method)MEDCoupling::MEDCouplingRemapper
prepareEx(const MEDCouplingFieldTemplate *src, const MEDCouplingFieldTemplate *target)MEDCoupling::MEDCouplingRemapper
PRINT_LEV_STRINTERP_KERNEL::InterpolationOptionsstatic
PrintMatrix(const std::vector< std::map< mcIdType, double > > &m)MEDCoupling::MEDCouplingRemapperstatic
printOptions() constINTERP_KERNEL::InterpolationOptions
reverseTransfer(MEDCouplingFieldDouble *srcField, const MEDCouplingFieldDouble *targetField, double dftValue)MEDCoupling::MEDCouplingRemapper
reverseTransferField(const MEDCouplingFieldDouble *targetField, double dftValue)MEDCoupling::MEDCouplingRemapper
setBoundingBoxAdjustment(double bba)INTERP_KERNEL::InterpolationOptions
setBoundingBoxAdjustmentAbs(double bba)INTERP_KERNEL::InterpolationOptions
setCrudeMatrix(const MEDCouplingMesh *srcMesh, const MEDCouplingMesh *targetMesh, const std::string &method, const std::vector< std::map< mcIdType, double > > &m)MEDCoupling::MEDCouplingRemapper
setCrudeMatrixEx(const MEDCouplingFieldTemplate *src, const MEDCouplingFieldTemplate *target, const std::vector< std::map< mcIdType, double > > &m)MEDCoupling::MEDCouplingRemapper
setDoRotate(bool dr)INTERP_KERNEL::InterpolationOptions
setInterpolationMatrixPolicy(int newInterpMatPol)MEDCoupling::MEDCouplingRemapper
setInterpolationOptions(int print_level, std::string intersection_type, double precision, double median_plane, bool do_rotate, double bounding_box_adjustment, double bounding_box_adjustment_abs, double max_distance_for_3Dsurf_intersect, int orientation, bool measure_abs, std::string splitting_policy)INTERP_KERNEL::InterpolationOptions
setIntersectionType(IntersectionType it)INTERP_KERNEL::InterpolationOptions
setMaxDistance3DSurfIntersect(double bba)INTERP_KERNEL::InterpolationOptions
setMaxDistanceStatus(bool maxDistStatus) overrideINTERP_KERNEL::InterpolationOptionsvirtual
setMeasureAbsStatus(bool newStatus)INTERP_KERNEL::InterpolationOptions
setMedianPlane(double mp)INTERP_KERNEL::InterpolationOptions
setMinDotBtwPlane3DSurfIntersect(double v)INTERP_KERNEL::InterpolationOptions
setOptionDouble(const std::string &key, double value)MEDCoupling::MEDCouplingRemapper
setOptionInt(const std::string &key, int value)MEDCoupling::MEDCouplingRemapper
setOptionString(const std::string &key, const std::string &value)MEDCoupling::MEDCouplingRemapper
setOrientation(int o)INTERP_KERNEL::InterpolationOptions
setPrecision(double p)INTERP_KERNEL::InterpolationOptions
setPrintLevel(int pl)INTERP_KERNEL::InterpolationOptions
setProjectionMaxDistance(double projDistMax) overrideINTERP_KERNEL::InterpolationOptionsvirtual
setProjectionOnSurfStatus(bool projOnSurfStatus) overrideINTERP_KERNEL::InterpolationOptionsvirtual
setSplittingPolicy(SplittingPolicy sp)INTERP_KERNEL::InterpolationOptions
SPLITTING_POLICY_STRINTERP_KERNEL::InterpolationOptionsstatic
TimeLabel(const TimeLabel &other)=defaultMEDCoupling::TimeLabel
TimeLabel()MEDCoupling::TimeLabelprotected
transfer(const MEDCouplingFieldDouble *srcField, MEDCouplingFieldDouble *targetField, double dftValue)MEDCoupling::MEDCouplingRemapper
transferField(const MEDCouplingFieldDouble *srcField, double dftValue)MEDCoupling::MEDCouplingRemapper
TRIANGULATION_INTERSECT2D_STRINTERP_KERNEL::InterpolationOptionsstatic
updateTimeWith(const TimeLabel &other) constMEDCoupling::TimeLabelprotected
~InterpolationOptions()=defaultINTERP_KERNEL::InterpolationOptions
~MEDCouplingRemapper()MEDCoupling::MEDCouplingRemapper
~TimeLabel()MEDCoupling::TimeLabelprotectedvirtual
